Question about Salton FBL500SS 3-Speed Blender
Salton Blender I mistakenly used my blender on very frozen yoghurt and the grindin teeth on the bottom part of the 3 speed blender have lost grip and the grip ahs been grinded off, how and where can i get new part for this problem.
  • Wadzy Oct 23, 2008
    Will surely get i touch with hte manufacturer and let you knwo if it worked for me, thanks
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 150 Answers
Contact the manufacturer of your blender, if the manual is around look in the last pages.
Posted on Oct 23, 2008
Salton professional power blender manual
The Manual for the Salton Professional Power Blender BL-1051 can be downloaded from this link:
Apr 15, 2012 | Blenders
Where can I get replacement blade unit for Farberware/Salton blender model FBL500SS??
Available replacement parts for your blender are normally available online at the following site:
Unfortunately I do not see that a blade unit is available. I would recommend you contact this supplier directly to inquire whether a compatible blade is available.
Contact information can be found here:
Trust this is helpful. Thank you for using FixYa!
Jul 12, 2011 | Salton FBL500SS 3-Speed Blender
Seems like motor has lost power
This sounds like the black rubber coupler has broken. The teeth often get knocked off. Have a look at the part shown in hte pictures here:
Jan 22, 2010 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Can't loosen to wash blender .I turned to the right in direction of arrows Won't budge
Run the bottom plastic piece under hot water for a couple minutes and then put a dish towel over it so you can get a good grip, and turn 'CCW' (counter clock wise) to loosen.
Nov 05, 2009 | Breville BBL550XL 5-Speed Blender
Need replacement blade for Russell Hobbs hand mixer
go to this page and order what you need directly from Russel Hobbs.
Please mark this answer as a fixya! thanks
Mar 18, 2009 | Russell Hobbs RH-HB3 Handheld Blender
How do I change to clutch on this blender. The outside of the clutch broke off leaving just the screw head on the blender, when I turn to unscrew it, the entire piece just spins, any suggestions.
You can probably use a Vise-grip pliers to clamp down on the brass insert and unscrew it. Not only is it on very hard, but it is also threaded reverse of a normal screw. This is so it does not come undone in normal operation.
You have to turn it counter-clockwise to unscrew it (a regular screw turns clockwise).
I had to clamp the motor shaft real tight with a bench vise to be able to remove the clutch. Hope this helps.
Aug 14, 2008 | Cuisinart SPB-7 SmartPower Work Top...
Top part of base broke off
This just happened to me too, and I think I just fixed it.  First you have to get a replacement part called the "blender coupling" (I got mine online from Goodmans for $3.99).  I also replaced the square drive and slinger (two parts come together for $2.99)-that's the little part that sticks up and attaches to the pitcher.
Unscrew the bottom four screws of the base where the rubber feet are.  Remove the rubber skirt to reveal four screws that hold the motor in.  They are way in there so you'll need a long screw driver.  Remove the motor and unscrew the old coupling.  Mine had not been replaced since my grandmother bought this blender who knows when, so the coupling was really stuck.  I did not have a tool narrow enough to get a good grip to apply enough torque to remove the coupling so I had to try a few other tricks.  If your blender is the same, remove the bottom nut, fan blade and two washers.  This gave enough of a rod to grip to get the old coupling off.  (I also had to use some WD40, and heat and cool the coupling a few times to break the old seal).
Good luck!  Hope that helps!
Jan 09, 2008 | Oster 465 Work Top Blender
Salton FBL500SS 3-Speed Blender Logo
221 people viewed this question
Top Salton Blenders Experts
Are you a Salton Blender Expert? Answer questions, earn points and help others
