Question about Refrigerators
Refrigerator starts cooling mainly when I open the door
My refrigerator does not seem to be cooling properly. It is a 253 series side by side by Kenmore, made by Frigidaire. I noticed that the frig & freezer were warmer than usual this morning (refrig was at 40 degrees). I have a feeling that it hadn't cooled all night long, until after I had opened the door a few times. This is not the first time I have noticed this. I have had freon added, replaced the defrost timer and the defrost thermostat. It is not freezing up on the coils. I don't know if it waiting to turn on until I open the door is normal or not, but the frig seemed a little too warm to me, but it cools fine when the fan kicks in.
  • 77 Answers
Put a thermometer in both the freezer and the fridge. Fridge should be around 40F if not a little lower, but should stay above 30F.
Freezer should be just below 30.
Posted on Feb 09, 2012
herodog909
  • 98 Answers
SOURCE: Frig will not cool
I had a similar problem. One thing that I need to know is is it cooling at all? If everything is operating, but no cooling occurs, you may have a bad board. This controls all of the components. Getting it replaced could be pretty pricey. Good luck, and please rate.
Posted on Jun 18, 2009
Sea Breeze
  • 4655 Answers
SOURCE: my side by side maytag refrig only cools to 60
Your refrigerator has an Adaptive Deforst Control located in the control panel inside the fresh food section part number 61005988 is is the most likely reason for your trouble. Picture #13 below.
Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
Posted on Jun 25, 2009
SOURCE: how do you replace the defrost heater in a ge frig
I have a GSH 22JSTC SS that has a frosting problem. After a series of hairdrier sessions and conversations with the know-nothings at GE service help, I took out the defrost heater and noticed it had burned out. I bought another one and after a few days, that too burned out. (all black like a bad light bulb). What is my next step? Testing the Thermostat? Could this be a timer issue? Where is the timer located? Any imput is greatly appreciated. I am one frustrated GE owner. Thanks
Posted on Jul 21, 2009
Sea Breeze
  • 4655 Answers
SOURCE: my frig is running but not cooling - frig is 50
I can help you diagnose the problems with your GE. Several things can cause these symptoms. All you need is a voltage meter patience and a want to, to repair and do it better than a paid technician. In most cases with the PSS26MSRSS the defrost heater is the cause for this. Look into rear of your freezer and back wall. Is Ice or frost building on rear wall? If yes unplug and prepair to remove contents in freezer compartment. Remove rear panel in freezer and use hair dryer to defrost ice until the defrost heater is visible. BRB , Sea Breeze
Posted on Jan 23, 2010
Testimonial: "Thanks for the quick help - yes frost on back wall. Once I unload and defrost should I then take out defrost thermostat? "
  • 132 Answers
SOURCE: 1 month old whirlpool refrigator is almost 60
It sounds like one of two things, either the evaporator fan is not running(fan in the back of the freezer behind lower back panel) or the bi-metal thermostat that may be in series with it is open..
Also some newer models use a lower voltage fan motor, use to be all were 120 volts........
It is under warranty for one year so call for authorized service to repair it......
(all of the cooling on the refrigerator side is done by air circulating from the freezer side, also possible there is ice blocking the air flow somewhere)
hope this helps
Posted on Feb 11, 2011
My 18 year old refrigerator GE model TFX24FG freezer side is not keeping food frozen. Refrigerator side seems to be working normally.
The refrigerator side is at present working properly , but slowly slowly, it will also loose its cooling.This will happen because, freezer side is the side which cools first, then the refrigerator side ( also called as fridge side)., gets cooled.If freezer side is not cooling / freezing properly then fridge side will also loose its cooling ability.------------ And later on both section will loose its cooling.----------- As per the present situation, it indicates problem with compressor or problem with freezer side door not closing properly.---------- Or the temperature in freezer section is not set to proper cooling/ freezing.--------- So first inspect temperature, is it set right? If ok, then check the freezer door , is it properly closed? If ok, then its compressor problem.? The compressor is running non stop, this is indication of compressor problem.---------- Click this link below for more help:--- http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html ----------- Later on both section will loose its cooling. -------- This will help.Thanks.Helpmech.
Aug 19, 2011 | Refrigerators
Refrigerator and freezer were working properly before an extended vacation. Cleaned both refrigerator and freezer, unplugged, and left doors open. Upon return plugged in and have waited 72 hours. ...
Let's think this through a bit....
You say it is cooling but it seems too quiet.... is the compressor runing but the condenser fan is not??? that would make it cool but not cold and also make it more quiet...
If both compressor and condenser fan are running... is the evaporator fan... the one inside the freezer running? That also could cause the same problems...
Is the compressor running all of the time??? or is it cycling? if it is cycling then it could be a t-stat or sensor problem....if it is not starting properly it may be a capacitor/relay problem...
