Question about JVC RC-EX30 Radio/Cassette/CD Boombox
Cassette or cd player doesn't work
  • Horace Stewart Feb 09, 2012
    Powwer comes on but no motor moves. It appears that a fuse may be blown or amp circuit has failed. How do I fix this
Used isuzu radio/cd/cassette will not work in my vehichle, does it need a code?
If it works @ all it doesn't need a code - it's a bad CD player.
td
Nov 05, 2012 | 1998 Isuzu Rodeo
How do i replace radio cassette player with a cd player mazda 6 2002
Don't replace it. Go to Walmart and buy an adapter. It is usally at the check out somewhere and It cost about $5.00. It has a cassette that goes into the cassette player. Then you plug your ipod or whatever into the attached wire. Doesn't look cool but it works and it is inexpensive. The adapters with the cd player attached skip (we had one 20 years ago) so just buy the new kind of adapter for less and play all your up to date gadgets. Put your cd songs on your ipod or iphone. Our son uses one in his truck with his little ipod shuffle. No cd player needed.
Sep 12, 2012 | Mazda Cars & Trucks
How do I record from a tape cassette to a cd?
You cannot, with this device. It doesn't have a CD-burner... those are usually only found in VERY high end audio systems, or on home computers. That said, you can find devices on the internet that will let you rip audio tracks from a cassette player to an MP3 file, which you can then burn to a CD or put on your computer.
May 05, 2012 | Aiwa CA-DW530 Cassette/CD Boombox
U70 error message on cd player
U70 error message on cd player - Fixya
www.fixya.com/support/t12308553-u70_error_message_cd_player
Apr 5, 2012 - U70 error message on cd player Cd player doesn't work at all. Displays 0 track, 0:00 (min,sec). The play - Technics CD Players question.
Technics error code f 70 CD Players Questions & Answers ...
www.fixya.com > Forum > Tags > error code f 70 > CD Players
Technics cd players error code f 70 related questions and answers. ... won't play cds changer turns on ok, reads error message I have the same problem.
Apr 05, 2012 | Technics Audio Players & Recorders
I have a 2000 grand prix gtp with a radio cassette...I want a radio cd player. I went to a junk yard and found a 2000 grand prix gt with a radio cd player....I bought it (the radio cd player), can i swap...
The wires will be the same. The problem is that the radio you bought may have theftlock on it. ( it would be printed on the front). If so you don't have the code for it. there is a slight chance that it will work, probably 1 in a 100. If it doesn't and the display reads LOC not LOCK, then you can take it to a dealer and they can recode it for you. Costs about 50 dollars here. Indy
Sep 08, 2011 | 2000 Pontiac Grand Prix
How to record a cassette tape to a cd
Your question is posted under a "CD Shelf System" heading. If you really have one of these, the answer is "you can't". The CD player is a player only, not a recorder.
On the other hand, if what you're asking is how to transfer cassette tapes to CD using a computer, there are a couple of ways. One is to connect a cassette player (boom box, component system cassette deck, etc.) to the line-in jack of your computer's sound card. Download and install Audacity, which is free software for recording and editing sound. Then you can record the sound from your cassettes as you play them into the computer.
Another option, If you want to be fancy and spend a little money, is to buy a USB cassette deck. It automatically converts the cassette audio to digital and sends it to your computer over a USB cable. Recording software is supplied (sometimes the Audacity program mentioned before). Several companies make them. Here's one from a company called ION that some friends of mine have, and it seems to work well for them. They've been converting a lot of tapes of family members, and Audacity has been good for cleaning up tape hiss and enhancing the sound.
Either way, once you have the sound in your computer and processed to your liking, you just need to burn it to a CD using whatever burning software you have. (I use CDBurnerXP. It's free, easy to use, and does everything needed for normal CD and DVD burning.)
Aug 10, 2011 | Crosley 4-in-1 Entertainer CD Shelf System
Following a split from my boyfriend I really need some help in how to connect up my hifi system. It's all technics Tuner Receiver ST 610L Equaliser SH GE70 Amp SU V470 CD Changer SL...
the amp should have an in and out for the cassette player also,, so you would go from the Out on the receiver, to the in on the cassette,, and out of the cassette to the in on the receiver, I don't have nor can I locate that EQ , but basically,, you need to come out of the eq and back the same way you would a Cassette player,,
Jun 14, 2011 | Technics SH-GE70 Home Equalizer
JVC RC-EX30 Radio/Cassette/CD Boombox Logo
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
