Question about Brother CE5000 Computerized Sewing Machine
Bobbin thread tangles
After practicing free motion quilting, I can no longer sew. The bottom thread tangles and does not seem to be "picked up" by the top thread. The machine shudders and displays an E-6 error msg. The needle is very hard to raise and disengage. The fabric is pulled into the bobbin area. I have changed needles, bobbins, reloaded bobbin, cleaned lint from bobbin case and area, rethreaded needle, changed tension.
  • Brother Master
  • 7,365 Answers
When this happens have you check to see if the thread has come off the thread take up lever?
Posted on Feb 10, 2012
How to Free motion quilting on Janome 1600P QC
Be sure to use a darning foot (or free motion quilting foot).
Use a brand new sharp needle, ie top stitch, embroidery, or microtex work well.
Check that the thread, needle, and fabric are compatible--Caution, the needle eye should be the right size for the thread weight.
AVOID old or bargain bin thread!
Be sure to drop or cover the feed dogs.
If your machine has it, use the needle down feature.
You may need to adjust the tension for FMQ--I have to tighten the bobbin tension a little to keep the bobbin thread below the quilt surface (so I bought a special bobbin case and set the tension for FMQ and that's all I use it for.)
Lots of web sites that talk about how to free motion quilt. Then, it's PRACTICE, PRACTICE, PRACTICE! I use a portable white board and draw free motion designs on it (while watching TV, etc.). The idea is to get it fluid without jerking, jumping, speeding up or slowing down, etc. When your hand and brain are able to work smoothly, then you can probably do free motion quilting. Practice on scraps of fabric and batting (preferably the same kind you will be working on). Cut up some 14 inch squares of fabric and batting and draw designs on them and see if you can stitch them. Some advice: don't watch the needle...look at where you are going in front of the needle. Don't expect perfection to happen overnight. Many quilters have been FMQing for years and still make mistakes. (I've made a few quilts and my stuff still looks less than professional, but it's all mine!)
Free Motion Quilting with Janome 1600P sewing discussion topic...
All About Needles
Jul 23, 2017 | Janome Sewing Machines
How do I set up my Janome 1600p-qc for free motion quilting?
You will need a darning foot or free motion quilting foot for your machine (these feet are shorter than the regular feet which allows space between the foot and the needle plate to manually manipulate your fabric). Then drop the feed dogs and, if your machine does not have that capability, there should be a cover plate included with your machine that snaps over the feed dogs. Install a brand new needle in your machine, set it for a straight stitch, and test the stitch. Sometimes, the upper tension needs to be loosened a bit so the bobbin thread does not poke through the top of the fabric.
Then...practice, practice, practice...
How to Free Motion Quilt on Regular Sewing Machine
Free Motion Quilting Beginner Tutorial 1 of 4
FWIW, I've found it helpful to use a "Supreme Slider" on the base of my machine. It is slick and allows the fabric to move easily. Special gloves are helpful too because your hand will become dry and begin to slip on the fabric. Using cheap rubber gardening gloves works for some people.
supreme slider Google Search
quilt gloves Google Search
Feb 11, 2017 | Janome Sewing Machines
Bobbin thread will not catch unless the foot is down?
Ashleigh--Your machine will work satisfactorily ONLY if the presser foot is down. When the presser foot is up, the tension disk is released, therefore, no tension = a big knot of thread.
To free motion quilt, you should drop the feed dogs. Install a darning foot (this foot is shorter in length so when it is lowered, there is a space between the presser foot and needle plate). The space allows the fabric to be moved easily while stitching.
Some sewists will free motion quilt without a presser foot (if they don't have a darning foot), but that is very dangerous as one can easily sew through a finger. However, even when sewing without a presser foot, the presser foot mechanism needs to be lowered in order to properly form stitches.
Feb 25, 2016 | Sewing Machines
PLEASE TELL ME THE EXACT SETTINGS FOR THIS MACHINE FOR FREE MOTION QUILTING
How can anyone do that when we do not know the make of it .
Jan 05, 2016 | Sewing Machines
Brother Sq9185 sewing machine, the thread on bottom just pulls out, when free motion quilting? how do I fix this
Sounds like the upper tension needs to be tightened, or the bobbin thread needs to be loosened. At any rate, the tension is correct when the two threads meet in the middle of the fabric for general sewing.
For free motion quilting, the tension should be adjusted so that the bobbin thread does not show on the top of the fabric, however, it should not lay in a straight line like it sounds like it may appear currently. What you are currently producing is a gathering stitch where the bobbin thread can be easily pulled.
Nov 16, 2015 | Generic Brother 130-Stitch Sewing and...
Machine well not work with the quilting foot what can I do
Basic Tips for All
  1. Always turn the handwheel TOWARDS you (counter clockwise) as turning it in the opposite direction (away from you, clockwise) may knock the timing out requiring repair from a service center.
  2. Always be sure your presser foot is in the DOWN position before sewing. Sewing with the presser foot in the up position will cause your thread to tangle and your bobbin to jam.
  3. Change needles regularly (after 16 hours of use) as dull/weak needles can cause damage to your machine and fabric. Only use SINGER needles on your SINGER sewing machine.
  4. Always be sure you are using the correct bobbin for your machine. Class 66, Class 15 and Class 15J bobbins look very similar. However, using the incorrect bobbin class in your machine can cause damage.
How do I thread my 3/4 thread serger? (14SH654, 14ET754, 14SH764, 14CG754)
Q.
How do I thread my 2/3/4/5 thread serger? (14T967, 14T968, 14T957)
Why is my electronic machine beeping? Why won't my machine sew? Why will my machine start to sew then stop?
Q.
How do I sew denim and heavy fabrics?
Q.
Why is my bobbin not winding evenly?
Q.
Why won't my machine pick up the bobbin thread?
Q.
Why is my machine skipping stitches?
Q.
Why is the thread looping/bunching under my fabric?
Q.
Why is the thread looping/bunching on top of my fabric?
Q.
Why doesn't my stitch pattern match what is on my machine?
Q.
How often should I oil my machine?
Q.
What types of thread should I use?
Q.
I can't see the take-up lever? h
May 17, 2015 | Juki Sewing Machines
Bobbin thread is not being picked up when I free motion quilt
Duh. It was the breaker. Always check the breaker ...especially around Xmas!
Dec 04, 2013 | Janome Memory Craft 9000 Computerized...
When attempting to free motion quilt, bottom thread is not being picked up
You must lower the presser foot to use the free motion/darning foot.
Dec 04, 2013 | Brother Sewing Machines
When free motion quilting I get loops on top of the fabric and on the bottom when doing tight curves. I also get thread "puke" - tangles and snarls on the bottom when going through the quilt...
Check the height of the quilt under the machine-adjust the bars until the quilt is just barely over the bed of the machine, and level front to back and side to side. Also, level up the frame, using a long carpenter's level. You'd be surprised how much this can help with all sorts of thread problems.
Feb 23, 2011 | Juki TL-98Q
Timing
Question: How does one find the tension discs??? I have a White 1740 with a top drop in bobbin and I went thru the same problems as night_wolf above, then, ultimately, the top thread will now not pick-up the bobbin thread through the fabric. It picks up the bobbin thread without fabric in play, but once fabric is added (for free motion quilting) it won't pick it up. This is after using the machine for the last 10 days to piece and quilt without a problem until this morning.
I'm at a loss.
Tks, Candace
Jan 17, 2008 | Brother LS-2125 Mechanical Sewing Machine
Brother CE5000 Computerized Sewing Machine Logo
189 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
