Question about Jenn-Air Cooktops
Code fi-7 jenn air model jes9800acw
Code f1-7 cannot use anything to do with the oven or touch pad
2 Suggested Answers
Eddie Rentas
  • 59 Answers
SOURCE: Code f-7 displays and it is beeping
Hello
Mam here is the brochures you need just click on them.
Eddie Rentas
Tupper Lake NY
Posted on Jul 26, 2008
After cleaning f1 appears on display
This means the oven lock is activated. The cook top touch panel is likely causing some problem.
Try to press the child lock button and see if F1 goes off. Otherwise the control panel will need to be replaced.
Oct 18, 2011 | Jenn-Air JED8430 Electric Cooktop
F1-8 error
F1 indicates a clock or touch pad problem. F8 indicates a clock, or ERC (Electronic Range Control) problem. Are you receiving both codes? If so it seems likely that your touch pad and ERC are contained together in one module, and must be replaced. If you find however that they are separate modules it is possible to determine which is faulty by simply disconnecting power to the unit, disconnecting the touch pad from the ERC, and then powering it back up. Wait for a half hour or so to see if the unit sets the error code again with the touch pad disconnected. If it does the ERC is faulty, otherwise it is the touch pad.
Please note that if you do not have experience mucking about in your appliances inner workings it is best that this be done by an experienced technician.
May 12, 2011 | Jenn-Air Cooktops
My schott ceran class top stove keeps saying F1 on it and don't no how to fix it
Here below we have aprocedure to try to see if you can save the ERC.
F1 touch pad / ERC test
This simple test will help determine
whether the ERC (Electronic Range Control or Clock) or the touch pad is
defective when F1 error code is present.
Note: Some models
incorporate the touch pad in to the ERC as a single assembly, in which case this
test is not necessary. Simply replace the ERC (Clock).
Warning: If
you feel in any way uncomfortable performing this test or making this repair,
please contact a qualified appliance repair technician.
1. Disconnect
power to the range (unplug the range power cord or turn the power off to the
range at the circuit breaker). It is very important that the power to the range
has been disconnected, so please double check before continuing.
2. Gain
access inside the control panel.
3. Disconnect the touch pad (also called
keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no
lose wires, or anything else that may cause a short when power is turned back
on. Assemble the control panel back the way it was.
5. Turn the power back
on.
6. Wait for at least one hour to see if the F1 code comes back (usually
accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it
does not, replace the touch pad.
Dec 15, 2010 | Cooktops
Jenn- Air cook top oven sve47500b has error # F7 and the oven will not work
F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC).
Oct 25, 2010 | Jenn-Air JED8430 Electric Cooktop
OVEN ERROR CODE F1
F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information.
Oct 09, 2010 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Ge monogram cooktop model#zeu30rsf1ss error code f1 74
Hi There
I have found the codes that you need and hope this helps you.
F1 Stuck touch pad Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be cancelled, replace the oven control (also called clock or ERC), touch pad, or both.Thank You for writing to fix ya.
Best Regards Richard
Feb 18, 2010 | GE Monogram ZEU30R Electric Cooktop
I was given a jenn air stove and we plugged it in and it wont stopped beeping and it says F-7. How can we get it to stop?
Unplug it. Or replace touch pad (55% chance) or main board (45% chance). You can test it be disconnecting the touch pad and see if it keeps beeping, then it's the board.
Jenn air oven repair in orange county, ca
appliance repair orange county, ca
Feb 07, 2010 | Cooktops
Message f 7
Hi There
I found the fault codes for you and i hope this will help you.Let me know when you can.
F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or attempt to un-stick buttonThank you for writing to fix ya.
Best regards Richard
Dec 11, 2009 | Jenn-Air JED8430 Electric Cooktop
-F1-
F1 for Magic Chef means there is a problem with the control board or the touch pad to the board.  I would need the entire model # on sticker on the oven to see what parts are on this one.  If the touch pad is separate it will have a ribbon that goes from it to the board.  Unplug that ribbon, if the code goes away then the touchpad is the problem.  If the code stays with the ribbon unplugged then the control board is bad.  Make sure power is off to unit when touching anything!
Oct 12, 2007 | Cooktops
Pitted glass cooktop in Jenn Air Model JGC9430ADS
Did you find anything out? We have had our Jenn-aire gas stove for 1 1/2 years and just noticed today that the surface has bubbled in a spot??? I did clean the oven last week.
Sep 10, 2007 | Jenn-Air JGC9430ADS Gas Cooktop
Cooktops Logo
37 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
