Question about Canon PIXMA iP1800 InkJet Photo Printer
Canon ip1880 Power button does not lit up.
Hi i need 1800ip printer progrm downlowd
Posted on Oct 23, 2008
    Sergeant:
    Champion:
  • 214 Answers
Either the power cord isn't working or the power supply unit isn't working
I have canon ip1880 when i give a print command it shows the message on my monitor ink cartridge cannot recognised - color
Solution: press and hold (10 second) reset button/resume (Button reset/resume, under the power button)
Sep 23, 2011 | Canon Office Equipment & Supplies
Canon ip 1800 full tank
Reseter Printer Canon IP1880 To reset manually Ink Full Tank, try these methods :
1. Turn on Printer Canon iP 1880
2. Push and Hold resume button about 2 minutes
3. Release resume button
4. Printer will back in normal again
5. Then use the software.
6. Good Luck friend
7. If you want this permanent, Please Download Reset Tool
8. Reset tool support Canon iP2500, iP 1800, iP 1100
For more details visit the following link
http://indoresetter.blogspot.com/2009/04/reseter-printer-canon-ip1880.html
Feb 09, 2011 | Canon Office Equipment & Supplies
How to solve 5100 error of canon pixma ip1880 series printer
Follow this procedure:
1. Enter Service Mode: Hold Power button and plug a power cord, then push Resume button twice and release all buttons.
2. Free Download from Internet: GeneralTools for Canon Pixma IP1880
3. Starting GeneralTools
4. CHANGE USB PORT change into PORT of your printer
5. click lock release
6. click ip1800
7. click device id
8. clear waste ink counter by clicking MAIN & PLATEN
9. Check EEPROM Box
10. Click EEPROM Dump
Power off printer and all done. Work again!
Jan 11, 2011 | Canon PIXMA iP1800 InkJet Photo Printer
My canon ip1880 's ink absorber is full
Ink absorber is a part of the printer that absorbs the excess ink while printing. There is a way to reset it but its not recommended, as the ink will eventually leak into the printer. I suggest that you get a replacement ink absorber pad from canon and replace the one in your set.
Nov 10, 2010 | Canon Office Equipment & Supplies
How to fix service error on canon ip1800
You will need a resetter. Download this software and follow these steps.
Step 1: Reset hardware
  1. Press Resume button hold for 1 – 2 minutes
  2. Open the cover
  3. Release the catridge and then put catridge again
  4. Close The Cover
  5. Turn Off
  6. then Turn On again
Step 2: Reset Software using general tools
  • Download software resetter or general tools for canon pixma iP1800 http://www.mediafire.com/?nmfns4hixel :Driver should have been install correcly.
  • Connect USB cable.
  • Before connect power, press and hold power button then connect the power.
  • At the same time Hold power button, and press reject button for 2 times then release power button.
  • Run software resetter for canon iP1880.
  • Don’t forget to open lock release in the software. ( note : to view locK release menu, min resolution 1024 x 728)
  • Then select Set Destination to iP1880
  • Check CLEANING and EEPROM CLEAR
  • Click MAIN and PLATEN
  • Finally test print by click TEST PATTERN1.
Mar 18, 2010 | Office Equipment & Supplies
My canon ip1880 printer orange light flashing 7 times even after I have installed both my cartridges correctly.
1. Press power button while plug in the power cord – green lamp.
2. While hold the power button press resume button twice – orange blink and return to green.
3. Release the power button, Then the PC will recognize new printer install.
4. You need the software for permanent reset.
5. Run the software and select printer port.
6. Then select Set Destination
7. Click MAIN and PLATEN button to reset waste ink counter to zero.
8. Finally test print by click TEST PATTERN button.
Oct 09, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Ip1880 reset didn't works
This is the REAL working method of manually resetting Canon ip1880 - ip 1980.
1. Unplug the POWER cord.
2. Press & hold the power button.
3. Connect the power cord WHILE holding the power button.
4. Keep on holding the power button for about 30 seconds.
5. Release the power button. The printer should be turned off.
6. Turn the printer on and that's it!
NOTE: You have to do this every time you turn on your printer. Or you will get the waste pad full error.
Hope this helps.
vulmec.wordpress.com
Apr 24, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Free driver for canon printer ip1880
I want to install cannon iP1880 printers software.please letus know how to installed
Mar 22, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Problem on my Canon ip1880
Unplug the printer from power for a few minutes. If this doesn't reset it, then try the following:
PLUG the printer into power.
1. Press Resume button ( hold for 1 – 2 minutes )
2. Open the cover
3. Release the catridge and then put them in again
4. Close The Cover…
5. Turn Off, then Turn On
Jan 21, 2009 | Canon Office Equipment & Supplies
IP1880 Canon PIXMA showing Ink absorber full
Pixma ip 1880 is full(solution)
1. first unplug power cable and usb cable
2. hold power for 1-2 minutes
3. turn on power
4. your printer should back to normal printing
Mar 07, 2008 | Canon I990 InkJet Photo Printer
Canon PIXMA  iP1800 InkJet Photo Printer Logo
old marine
old marine
