Question about HP Compaq Presario CQ60615DX Notebook
I want to know how to use control letters in the pad
I just want to know how to use the control bottin and the word pads
    Top Expert:
  • HP Master
  • 80,339 Answers
Press them and find out, keep in mind that all functions on any IBM standard keyboard are enabled. You can also go to the HP factory support site and use the search window to pose the question by specific model number.
Posted on Feb 09, 2012
2 Suggested Answers
  • 383 Answers
SOURCE: keyboard control unit problem
either the keyboard/mouse (2 in 1 on laptops) drivers are invalid in which case you can go to http://support.acer.com and download the keyboard/mouse drivers and/or utility.
Let me know if this works for ya,
Have a great and safe Sunday !
Posted on Dec 02, 2007
Chromo tablet
You can't put letters on the number pad but you can change your password to be made up of letters. You do this by going to settings, security, then at the top of the page it will say number pad or something, you click on that, then follow the instructions.
Jul 20, 2014 | Chromo Inc Chromo AAAAAAAA Pink 4gb 7"...
How do I use the letters on the number pad?
you must read your owner manual, for indication. download from www.retrevo.com or www.manualslib.com
However if the problem is when you hit, NOT key is activaded you must open the keypads, for clean it, from oxide, corrosion, dirty, with contacts cleaner.
God bless you
Nov 25, 2013 | Logitech Harmony 650 Remote Control
Error code of "Er s" appears on the display and inside the light remains on at RINSE Low. HELP!
Many modern appliances have error code build in to the control programing to help with the diagnosis of a failure. Frigidaire dishwashers with display s will flash Er then a two letter error code.
Er i s a Switch error (Replace Console Pn# 154639207)
CE is a Configuration error (Replace Control Pn#154543602)
UO is a Vent that will not close. (Replace Vent Pn#154682301) or remove blockage
uF is a Vent fan Not running (Replace Vent Pn#154682301) or remove blockage
Other codes you my see in the display that are not errors
LO is Low rinse aid
PF is power failure
Ho is Water Heating
CL is close Door
01-24 hours of delay
Service Test
To enter service test you must turn off the power and PF will be displayed. While in PF press and hold Pad # 1 and Pad # 7 at which time an “rt” will appear in the display. To get it out of service test Press Pad # 1 and the Pad # 7 this will return you to PF mode.
[ (#1)(#2)(#3)(#4)(#5)(#6)(#7) (#8)(#9)(10)(11) ]
Press pad # 1 Active water valve Ultimate Scrub Maxx Clean Valve on =FL Valve off =rt
Press pad # 2 Test Speed motor (1 Time) motor @ 2800 rpms Speed Wash pad ”28′ First two digits motor speed
Press pad # 2 Test Speed motor (2 Times) wash motor @2950 rpms Speed Wash pad “29′ in display
Press pad # 2 Test Speed motor (3 Times) wash motor @3150 rpms Speed Wash pad “31′ in display
Press pad # 2 Test Speed motor (4 Times) wash motor @3450 rpms Speed Wash pad “34′ in display
Press pad # 2 Test Speed motor (5 Times) turns off wash motor No light on ”rt” in display
Press pad # 3 Test Dispenser dispenser powered Normal Wash on = “Sd” off = “rt”
Press pad # 4 Test Drain pump on/off China Crystal or Party glasses on = dP off = “rt”
Press pad # 5 Test Fan dry Active vent on/off Top Rack,Eco Wash Glasses on = Fan speed off = “rt”
Press pad # 7 Test Rinse aid level none Rinse only low = RE full = RF off = “rt”
Press pad # 8 Test Soil Sensor none Wash Silencer or Wash pressure on = sensor voltage reading off = “rt”
Press pad # 9 Test Thermistor none Wash Temperature on = Temperature in °F off = “rt”
Press pad #10 Test Heater on/off Heater on/off No Heat Dry on = HO off = “rt”
Let me know how this works out for you.
Benjamin
Dec 23, 2009 | Dishwashers
My numbers 1234789 in letter pad don`t work.But if i pres 3,4,5 at one time will open Help in Google Chrome
The numbers five and six don't seem to work on my letter pad. All other number keys work fine. I have a Dell Inspiron notebook. Does anyone know how I can fix this? HELP!!!!
Dec 04, 2009 | Computers & Internet
Every once in a while my key pad first letter row Q thru P and second letter row keys a thru L will not operate. When the letter q is pushed qa will come up on the screen and when you push the a key qa...
Keyboard errors are Locale setting errors.
check your regional languages in control panel,
are set to english at the top, and save it.
Should be good if hardware ok
Regards
Richard.
Apr 14, 2009 | Computers & Internet
I have trouble when typing. The letters skip all over text.
Do you have a small button on the top side of the touch pad that will allow you to turn off the mouse? I bet that you are accidently touching the mouse pad with your thumb while you are typing, and this is causing your problem. I have the same problem if I do not turn off the touch pad on my laptop.
Good luck, and please rate me, OK?
Mar 16, 2009 | Dell Inspiron 6000 Notebook
My touch pad on toshiba will not work.
Hold down the function key and press F9. That enables/disables the touch pad. The function key is the one with the letters 'Fn' on it. If that doesn't work, let me know and I well explain the long answer.
Good luck, and let me know how you made out. and please rate my answer.
Jan 17, 2009 | HP Compaq Presario v3000z Notebook
Keyboard control unit problem
Dec 02, 2007 | HP Compaq Business Notebook NX9010
HP Compaq Presario CQ60615DX Notebook Logo
21 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
