Question about GE Refrigerators
G.e. model STS15AbRFRWW refrigerator
G.E. Select refrigerator model STS15ABRFRWW, the freezer works, but the refrigerator isn't cooling. What is the problem? We have defrosted several times.
  • 7 Answers
SOURCE: freezers cold but refrigerators warm
see if there is a big block of ice on the back plate in your frige, if there is then your thermostat is set to cold or broken. if no ice in the frige then it has a gas leak!
Posted on Apr 19, 2009
  • 363 Answers
SOURCE: model #RB2155sh. Refrigerator will not cool.
sounds like the evaporator fan motor is wearing out. This problem is very hard to diagnose because the fan still spins, But it does not spind fast enough to circulate the chilled air thru the freezer and refrigerator. The minimum cost labor and parts is around $300.00. If you try and repair/replace the fan motor yourself, You can find the motor for thaat fan for around$80.00, But this doesn.t count the cost is the other components are worn out,(blade, noise arrestors, mounting bracket). I would let a serviceman make this repair because reaching the electrical connection for the fan is labor intensive.
Posted on Jul 30, 2009
  • 2341 Answers
SOURCE: Maytag MZD2766GEW side by side refrigerator fridge not cooling
you have a defrost problem, could be bad adaptive defrost board,t-stat heater,when you open freezer door listen for fan if fan is blowing check the t-stat,look at it and see if it has a buldge on it,sometime you can see this and tell it's bad,you'll need a meter to read out the heater and other parts to see whats bad,might be a good idea to call a tech to do this,when you find problem you have to melt everything out again
Posted on Oct 31, 2009
mgprice
  • 744 Answers
SOURCE: Freezer side not defrosting. Refrigerator cooling.
Hi, With the information you supplied I’m going to assume there is an ice build up at the rear of the freezer. Your problem is going to be with your defrost system. I will also assume you have the ability to repair this yourself.
This is going to be one of three problems with your refrigerator, 1st thing to do is remove shelf’s and panel in the back of the Freezer. You may see ice build up on the evaporator, don't worry get a hair dryer and melt the ice.
Next locate the wires for the defrost heater and using a multi-meter/ohms meter test the heater for continuity (it should read infinite) if the defrost heater is bad replace it.
This is what a typical defrost heater looks like:
If the heater is good test the defrost thermostat. This should normally be done when the evaporator is still covered with ice since it will only activate at 40f - 50f depending on the thermostat. When tested with the ohms meter at below 40f it will read infinite. It is normally clipped to the upper right of the evaporator and look something like this:
e5bc839.jpg The next possible problem could be the defrost timer. If you have tested the heater and thermostat and they have tested good next find the defrost timer, If your refrigerator has a mechanical one it will either be located inside the control panel in the fridge or behind the panel below the doors. Once you have located it advance the dial until you hear a click. This will initiate the defrost cycle. If your heater begins to get hot this will tell you that your timer has stalled and needs to be replaced. A typical mechanical timer looks like this:
1742d10.jpg If your refrigerator has a digital defrost timer you should locate the tech sheet. Normally you can find this behind the panel under the doors. It will tell you how to initiate a manual defrost cycle. As before if the heater gets hot you will have to replace the mother board normally located behind a panel at the rear of your refrigerator.
If your fridge is warm and there is no build up of frost/ice on the back panel inside the freezer then you problem is most likely going to be the evaporator fan, have you heard the fan running in the past few hours? if you are not sure pull the panel out to where you can see fan and watch it over the space of an hour to see if it turns. If you don’t see it turning replace the motor. This is what a typical evaporator fan looks like:
Hope this helps. If you have any other questions please feel free to comment again. If you decide to get a repair guy in should not cost you any more then $120 - $200 depending on make/model/problem Good luck! Mike
Posted on Dec 02, 2009
  • 35 Answers
SOURCE: model # bx2255w Amana Refridgerator bottom
If you have high humidity or the door gets opened a lot, the evaporator coil may need a good defrosting. There are defrosting devices in the unit like the timer, heating coils, thermostats that could be bad. There should also be a small fan in the freezer that transfers the air to the refrigerator section. If that's not spinning only the freezer will work.
If you find the fan and it's working you can do a thorough manual defrost by removing the food, unplugging the unit and letting it set for a day with the doors wide open. Have some big towels handy :)
After a day, plug it in and see what it does (don't add food, yet). If it cools down then you will know that the compressor is still good and it's worthwhile to fix.
Easy fixes: Timer and fan.
Moderate fix (cheap part - more labor) - Defrost thermosat
Pain in the **** fix: Defrost heaters.
Ed
Posted on May 22, 2011
Freezer side seems to work but the refrigerator side isn't
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Sep 11, 2011 | Maytag Refrigerators
My refrigerator freezer is working but my refrigerator isn't
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 30, 2011 | Microwave Ovens
Freezer works great but refrigerator. Doesn't get cold its cool but not cold turned thermostat to 33 and ut isn't gettingcold
heatman101
Aug 21, 2011 | Kenmore Side by Side Refrigerator
I have a sharp refrigerator - freezer. SJ-48L-SL1 The freezer is colding but the refrigerator section isn't.
heatman101
Jul 26, 2011 | Refrigerators
My refrigerator isn't cooling. The freezer is working fine though. Any suggestions?
heatman101
Jul 07, 2011 | Refrigerators
Freezer appears to be working, but not the refrigerator section - at most that will only get to 50 degrees. Manually switching to propane makes no difference.
Sounds like your cooling fan is out. If the freezer is fine and the fridge isn't, then the cooling fan isn't blowing the cold air the the fridge. Or you could have ice obstructing the airflow.
Jul 01, 2011 | Refrigerators
I have a GE Model GSS22SGRF refrigerator. The freezer is cold but the freezer isn't staying cold. Any suggestions?
heatman101
May 23, 2011 | GE Refrigerators
Hi the fridge side of my side by side isn't working. The freezer side is still working. Any ideas?
heatman101
May 14, 2011 | Maytag MZD2766GES Side by Side...
Refrigerators Logo
252 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
