Question about Philips DVDR 3355 DVD Recorder
Dvdr 3360h dvd blocked - Philips DVDR 3355 DVD Recorder
3 Suggested Answers
nandosnut
  • 112 Answers
SOURCE: dvdr tray
You have one of the following problems:
  • The device freezes and does not react anymore to the remote control commands.
  • The DVD is stuck in the tray. Sometimes the message BLOCKED appears.
  • A feature is not available in the menu without any logical reason.
  • A feature of the device does not work (for example start install).
  • There is some problem with the device you cannot solve.
Reset the DVD recorder.
  1. Unplug the mains cord from the mains wall outlet.
  2. Press the POWER/ON button on the DVD recorder itself.
  3. While keeping the POWER/ON button pressed connect the main power cord to the wall outlet again. A message IS TV ON? or a demo message will appear in the display.
  4. Start the first installation process.
Notes:
    1. The settings of the DVD recorder will return to their default settings. Install the DVD recorder as if it came out of the box.
    2. The data on the hard disc will not be affected.
Posted on Apr 28, 2009
  • 417 Answers
SOURCE: Philips 3360H - can't eject DVD
Try this..turn it off, unplug it for a min or two, then plug it back in. THEN...if the power stays off...hit the eject/open/close button on the panel.
Sometimes this activates the eject mode without turning on the unit. IF NOT, try the remote eject without turning on the unit.
Posted on Apr 06, 2010
Apr 06, 2010 | Philips DVDR3370H DVD Recorder/HDD...
The disc is block inside
Try unplugging and when you plug in again press stop at the same time.
Feb 25, 2010 | Philips DVDR 3355 DVD Recorder
Philips DVDR 3380 - display says''UNKNOWN''
if you get locked deconfigure this is that it can do is restart it from the inside has to find an IC that is the microprocessor and mandar grounding all pins
Aug 20, 2009 | Televison & Video
My dvdr 3380 is blocked...what can to do?
the rubber belt inside de dvd player to open de tray is broken. I replaced it with a elastiek. you need some technical skills to repair it.
Aug 01, 2009 | Philips DVDR3380/05 DVD Recorder
Philips DVDR3380 dvdr say'a blocked!! How can I fix this?
what is the exact message again ?
if it is saying blocked try goin into setup and changing the country or zone code
May 16, 2008 | Philips Televison & Video
Code for remote control of philips DVDR 3360D Hard disk / DVD Recorder
Also need to know what is the make and model of the universal remote you are using. Codes vary from one to the next.
If by chance your remote is Philips, the code for Philips DVDR's is one of the following:
0599, 0699, 1211
I have a Philips URC US2-PH5DSS and I use the code 0599 to control my Philips 3355 DVDR.
Apr 15, 2008 | Philips DVDR 3355 DVD Recorder
Blocked
The solution for this problem is on this forum here http://www.fixya.com/support/t353456-dvd_player
Apr 13, 2008 | Philips DVDR 3355 DVD Recorder
Phillips dvdr3305
switched dvdr off for 1 hour started up again dvd loaded pressed open draw and dvd come out
Feb 12, 2008 | Televison & Video
Phillips DVD Player / Recorder
Slot under front edge of player will allow you to eject by sliding lever with a small pointed object
Nov 03, 2007 | Philips DVDR 3355 DVD Recorder
TV, Sky, DVDR, VCR + Wii connection
i cant see any problem with the connections. have you tried to connect the dvdr along with sky to another tv set? and did the same problem occured? if not, try connecting it the same way with another tv. and see if thesame problem would occur. if the same problem appears check if the connections from sky to dvdr scart if it is loose or not. try to clean the solid wire of the cable. if proble still persists dvdr is faulty. if not, defenitely there is a problem with the tv. and i suggest for you to have it checked.
Oct 06, 2007 | Televison & Video
Philips DVDR 3355 DVD Recorder Logo
112 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
