Question about Kenmore 50522 / 50524 Side by Side Refrigerator
Water filter for kenmore coldspot model 58282892
  • 172 Answers
SOURCE: Kenmore Coldspot w/Ice Maker Not Making Ice
hi LOP7,
In most cases you can easily solve this problem.
step one would be to make sure your freezer is getting cold enough. If you have icecream in your freezer is it frozen solid or is it soft. Most icemakers cycle around 0 degrees and if your freezer is not getting to 0 then it will not cycle and it will not make ice.
Step two would be to make sure you icemake is cycling. To do this simply lift the little shut off arm on your icemaker and wait about an hour then go back to the icemaker and drop the arm down. The icemaker should start going through a cycle. You should notice the arm slowly begin to raise and the ice dispencer fingers will begin to turn. Then you will hear it call for water. You may hear a humm.
If the freezer is cold enough and the icemaker is cycling that only leaves the inlet valve. replace the valve and enjoy the ice.
If the freezer is cold enought and the icemaker does not cycle, then you have a bad icemaker. Simply replace the icemaker and viola.
Third if the freezer is not cold enought 0 defrees. Then you may have a defrost problem. In this case post more info and I will be happy to help. Good luck mca0824@aol.com
Posted on Apr 30, 2008
  • 36 Answers
SOURCE: What size is this fridge?
there is a sticker some where inside that will tell you cubic feet
Posted on Dec 12, 2008
SOURCE: Water filter stuck on my Kenmore Fridge
I had the same problem. I coudn't get the knob to turn. I ended up taking the front grill off so I could get a better grip on the knob. Once I did that I still have to put a lot of pressure on the knob to turn it but that did the trick. When I got it turned a quarter turn then it was easy to pull the filter out. Hope this helps!
Posted on Jan 11, 2009
  • 190 Answers
SOURCE: kenmore coldspot top freezer auto ice maker, water
Dear customer,
               We suggest u to perform the following checks to solve ur problem...
  1. Check the refrigerator for level
  2. Check the ice maker for level
  3. Inspect the fill cup alignment
  4. Inspect the water supply line
  5. Test the water inlet switch
  6. Test the water inlet valve
  7. Check the shutoff arm
  8. Test the shutoff switch
thank you..
Posted on Apr 08, 2009
localwonder
  • 6784 Answers
SOURCE: can't locate the water filter. water has a bad taste
The base grille water filter is located below the freezer
compartment door. Depending on your model, you may have a filter that is installed behind the base grille or a filter that is installed through the base grille.
Posted on May 23, 2009
Kenmore coldspot 52582201- water filter part number
found it try here...
https://www.repairclinic.com/Shop-For-Parts/a4b6i183d605447/Model-10652582201-Kenmore-Refrigerator-Water-Filter-Parts
Jan 24, 2018 | Kenmore Refrigerators
I have a 2001 kenmore Coldspot model 52602100 and I cant seem to find which water filter model to buy for it. Thanks
take your pick....
https://www.amazon.com/s/?ie=UTF8&keywords=water+filter+kenmore+coldspot&tag=googhydr-20&index=aps&hvadid=229213450732&hvpos=1t1&hvnetw=g&hvrand=2738182264018743319&hvpone=&hvptwo=&hvqmt=b&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9019622&hvtargid=kwd-297908882535&ref=pd_sl_7hjo17hk2k_b_p37
Jan 05, 2018 | Kenmore Refrigerators
Kenmore coldspot model: 106.74932400
Your fridge dose not have a water filter.
Aug 04, 2013 | Kenmore Refrigerators
Kenmore coldspot- 106 Model 9537654
The Kenmore Model 106.9537654 does not appear to have a water filter. Thanks Sea Breeze
Here is a PDF of the parts=> 106.9537654 Parts
Jul 15, 2013 | Kenmore Refrigerators
Kenmore Coldspot Model 51572200 is leaking water all over the floor
On the bottom rear of the refrigerator as you are looking at it from behind the left side where the water is feeding into there should be a double valve. 1 is for the water and the other to the icemaker. Many times that valve won't shut off, however the switch that dispenses the water is evidentially bad and needs to be checked if it is stuck open.
Jun 03, 2017 | Kenmore Side by Side Refrigerator
I have a leak inside my Kenmore Coldspot Model # 106 72104100. It is not coming from the icemaker.
If the water filter is old the seals will leak into the evaporative tray overflowing it. Replace the filter or give it a turn to bypass.
Jan 26, 2011 | Kenmore Refrigerators
Can't locate the water filter. water has a bad taste
May 23, 2009 | Kenmore Refrigerators
What is the part number for the water filter for a Kenmore Coldspot refrigerator model 106.54209300?
The part number is 4392922 for the water filter. You can purchase this water filter at the below link for $ 34.49
http://www.freshwatersystems.com/p-3051-whirlpool-kitchenaid-deluxe-filter-4396510.aspx
FreshWaterSystems
1.877.335.3339
May 17, 2009 | Refrigerators
How often do I change the water filter
i cant even find a filter on your machine, if there is one, there will be a model number on the filter itself as well as re-order information.Once a yr , you shhould change
Dec 07, 2008 | Refrigerators
Kenmore 50522 / 50524 Side by Side Refrigerator Logo
192 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
