Question about Western Digital Protege WD400EB 40 GB Hard Drive
What are the jumper settings for western digital velociraptor 6 Gb/s hard drive
SOURCE: western digital hard drive
I have a WD800BB.
Jumper settings starting closest to the power connector.
CS for Cable Select
SL for Slave
MA for Master
The last two position are not marked.
Hope that helps.
Posted on Mar 19, 2008
nick_helpap
  • 334 Answers
SOURCE: western digital hard drive 500gb
do u just wann wipe it out u meen ? then right clik on it in under my computer formatt it cheak quick box for that hard drive
Posted on Oct 06, 2008
geraldo14200
  • 48 Answers
SOURCE: Maxtor Internal EIDE hard drive dip switch settings.
I assume you have two IDE controllers? IDE1 and IDE2, I'll try to help, the primary HD needs to have the pin set to primary and the secondary set to slave, if you're running both of these drives off of the same ribbon cable. You may have to go into your BIOS settings and check to make sure the Primary HD is the WD drive.
Posted on Apr 06, 2009
  • 788 Answers
SOURCE: I have a Western Digital Wd2000 hard drive 200 GB
The 20 GB drive will be Master and the 200 GB will be slave. If you are using one cable, you can use the cable select setting.
If you are useing two cables, one must be set as master and the other set as slave.
Posted on Sep 04, 2009
  • 509 Answers
SOURCE: my western digital wd800bb caviar, has no label
Set the jumper like this for a secondary hard drive...
Posted on Jul 09, 2010
What is the nutral position sinle jumper settings
Jumper Settings: The Western Digital hard drive is factory set for single drive installation. Western Digital hard drives are shipped with a jumper in the neutral storage position (across pins 5 and 3) for future dual drive use. If you are installing the Western Digital hard drive as the only hard drive in your system, leave the jumper in the neutral storage position. Jumpers are not required for single hard drive installations.
For more information visit this link http://support.radioshack.com/support_accessories/doc33/33085.htm
Apr 25, 2015 | Western Digital CaviarĀ® WD400BB 40 GB...
Western digital wd2500bevt slave jumper settings
SATA drive position is determined by the plug on the motherboard, not a jumper. Jumper settings are for PATA drives (much older).
Feb 06, 2014 | Western Digital WD Scorpio Blue WD2500BEVT...
Velociraptor SATA2 Jumper
Hello, you don't say what you want to know, but read this info at the following link as it might help you:
http://www.techarp.com/showarticle.aspx?artno=590&pgno=4
Regards, nicam49
Feb 14, 2012 | Western Digital Velociraptor 600Gb 35 Sata...
Drive spins but cannot access via os
try to check your hard drive from Computer Management..
Maybe the hard drive are not yet partitioned..
Thanks...
Aug 19, 2011 | Western Digital VelociRaptor (WD1500HLFS)...
How can I clean boot record password
You have to clear this in BIOS. Power off you PC, change jumper on motherboard for you specific board (Have to look it up) place jumper setting where indicated 5-6, 6-7???, power on PC, at beep remove jumper and place back on original jumper setting. This should clear passwords.
Jan 11, 2011 | Western Digital Caviar WD400AB 40 GB Hard...
How do set the jumpers on the HD to slave ? thanks
you can find the jumper settings printed on the top of western digital caviar hard drives
slave setting with the hard drive end jumpers facing you is 2nd from the right or 4th from the right
good luck
Aug 28, 2010 | Western Digital Caviar WD400BB 40 GB Hard...
Need to know what is jumper setting for cable select on all western digital hard drives
Welcome to Fixyah,
Jumper settings procedure will located at the front of that disc and it will show where the jumper setting was located. I suggest to you to go ahead and check it out.
Aug 11, 2010 | Western Digital Caviar WD400BB 40 GB Hard...
Jumper settings
check this official web of western digital...
http://www.wdc.com/en/products/legacy/Legacy.asp?Model=WD400EB
Aug 19, 2008 | Western Digital Protege WD400EB 40 GB Hard...
Western Digital Protege WD400EB 40 GB Hard Drive Logo
312 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
