Question about Pioneer PRO-510HD 53" Rear Projection Television
Pioneer PRO-530HD I had a lighting storm lastnight and My television won't come on..everytime i try and cut it on the red power standby light keeps flashing could someone please tell me this is not a major problem.
    President:
  • 3,130 Answers
Its really hard to say if its a major problem or not. I think anytime a circuit part goes bad thats its a major problem, because these sets HAVE NO USER REPLACEABLE PARTS inside so you should call out a trained technician, as theres alot of High Voltage inside these sets and also this is not a place for an experimenter or a handi-person to be messing around in. Your problem if you are a tech and Know the HI voltage saftey issues is most likly in the standby or main power supply... Good Luck
Posted on Aug 05, 2006
NEED OPERATING MANUAL FOR PIONEER ELITE PRO 530 HD TV
both may be a little hard to find anymore, the main problem is dead set and that is bad soldering all over the giant power supply board this set uses.
Sep 02, 2012 | Pioneer PRO-530HD 53" Rear Projection...
Why lights won't turn off after a lightning storm last night?
The light switch is defective replacing the switch should solve the issue.
Aug 09, 2012 | Televison & Video
What's your problem?Pioneer PRO-530HD 53 in. Rear Projection Television flashing red standby light
This and a few other models like it have one real common issue:
they develop from age and heat bad solder connections all over the power board (rather large board).
My experience with them is the fix usually is remove rear cover and follow power cord to power board (a lot of plugs to mark) and remove that board----then solder every single connection on the board which by the way has some special fuses on it.
Jun 14, 2012 | Pioneer PRO-530HD 53" Rear Projection...
Have a Pioneer pro elite 730hdi. When you try to turn it on (main power, not standby), the tv cycles from the red (standby) light with the normal click to the green light, then one second later, it cycles...
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hoping this will help in solving the problem....
Aug 09, 2011 | Pioneer PRO-730HDi 64 in. Rear Projection...
Pioneer 65" TV Model # SD-643HD5 won't power up.
I would suggest replacing the board itself, chances are what caused those fuses to blow is still faulty. did you check those fuses again after you powered it back up?
Jun 12, 2011 | Pioneer Televison & Video
Pioneer media receiver won t turn on
If the light on the media reciever doesn't come on then the power supply in that needs to be replaced by a service tech. If you disconnect the 2 cables from the media reciever and the panel and then try to turn on the panel it should light with red and green squares for a few seconds but will turn off as it needs the media reciever to be connected.
Mar 29, 2009 | Pioneer PureVision PDP-4340HD 43 in....
Pioneer elite pro-530hd tv---no picture at all!
I have a 532nd 53 that shuts off and red stand by lite comes on in the back. If you wait awhile and unplug it and plug it back in it will come on again and then shut off after an hour or two
Jan 19, 2009 | Pioneer PRO-530HD 53" Rear Projection...
Pioneer pro 99
thats usually a problem in the standby voltages not being correct. If you would like to diagnose this with help from a support tech you can get the service manual emailed to you after purchase at the following link and they provide free tech support to help you diagnose and repair the set. Heres the link.
http://servicemanuals.vstore.ca/
May 06, 2008 | Pioneer PRO-200 60" Rear Projection...
Power problems with PRO-530HD
do you know what the pix look like be for it whent dead?
some time bad solder can do this. in the center of the board
thear is fuse that go bad because of bad solder on stk 392-120 or 110 on the conv. pcb the fuse is 5amp 125v you have about 3 of them on the def pcb. to ch them. to hit the flyback&hozoutput
ch cap.s in power supply.
Mar 30, 2008 | Pioneer PRO-530HDi 53" Rear Projection...
Pioneer PRO-510HD 53" Rear Projection Television Logo
136 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
