Question about HP LaserJet 1320n Printer
There is no power in my hp 1320 laser printer after being serviced
We serviced the printer and there after, when we powered the machine could not power on.
Check all the connections inside maybe some connectors are not plug in
Posted on Feb 09, 2012
SOURCE: HP LaserJet 1320 lights
hi there andy u will find your harraness from u formatter board has beeb broken or one of the plugs arnt making contact on the baord only to solve the problem is to trace everypoint out to find the break and then replace that cable link
Posted on Dec 07, 2007
ctf1800
  • 4402 Answers
SOURCE: I want to install my hp laser jet 1320
http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=us&cc=us&h_page=hpcom&h_client=S-S-R295-1&h_pagetype=s-002&h_query=hp+laser+jet+1320&submit.x=4&submit.y=7
Posted on Jan 15, 2008
  • 58 Answers
SOURCE: My Hp laser Jet 1320 is printing fent text
On the settings for the printer check for the clean option. Click clean and the printer should clean itself.
Posted on Jan 16, 2008
SOURCE: hp 1320 driver
Go to HP.COM to the drivers and support tab, search for your driver and download
Posted on Apr 25, 2008
SOURCE: HP Laser Jet 1320 Printer installation
Just downloading the PCL5 driver was not enough for my computer. Maybe it is enough for other users' computers. But in addition to downloading the drivers, i had to also download and install the "HP Laserjet 1320 plug and play print driver solution" at the bottom of the driver list. Save the file to your desktop, double-click it and follow instructions to install, then reboot. Then when I checked my printer list, the HP Laserjet 1320 was there. I printed a test page, and now i am good to go. Hope this helps.
Posted on Jun 13, 2009
Hp 1320 printer not showing any signal light (what is the problem)
have you check the power source? if there is no light on the machine you have to bring out the power supply to test the fuses.
Apr 22, 2013 | HP LaserJet 1320 Printer
How to install hp 1320 ppd for postscript printer (PS)
Just install Postcript Driver for Hp LJ 1320 in your PC.
Available in Hp Page.
Jul 01, 2011 | HP Laser Jet 1320 Printer
Can't install hp 1320 printer
Hi downward_man,
Here's the instruction on how you will install your HP Laser Jet 1320 Printer:
1. Access the HP hardware support site to retrieve the HP LaserJet 1320 driver download.
2. Click the link that represents your computer's operating system.
3. Scroll down the page, and click the "Download" action, below the "Driver - Universal Print Driver" table. Opt to save the driver, as the download file has the setup application that is needed to install it.
4. Double-click the setup application's icon from its new file location on your hard drive. The HP installation application will open automatically.
5. Click "Next" to proceed to the first installation steps.
6.Select all of the HP recommended installation options, and click "Next" to begin copying the driver's files and components to the computer.
7. When the HP installation wizard asks, plug the HP LaserJet 1320 USB sync cable to the USB port, located on the back of the printer hardware. Connect the other end of the cable to an open USB port on your computer.
8. Click "Finish" to complete and conclude the HP LaserJet 1320 series driver installation process.
Hope it helps.
Thank you for using FixYa.
Jan 27, 2011 | HP Laser Jet 1320 Printer
Paper jam in hp laser 1320
Unplug the power cord and open the cover and remove toner and try to look I inside around the roller and try to manually roll the roller and if you can see the paper try to pull is slowly.
Have a nice day and do not forget to rate please...!
Feb 10, 2010 | HP LaserJet 1320 Printer
How do I clean the rollers on my laser jet printer, it prints with a long black strip in the middle of the page. Hp laser jet 1320
Most likely the heat roller is breaking down in the fuser. The fuser must be replaced. But before going that far, replace the toner cartridge, as it may have a bad cleaning blade. 85% of all print quality defects are cartridge related. This particular model of machine has a very brittle heat roller that more often than not wears out prematurely. This is true across the board for all of the newer HP low end laser printers unfortunately.
Sep 30, 2009 | HP LaserJet 1320 Printer
Hp laser jet 1320 stop printing
Try unplugging the power cord and plugging it back in. Check to make sure that there are no paper jams or foreign objects stuck in the rollers. Reseat the toner and make sure the lid is firmly closed.
Jun 19, 2009 | HP Laser Jet 1320 Printer
HP laser jet 1320
I NEED HP LASER JET 1320 PRINTER DRIVER FOR WINDOWS XP.
POSSIABLE TO URGENT REPLAY PLS
SUMONJS@GMAIL.COM
Feb 09, 2008 | Office Equipment & Supplies
Dec 07, 2007 | HP LaserJet 1320 Printer
Laserjet 1320 will not pick paper
Paper misfeeds and failure to pickup the paper are both common symptoms of a worn pickup roller. This roller is on the bottom of the printer as shown in the attached picture.
With use the rubber tire gets smooth and can't grip the paper enough to pick it up and push it into the printer. The roller kit is easy to install yourself and will get the printer back going as good as new. You can get the roller kit here:
http://www.ccl-la.com/catalog/product_info.php?cPath=24_41_42&products_id=71
I hope this helps, if so please rate my solution.
BuddyMc
Dec 05, 2007 | HP LaserJet 1320 Printer
HP LaserJet 1320n Printer Logo
42 people viewed this question
Seeker5211
Seeker5211
