Question about RCA D52W19 52" Rear Projection Television
Tv conversion how do i have it done?
  • jack43 Nov 28, 2008
    yep , thats what i had to do , and they fixed it right there
    three hundred bucks! for what took about a hour
  • 905 Answers
You will have to find an electronic repair shop near you and see if they will come and get the main board out of it or they will fix it right in your house in about an hour or so
hope that helps
electech
Posted on Oct 23, 2008
How do i connect marantz rs2252. To tv
Do you have an audio out or headphone jack on the TV? If not you'll need a digital TV tuner converter box that does. If you remember, these are the "digital conversion" boxes the government provided when the USA switched from analog to digital TV. They sell for $50 - $60, have a input for TV system (antenna, cable, etc) and analog outputs that will connect to your Marantz via the "Aux" input. Purchase shielded "RCA male to RCA male" connection cables at Radio Shack, connect "Audio Out" from converter box to "Aux In" on Marantz and you're done.
Mar 28, 2015 | Marantz Audio Players & Recorders
How do i convert video files to mjpeg for magnavox tv
Hi Anonymous.
You can watch the converted files on your tv, in fact any tv, provided that it is equiped with video input(s), be it Scart or a separate video input by RCA connectors.
Your files can be played in a DVD player, or in any player equiped with a USB input. (files burnt on a disc, or on a USB stick.)
Conversion should be done on a computer. There you need conversion software, which you can download from the net, and installed. http://download.cnet.com/Any-Video-Converter-Freeware/3000-2194_4-10661456.html
This is one of the many free convertors you can find. I guess you're familiar with the procedures to be followed.
Good luck and best regards. F.Baeteman Belgium.
Jul 31, 2014 | Philips Magnavox 20MT133S 20" TV
Rinnai granada MKII
The conversion requires new jets in the unit and readjustment of the air /gas ratio shields. Use a qualified gas specialist for the conversion .
Jun 11, 2013 | Heating & Cooling
How to remove tv from explorer conversion van?
That is one problem with an after market conversion. If you know who did the conversion, you can contact them. If not look for screws that are present on the base of the set. Be advised that the aftermarket install might use non conventional methods of using fasteners.
Feb 12, 2013 | Cars & Trucks
Power supply wont start
you have to do some alteration for the supply. The conversion can be made with the help of step up transformer (110 in 220 out). This kind of transformer is available in the market. This can only be done by some expert in this field. If you are a technical person and can handle this kind of issue then do it yourself otherwise get it done with the help of expert technician.
good luck
Jan 31, 2010 | Samsung TXD1972 19" TV
Since conversion TV not working
If you are using a rooftop antenna or "rabbit ears", you will need a converter box.
Marco
Jun 17, 2009 | Toshiba MD20P1 20 in. TV/DVD Combo
Color Gun Help?
this tv will need some testing to determine the exact cause but most likely it will need a conversion done, you will need to call your local repair shop to come out and fix the problem
sorry about your tv
electech
Oct 26, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Screen has 3 lines at the top
you need to get a conversion done to correct this problem
Oct 20, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
GRRRR.THIIS TV!!!!!!!
First thing to check is the onscreen menu, does it have the pink tint? What about when you watch a DVD? If so, the problem lies within the TV. If not, this maybe a problem with cable/satellite input. Cables can degrade or have cracks that can cause poor results. I would try another set of cables. You have to determine if it's the TV, the signal or the cable/satellite receiver, if one is in use.
Is Orion TV model 1929 ready for Feburary 17, 2009 Digtal conversion without the converter box ?
is the model number correct? Can't find the details of your television.
Does your tv use digital input? or analog if its analog then you need the box.
May 04, 2008 | Televison & Video
RCA D52W19 52" Rear Projection Television Logo
22 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
