GE HO98202 USB 2.0 128MB Intelligent Stick Flash Drive
  • 12 Answers
SOURCE: PQI 2G Intelligent Stick
First double check the stick for a tab with a picture of a lock on it, if that is there then switch it to the other position, if your drive lacks the switch then connect the drive. Go to my computer, right click the drive, click properties and search the taps for write protection and disable it(im sorry but i forget what tap it is under) hope that will help you out some but let me know if neither of those help
Posted on Jan 26, 2008
SOURCE: PQI 1GB Intelligent Stick USB 2.0 Flash Drive
When I plug it to my PC,It says "please insert a disk into drive".And I can't format it. T with Tanks
Posted on Oct 19, 2008
  • 76 Answers
clean your usb port if it does not work open my comp then watch in that window and keep inserting and uninserting until u see my comp reconize it if you have to do the ladder it is time for a new flash drive they do not last forever
Posted on Dec 03, 2008
bunnydawg
  • 5158 Answers
SOURCE: How do I download to a usb flash drive (memory
if you mean put files on it. you go to start--my computer and look for the drive that is your usb. likely named sandisk. double click on it so that the drive folder opens. select the item you want to put on the usb stick. left click on it and hold down the button. drag the item to the usb folder and release the mouse button. it will copy the file to the drive.
if you mean downloading from the internet. when it asks you to save the file. browse to the usb drive and click save.
Posted on Sep 02, 2009
laikexpert
  • 281 Answers
SOURCE: My usb intelligent stick installs ok and shows
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Posted on Feb 02, 2010
My flash drive is malfunction what do i do to make it function again?
Take a sledge-hammer to it, to ensure that NOBODY can ever read your private files.
Then, spend $8 to buy a replacement 1024MB (1GB) memory-stick.
Dec 10, 2010 | PQI 512MB Intelligent Stick USB 2.0 Flash...
Why is my intelligent stick write protected and why can't i format it or at least take the write protection off of it
Remove the device from your computer and check the side of the stick for a small switch that has a picture of a lock around it somewhere. If there is then push it to the other position and that should unlock it for you
Mar 02, 2010 | PQI 512MB Intelligent Stick USB 2.0 Flash...
MY pqi 4gb travelling disk is not working actually it is not getting connect with PC.Any hardware problem?
if you already tried different computers, and checked if the USB port is a known good port, then it might be your USB flash drive thats having problems. Check if your flash drive has lifetime warranty thru PQi's website...you might be able to get that 1 replaced..
Hope it helps..
Feb 15, 2010 | PQI 512MB Intelligent Stick USB 2.0 Flash...
2. Format
Mar 27, 2009 | PQI 128MB Intelligent Stick USB 2.0 Flash...
Usb flash drive can't be recognize anymore by the pc..
test with "H2testW" , if the program works and tells you you have errors, run "PD V1.08 B3"
if when selecting usb drive and it states to insert disc... it's stuffed.
Jan 28, 2009 | PQI 512MB Intelligent Stick USB 2.0 Flash...
Dec 03, 2008 | PQI 512MB Intelligent Stick USB 2.0 Flash...
Jul 11, 2008 | PQI 512MB Intelligent Stick USB 2.0 Flash...
I found no instruction booklet and I never used a flash drive USB 2.0 Flash drive. Is there somewhere I can find this on line?
This device is very easy to use you don't actually need a booklet for it , this use as a portable storage disk just plug it to a usb port of you computer then you can save files on it.
May 12, 2008 | PQI 512MB Intelligent Stick USB 2.0 Flash...
Swap files in a flash 1gb
copy pictures from hdd and paste to stick drive
Jan 05, 2008 | PQI 512MB Intelligent Stick USB 2.0 Flash...
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