These are alll things that you can easily check yourself....
If they all checkout... then the unit may have a small refrigerant leak and just will not cool enough now to catchup from a earm condition....
To check that out you would need a tech. to attach gauges to the system and check the charge...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 04, 2010 | KitchenAid Superba Architect KSCS25INSS...
MODEL GLRS264ZA WILL NOT COOL
Hello.
If your refrigerator cooling doesn't seem to be working well, and you have no idea what to look for in troubleshooting your problem, there are some things you can do to try to figure out your problem without paying a serviceman to come into your home.
Freezing
Most new refrigerators come with automatic defrosters. Although this is a standard feature the drain hole in the defrosting assembly can get clogged with debris, lime, or even ice. If this happens the defrost will not work and there will be a build-up of ice in your freezer that begins to block the freon from flowing properly and causing heat to react improperly and cause your refrigerator to stop cooling.
Freon
Freon systems in a refrigerator are closed systems but on occasion you may need a recharge. Refrigerators use R-134a freon, just like in an automobile. The old R-12 freon is no longer available, so if you have an older model of refrigerator you will not be able to obtain the freon, and it will be recommended that you replace that refrigerator.
Seals
The seals that are on the door of the refrigerator and freezer can dry rot with time. When you begin to see the seals cracking or warping, if your refrigerator opens more easily than before, or if you see the the door does not close fully without pushing on the door then the gaskets around the doors will need to be replaced. They are held in place by clips and the replacement is an easy fix.
Holes in Lines
Let's face it, many people find ice in their freezer or the back of their refrigerator and will try some self-help without knowledge. They will grab a knife or fork and start chipping away at the ice. This is extremely dangerous. There is a great risk of puncturing a hole in the freon lines by stabbing at the ice. Since freon has the purpose of cooling most ice collects the thickest on the inside of the walls with the freon lines right behind the plastics. A better method of removing the ice is to empty your refrigerator, turn it off and leave the door open. If you want to speed up the process you can turn on a blow dryer and aim it at the edges of the ice. If you aim at the edges you will warm up the ice and create warm water which will flow down and help to separate the ice panel from the wall.
Uneven Refrigerator
If a refrigerator is not even on the floor it may not close properly. Rock your refrigerator and see if it seems to topple from one foot to another. The feet on a refrigerator can be adjusted by screwing in or out and leveling each foot individually until they are all even.
Non-Problem Warming
If your home is hot your refrigerator will work harder. If you put a lot of food in your refrigerator and freezer, your coolant will have to work harder, and it will seem to take longer to cool. It is just that there is a lot of food that is trying to freeze or maintain cool temperatures.
Take care.......
Aug 15, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Refrigerator won't cool
MUST DEFROST LEAVE IT OFF FOR 24 HOURS .
Apr 07, 2010 | Kenmore 57029 Side by Side Refrigerator
Our Kenmore refrigerator, Model 253. 6480240C doesn't cool.
I doubt you have a loss of refrigerant if the freezer is fine. Typically, the freezer would be more like a fridge with this condition.
So a couple things to check.. First, open the freezer door. There is a tunnel in the middle of the back wall. Can you hear,or feel the fan motor blowing air? If yes, then open the fridge door and feel in the top back where the tunnel is there will be two holes at the lowest part and you should feel air coming out.
look at the vents on the back panel. can you see through them? or is it all frosted over? If so,you have a defrost issue.
Feb 02, 2018 | Kenmore Refrigerators
Refrigerator seem to not cool to the proper
your problem is in hte freezer area open the panel in your freezer you might need a new heat element or a new thermostat unit... not so bad to do or check...
arik from 911.servicetoday.com
Nov 06, 2009 | Kenmore 53092 / 53094 Side by Side...
I have a frigidaire gallery series frig side by side with ice and water in door. The frig part won't stay cold. It also seems to take long time to make ice. The frig part works ok for awhile and then...
Check for two things. Look under the refrigerator and make sure the compressor fan is turning.
Second, check inside the freezer for proper operation of the fan that moves cool air throughout the freezer and refrigerator. If this fan is working, you can probably hear it. It should be behind an access plate in the freezer (near the top). Remove the plate and look at the fan. If it's not turning, you will have to replace the fan motor.
Oct 17, 2009 | Frigidaire FRS23KF7AB Side by Side...
253 55682402 Kenmore Side by Side Refrigerator Not Working. Freezer is not freezing and the fridge part is not cooling properly. Also water to ice maker and instant water in front of door stopped working....
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Aug 21, 2009 | Refrigerators
I found y GE Side by Side refrigerator door open
i have a kenmore side by side refrifgetator , model 253 5627240p. ice make is not makin ice. I can get water from fridge but no ice. i need help asap.
Aug 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
107 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
