Procom Heater MD300TBE only the pilot works - Heating & Cooling
Therinnaiguy
  • 1420 Answers
SOURCE: Procom ML200TBA
Propane appliances usually run on 10-11 inches of water column, this is about 1/2 pound of pressure. If the regulator you have is not rated for delivering gas at that rate, you will need to find one that does. If your regulator is rated for more than the 11 inches, most likely you could have damaged the appliance regulator that came with the heater. Check the propane pressure specified by the heater manufacture against the rated supply of your regulator and see if they match. Make sure the heater is rated for Propane and NOT Natural Gas. Check to see if the gas valve on the appliance is in the operate position and all valves are open. Bleed off the air in the gas line by holding down the pilot switch and keep attempting to light the pilot. It could take you a few minutes. If you hear and smell gas but the unit will still not light, don't chance at getting hurt, call a technician. Look to make sure there are no safety switch that may have triggered off not allowing the gas valve to operate. And make sure there is no obstruction in the heater?s gas valve blocking off the supply of gas. Always exercise caution when it comes to gas and if you are uncomfortable, call a qualified gas technician.
Posted on Sep 17, 2007
Therinnaiguy
  • 1420 Answers
SOURCE: Pilot light goes out!
Have a technician check your gas pressure, your pilot should be nice and blue. You could start by replacing the thermocouple but I think it is gas related.Is there a pilot adjustment screw on the gas valve? If so increase the flame. Has it always done this? If so, is the model made for the specific gas being used i.e. Natural Gas or Propane and it may be operating on the wrong gas?
Let me know what you find, Thanks!
Posted on Oct 11, 2007
hotuna
  • 288 Answers
SOURCE: Pilot goes out!!
Just a hunch, but most propane have left handed threads. Meaning they turn the opposite from everything else. Its possible you are turning the gas off by mistake.
Posted on Mar 09, 2008
  • 3284 Answers
SOURCE: Gas smell from Procom 28000 btu infared heater
check the connections with some washing up liquied and water in a bowel and try the connections with this , it should help find your leak use a paint brush to put on
Posted on Jan 13, 2009
  • 3284 Answers
SOURCE: procom propane heater will light the pilot but not the burner
the pilot and clean the injector and see if this is clear then try it , you will need a pressure gauge to check the gas pressure ,
Posted on Feb 03, 2010
Procom heater will not stayon
check the milivolt reading with a tester or replace the powerpile/pilot assembly
Sep 30, 2016 | Procom Heating & Cooling
I have a procom ventless fireplace heater and the pilot light will not stay lit
Sounds lie you need to replace the bimetallic strip by the pilot light. If that is bad the main gas nor the pilot will stay on.
Jan 03, 2016 | Procom Heating & Cooling
Pilot light continues to go out on OTL MD300TBE heater
This happens to mine all the time and I wire brush the carbon off the metal tip of the thermocouple and give the pilot and surrounding areas a good blast of compressed air to clear the dust and carbon. Works fine after these cleanings.
Jan 29, 2013 | Heating & Cooling
Procom ML 300TBA Pilot will not stay on when button released
It sounds like you need to clean the contact on the thermocouple.
Here is a link to the service instruction of how to do that.
http://www.allpartsinc.com/mmAllParts/Others/Reseating%20Instructions.pdf
Oct 12, 2012 | Procom ML300TBA Heater
The pilot on my Procom QL300TYLA will not light. It appears that no propane is getting to the pilot. I tried lighting the pilot and burner with a BBQ lighter but nothing. No propane getting to the unit....
sounds like you have a blocked pilot injector. normally part of the pilot head. if you can remove it , blow it out with compressed air but it must be removed from the pilot head. commonly known as a Pilot restrictor,Pilot spud or Pilot injector
Dec 15, 2010 | Procom QL300TYLA Heater
Pilot light is very small on kozy world ventless wall heater
Probably dust in the pilot safety ODS chamber. I like to flush the pilot with rust buster. but shop air will work. More here
Oct 09, 2010 | Procom (177653) Utility Heater
Pilot goes out!!
My manual shows three possibilities:  1) Insufficient fresh air available for combustion, so ODS kicks off gas flow 2) Low gas line pressure (should be between 11 and 14") or 3) ODS/Pilot is partially clogged.  Toll free number for ProCom is 877-886-5989.
Mar 09, 2008 | Procom ML300TBA Heater
Heater runs 2 min. shuts off
Aim the pilot flame harder down the thermocople.
Willis
Feb 11, 2008 | Procom ML300EBC Heater
Heating & Cooling Logo
88 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
