Question about Cell Phones
I am using a Nokia Wireless Headset HS_26W with a Nokia 2600 mobile phone. I can hear people I call perfectly, however, they all complain of an echo at their end Any solutions Thanks
  • aisro1 Oct 23, 2008
    I don't know if this is the problem as I used the same wireless handset with another phone and there were no problems
    Aisro1
    Master:
  • 505 Answers
Make sure there is no electronic device in and around. Since wirless connection is bound to be effected because for interference with other electromagnetic signal, you get the echo sound.
There are certain devices available in the market which will take care of the echo. Please click on this link to know more about the product. http://www.widebandsolutions.com/
Thanks.
Posted on Oct 23, 2008
  • Indrajit Roy
    Indrajit Roy Oct 23, 2008
    Please go through the reason for the echo in brief.
    Summary: Integrating voice-processing algorithms into headsets is a challenging task due to size and power constraints. As a result of the small size of these headsets, acoustic leakage between the closely located speaker and microphone is a common problem. To address this problem, an oversampled sub-band adaptive acoustic echo cancellation system is proposed and implemented on an ultra-low resource DSP system. The echo cancellation algorithm is integrated with two voice activity detectors and double-talk detection logic to provide a fully functional system. By using decimation, load balancing and other optimization techniques, the complete system consumes about 6 mW. Other signal-processing algorithms can be added with very little impact on power consumption and no impact on size. Tests on a Bluetooth headset show an echo return loss enhancement of about 15 dB for a typical headset signal level
  • Indrajit Roy
    If this is the case then its a problem with your phone. You may have noticed that even when we are not using the Wireless headset we get a echo. The reason being is that the alignment is not correct. Get the Sound part of your mobile checked. You can contact Nokia Service centre in that case as we are sure that the Wirless headset is not a problem in your case.
    Thanks
    Master:
  • 538 Answers
Hmm..that is a little odd..it may be coming from your voice hitting the wireless headset and also the mike on the phone at basically, but not precisely the same time..try it with the phone far enough away so that the mike on the unit can not pick up your voice..
  • A Womans Computer Man
    A Womans Computer Man Oct 23, 2008
    that would explain what is technically called shadowing of a voice signal
    and thank you for using fixya to solve this problem..
Wife complains of echoing when listening to me on headset. Love the headset cause I'm hearing impaired.
Plantronics Voyager 510 echoing:
If the Plantronics Voyager 510 headset is being used with the base on a regular telephone, you can adjust the microphone volume on the bottom of the base unit.
If the Voyager 510 headset is being used with just a cell phone... unfortunately there aren't many adjustments. You may want to un-pair and delete the headset from the cell phone totally, and then re-pair it to the phone just to make sure that it has a strong link or connection.
Also just as a side note about Bluetooth headsets and cell phones. Typically the simpler the cell phone, the better the Bluetooth connection and quality.
Good luck from Headsets Direct - 800-914-7996.
Aug 03, 2011 | Plantronics 510 Voyager Headset - PLN-510...
I've just bought a Nokia Bluetooth headset BH-503, using it with Nokia 6300 phone. The person I'm calling says he hears terrible echo, but I hear fine
Check where your phone is during the conversation. Even if it is written that Bluetooth works fine up to 10m I usually have problems when phone is in the pocket on the other body side that my headset receiver.
Jun 02, 2010 | Nokia BH-501 Headset
Person I am speaking to complains that they can hear back everything they are saying.(echo)
Go to your phone carrier and exchange the phone out to one that doesn't have echo.
Jan 31, 2010 | Motorola Mobility Bluetooth Hands-Free...
Plantronics CS55. When using the wireless headset
Echo is usually caused by the transmit (speak) level on the unit being set too high.
1. First, try lowering the volume of the telephone. If you still hear an echo, adjust the volume of the headset itself.
2. The master transmit controls of the headset are the ABCD switch settings on the bottom of the base. A is the lowest and D is the highest setting.
3. You can fine tune this setting with the plus (+) and minus (-) buttons on the back of the charging base.
4. If this doesn't fix the echo, try moving the configuration dial on the left side of the charging base. The recommended setting for most phones is 1.
Jul 10, 2009 | Plantronics CS55/HL10 Wireless Office...
What is the password to connect handsfree with mobile
The passkey should be four zeros: 0000
Mar 27, 2008 | Lands Phones
Headset not Supported
Nokia HS-3 is a stereo headset.
Your phone does not support stereo.
So Use mono Headsets like HS-5.
Nokia 9300 is a stereo supported phone and hence works with the headset fine.
Dec 01, 2007 | Nokia 7610
HS-23 Not Being Recognized by Phone
Rub the pins of your headset, and your phone with some tissue paper or something like that.
You might use some cleansining agent like alcohol.
Switch off your phone while doing that.
I too encounter such problems.
Dec 01, 2007 | Nokia HS-23 Headset
Echo in hs850 headset
You did not say what phone you are using but I found that this problem went away for me when I changed a setting on my blackberry. I turned "encryption" off in the bluetooth settings on my blackberry 7100t and solved the echo problem. Alternatively, there might be a "compression" setting also. This one made no difference for me but might for you on your device. Also, make sure any firmware or software updates for your phone have been applied. On blackberry devices you do this via a PC. On cell phones it usually involves a reset or update from some buried menu options or call to their tech support. good luck.
Jun 05, 2007 | Motorola Mobility HS850 Consumer Headset
Cell Phones Logo
77 people viewed this question
Top Cell Phones Experts
William Alequin
meteshadow
Are you a Cell Phone Expert? Answer questions, earn points and help others
