Question about Yamaha RX-V863 Receiver
Conecting plasma to receiver using hdmi lead
Hi guys
having a problem using my receiver. my playstation works fine but when i switch over to tv veiwing i cant get a signal. i have a LG60pg7 and a yamaha rx v863 running 1 hdmi from tv to receiver and 1 hdmi to playstation
thanks
adam
  • 86 Answers
If you receiver has a Aux function an is still unused try to hook your playstation audio rca up to it directly it will work either way, Hope thats what you mean, An Hope it works
Posted on Oct 23, 2008
I was using my ps 3 on my plasma tv connected by a HD lead. I then hooked it up to another tv using a scart lead and now it won't work. I hooked it back up to the plasma tv and it works fine. I need it to...
Got to settings in the PS3 Crossbar and go to display settings. The first one should say video output settings, click on it. It should say your connection type is HDMI. Select component/D Terminal and hit change. The screen should go blank. During this time plug it in to your other t.v by the scart. It should say "Can you read this screen?" hit yes and there you go. To go back to HDMI do the same.
Jan 07, 2011 | Sony Playstation 3 (PS3) Console
Hi guys I have a Phillips Plasma TV 42PF5521D/10 model UK version bought in 2008 Guess what untill now i only used the HDMI ports to connect a Home Media Center PC to watch HD content. So last...
hi First, remember the old HDMI reset tech tip. Unplug all HDMI cables (one end will do.) Then remove power from all things in play. No, not just turned off but remove the AC. Wait 5 to 10 minutes, hookup re -test thanks
shaun .
Mar 09, 2017 | Philips 42PF5521D 42 in. HD-Ready Plasma...
I have a Sony playstation 3 that I use as my dvd player and run it through my yamaha via an HDMI cable. I also connect the Yamaha output to the TV through an HDMI cable. Until recently the playstation...
Look in the manual for which version of HDMI. If it's 1.2a, they had a problem with the boards and were repairing them. Contact Yamaha @ 1-800-292-2982 Hope this helps
Jun 11, 2010 | Yamaha RX-V863 Receiver
Sony Playstation 3 + HDMI + Samsung Series 5 47"LCD Problems (tried all solutions i found) OK at my wits end now. Heres the testing I have done. Have the ps3 connected to the set using the av...
make sure ur not using both the av cable and the hdmi on some models it causes conflict although they are on different inputs. also did you try using a blu ray player or another ps3 on that hdmi port using the same cables or different cables? if another equipment work/don't work u can at least start to narrow down your problem..
Apr 27, 2010 | Sony Playstation 3 (PS3) Console
My PS3 wont display.
you could use the hdmi cable or the composite cable(like the old playstation one with the 3 leads but different colours,not red,white,yellow.)
both would be better for a plasma.
make sure your screen can utilise 1080 for hdmi.
if 720 or 480 use the composite cable.
Feb 27, 2009 | Sony Playstation 3 (PS3) Console
HDMI Input only reads Digital TV and not PS3 or AV Receiver
Well, I won't take the credit of others. Many people have the same problem as you do.
In the search box on the top of this page, put in " PS3 HDMI ". The one that has the 10 solutions so far has the best answers for you.
Good Luck
Feb 16, 2009 | Philips 52 In. LCD HDTV
Dvi connection to ps3
try to hold the power button for like 6 seconds until u hear a beep...
it will reset the display and adjust it to ur monitor...
hope this helps
Sep 20, 2008 | Samsung SyncMaster 940MW 19" LCD Monitor
DENON AVR 888
hi dennon guy
you need to connect all your components to your receiver then from the receiver to the tv via the monitor out at the back of your receiver.
you need to make sure they are all the same type of cables. ie if you are using hdmi then make sure the dvd is hdmi output to hdmi input of the receiver then the receiver is hdmi output to the input of the tv. This will give you the best setup.
of course if u use component cables then the same principles applies.
good luck
smeags
Dec 31, 2007 | Audio Players & Recorders
PS3 not working thru HDMI cable
Same happened to my ps3 one week from new , took it back the the shop and got a refund.
Oct 06, 2007 | Sony Playstation 3 (PS3) Console
No Video
have you gone through the menu to assign which signals the receiver recognizes?  I had to change the source when i switched to the Dish Network HD receiver.
Aug 24, 2007 | Pioneer VSX-1016 Receiver
Yamaha RX-V863 Receiver Logo
137 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
