Question about Kenmore Drop-In Bobbin 16231 Mechanical Sewing Machine
Bobbin cover will not close
Bobbin is too high to close cover
  • Kenmore Master
  • 7,365 Answers
If the bobbin cover won't fit easily over the bobbin the either it's the wrong bobbin for the machine, the bobbin is warped or there is something wrong with the bobbin case
Posted on Feb 10, 2012
Bobbin case how to install it.
Follow the below steps to install the bobbin.
1. Prepare the bobbin wound properly before threading the lower thread.
2. Raise the needle by turning the hand wheel toward you (counterclockwise) and raise the presser foot lever.
3. Remove the bobbin cover by sliding it and lift toward you.
4. Put the bobbin in so the thread comes out in the direction shown by the arrow.
5. Hold the end of the thread and push the bobbin down with your finger and pass the thread through the slit.
6. Replace the bobbin cover.
*Put the projection into the race retainer groove and push closed.
*Make sure that the end of the thread comes out from the cover toward the rear of the machine.
*Draw up the lower thread before starting to sew.
Source:http://bit.ly/2Asv4jm
Best Sewing Machine Reviews 2018 The Ultimate Buyer Guide iSewing Machine
Nov 08, 2017 | Sewing Machines
My bottom thread wont pull out once the cover is closed and the thread is pulled through and ready to sew.
If the top thread is not pulling up the bobbin thread, is it actually catching the bobbin thread? If not, then the machine may be out of time. Search for sewing machine timing or take it for service.
If it catches the bobbin thread but then the bobbin thread is difficult to pull, then possibly there is a snag somewhere that is catching the bobbin thread, the bobbin tension needs adjustment, or the bobbin case is incorrectly threaded.
Nov 01, 2017 | Sewing Machines
Viking sapphire 830. Cleaned bobbin case and cannot get bobbin functioning normally. Bobbin thread in big snarl as it Sew's.
Is it actually bobbin thread that is "barfing?" Check closely. If it is under the fabric, it is most likely an upper thread problem. Remove all the thread from the machine. RAISE the presser foot and rethread from the beginning. Verify the thread path is correct. Set the upper tension to the midway point between high & low numbers--this may need to be tweaked for your particular machine. Verify the bobbin is loaded and threaded correctly.
Understanding Thread Tension Threads
Mar 10, 2017 | Sewing Machines
My 9410 wraps the spoon thread around the bobbin. the thread on the bobbin seems to be hard to pull off once the bobbin cover is closed
Got the correct bobbin for the machine? Is it in right way around? Once you've raised the bobbin thread out the needle hole, it should pull smoothly and relatively easily. Might also being snagged on a rough spot on the needle plate (=throat plate) or presser foot. Or has someone been playing with the bobbin tension? That's normally not something the user adjusts for normal sewing. Your machine takes class 66 plastic bobbins: http://www.dritz.com/askus/knownotions/index.php They're the ones with the sides that are slightly curved in at the edges, like two dinner plates facing each other, while the 15s have perfectly straight sides.
Apr 28, 2014 | Singer Sewing Machines
How do i thread the bobbin on a singer electronic anniversary edition
wind bobbin, drop into position ensuring that when thread is pulled bobbin rotates counter clockwise, pull thread towards you into slot, pull it to left under tension spring, then follow thread groove in bed to thread lock back left corner. close cover and start to sew ifr you need Singer 160 instruction email
Feb 04, 2014 | Sewing Machines
C an not get the bobbin cover to go back on
try a different bobbin, make sure the bobbin is seated correctly in bobbin case,,take a can of air & use it on the bobbin case area,,also check for lint or loose thread in bobbin case area
Feb 09, 2012 | Kenmore Drop-In Bobbin 16231 Mechanical...
Bobbin cover door is stuck on Bernina 930 Electronic, and won't open. Can you help me?
Tricky !!! I dont know why the door is stuck, but its possible that the spring-loaded plunger in the top of the bobbin door is stuck into the cover of the free-arm. If there is suficient gap between the top of the bobbin door and the free-arm cover, you could try sliding a thin piece of metal or a very small flat-bladed screwdriver between the two, in the dead-centre of the bobbin door - that's where the plunger is located. By gently manouvreing the screwdriver in, you might be able to release it - be careful, because it's possible that the retaining circlip has dropped-off the bottom, in which case, the plunger and its pressure spring might fly out when the bobbin door opens. If that doesn't work, you could try unscrewing and removing the stitch plate and, again, with a small flat-bladed screwdriver, see if you can release the free-arm cover catch that's next to the top-left-hand-side of the bobbin door, but that's a very risky approach, because the feed-dogs will be in the way and you dont want to mangle any of the hook/shuttle parts etc. You need to find out why the bobbin door is not seated properly - it may be that the bottom hinge that also carries the hook/shuttle retainer has come out of the left-hand hinge mount in the free-arm. Good Luck.
Nov 28, 2011 | Bernina Sewing Machines
B/A 180 engine groans and then stops...push pedal and may start stitching again...Sometimes have to turn hand wheel. ????
Refer to your owner's manual to better assist you in following these instructions.Remove the bobbin case. Release the hook cover by pushing the lever which is located at the top left side of where the bobbin case is inserted. After the cover pops open, remove the hook. Observe if the machine now moves freely. Clean the hook and the hook area with a toothbrush, removing all lint and debris. Place one small drop of sewing machine oil on the rim of the hook. Replace the hook into the raceway and close the cover. Replace the bobbin case and test sew.
Jun 02, 2011 | Bernina Artista 180
Machine does not sew- it does not catch the thread from bobbin
The timing mechanism is likely off. Take off the plastic bobbin case and see if the eye of the needle, on its way up, is just below the metal hook that catch the thread. If not,open the bottom cover with a flat screwdriver, loosen the two 2 mm hex screws, push out and disengage the gears. Adj the hook position by turning left or right so that it is right above the eye of the needle when the needle is on its way up. Tighten the hexes. I also give my machine a good old job with a high grade geese on the gears and light old drop on all moving parts before I close the cover.
Have fun.
Nov 08, 2009 | Singer 6423 Sewing Machine
Bobbin Case will not snap into housing
Insert the bobbin case without a bobbin to see if it will go all the way into the locked position. If it does,the bobbin case and basket are okay.
Check inside the bobbin basket(where the bobbin goes) and see if there is thread or lint wrapped around the spindle the bobbin case sits on. If there is, remove it. If there isn't ,then the bobbin is probably sprung and needs to be replaced.
sewman7
Oct 14, 2008 | Consew 206RB
Kenmore Drop-In Bobbin 16231 Mechanical Sewing Machine Logo
87 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
