I have a brand new samsung diamond drum top loader..it will not drain what would the problem be
Could you please tell me why my new top loader samsung diamond drum washer wont drain
SOURCE: NEW SAMSUNG WASHER WONT DRAIN.
Try clean debris filter locate in front of the machine.
Posted on Jun 23, 2008
  • 156 Answers
SOURCE: best way to drain washer to check pump or hoses
broken lid switch usely the call what kind top loader is it
Posted on Feb 27, 2008
  • 4 Answers
SOURCE: maytag washer wont drain
You most likely have a bad drain pump.
  • 66 Answers
SOURCE: ge top loader washer agitator does not work
To check the agitator. Start the washer into wash cycle. Once started Push down on top of agitator. If it catches some times or all of the time when pushing down, then then doggets are worn, under the agitator. You`ll have to remove the agitator to see these. If by pushing down on the agitator, nothing changes, Then you probably have a transmition problem. Check this and let me know what you find.
Posted on Nov 27, 2008
buffalonyman
  • 1865 Answers
SOURCE: MY LG WASHER WONT DRAIN, IT SAYS THE ERROR MESSAGE
OE is a drain error - Check there isn't a kink in your drain hose, ensure the filter is clean, the drain hose can become clogged with sludge, sometimes a hot wash with 1/2 a cup of vinegar will remove this sludge
Posted on May 06, 2009
Please how do I resolve error code UC on my Samsung diamond drum washing machine?
Washing machines have computers. They are literally designed for no ''DIY.'' Error code would likely mean ''new computer needed.'' Either way, you need a laptop with a factory testing program installed in it That's how these guys work nowadays. The laptop tells them what to do next, and you (and I) can't have one.
Aug 15, 2015 | Samsung Washing Machines
My Samsung 13Kg Top Loader WA13G7Q1 continuously drains out the water when the drum is being filled , what could be the problem
Either your in house drain pipe is too low or your drain pipe is down into the drain too far and this causes a siphon effect. Pull drain line up out a little at a time until it stops draining while filling. Good Luck!
Jul 28, 2015 | Samsung Washing Machines
Got a Samsung Diamond Drum WA80V3 after I put in on quick was and start it goes 22 minutes and when at 15 it goes toe rinse but then the machine just stop doing anything. Water still inside drum. Maks n...
The drain pump is either blocked or failed. Check the filter if it's clear then you are most likely up for a new drain pump. Here is a link to the part you need and a video on how to do it. Samsung DC31 00030E DRAIN PUMP B20 3 120V 60 NEW ORIGINAL
Mar 15, 2015 | Samsung Washing Machines
I have a Samsung top loader and even after leveling correctly as the spin cycle begins to spin faster, after the speed number nine the drum begins to bang all over the place then stop spinning. What c
You have an unbalanced load. This can be due to the amount of items in the drum or the type of items in the drum. Redistribute the items in the drum and restart. If this happens continually, you may have a problem with the drum dampening mechanism.
Jan 17, 2015 | Samsung Washing Machines
Kenmore 2600 TOP LOADER smells like Mildew. I can hear water sloshing around under drum. Is that Normal?
The drain on all washers have this issue. Unless the drain hose runs down hill, when the pump stops, water runs back into the machine that was in the hose but was not drained.
Feb 17, 2014 | Kenmore Washing Machines
8.0 kg wa10f4 samsung diamond drum
I NEED TO KNOW WHAT SHOULD I DO WITH MY SAMSUNG 8.0KG WA10F4 DIAMOND DRUM IF THE WATER FROM THE TUB IS NOT DRAINING..AS IF THERE'S SOMETHING STOPING THE WATER TO FLOW
Jun 02, 2012 | Samsung Washing Machines
WF218ANB noise like a bag of rocks being shaken.
This is a direct result of Samsung's Vibration Reduction Technology(VRT). There is a hoop at the front and the back of the drum holding 18 ball berrings in each hoop (36 in total). These balls use centrifugal force and automatically move to the opposite side of where the load is unbalanced and balances it out. It is only in the washing machines, not dryers.
Dec 16, 2009 | Samsung WF218ANW 4.0 cu. ft. High...
Washing Machines Logo
115 people viewed this question
Top Washing Machines Experts
