Question about JVC GR-DVL915 Camcorder
Tape ejects and won't load back, even after cleaned
I have a similar problem on this same camcorder model, my camcorder will spit out the tape-carriage mechanism and won't close up again, saying 'error' on the screen. (I think it was F4) Even after using a head cleaner, it does it. Once in awhile it works. Any ideas how much it costs to get these things cleaned and repaired? It's probably cheaper to get a new one, but I NEED it, to be able to copy off all my tapes to my computer into DVDs, so I HAVE to get it fixed, or fix it myself. (I can do some things like that.) Any help appreciated, Tabitha.
kala
  • 156 Answers
SOURCE: Frustrated
E03            TU & SUP REEL FG
In the case no REEL FG is produced for 4 seconds
or more in the capstan rotation mode after
loading was complete, the mechanism mode
is shifted to STOP with the pinch roller set off.
This error is defined as [E03].
However, no REEL EMG is detected in the
SLOW/STILL mode.
1. The idler gear does not engage with the reel disk well.
2. Though the idler gear and reel disk are engaged with
each other, the tape is not wound because of overload
to the mechanism.
3. No FG pulse is output from the reel sensor.
4. No power is supplied to the reel sensor.
5. Tape transport operation takes place with a cassette
having no tape inside.
6. The tape slackens and no pulse is produced until the
slack is taken up and the tape comes into the norma
Posted on Oct 27, 2007
JDeRuvo
  • 48 Answers
SOURCE: JVC Camcorder Model # GR-D270U
On page 51 of your manual, it states that an error has occurred and recommends resetting it by removing your battery, waiting a few minutes to clear it, and then resuming. If that doesn't clear the issue, then it may need servicing.
J. DeRuvo
Digital Camcorder HQ
Posted on Dec 04, 2007
SOURCE: head cleaning required
i have the JVC MiniDV Digital Video Cleaning Cassette. I began having trouble when I was shooting DV24P and when I went to playback I noted audio dropouts. I'm using SONY Premium DVM60 tapes. I began having Head Cleaning Required message. I have ran the Cleaning Cassette and the message disappears, but even trying a brand new tape, switching to DV playback i get the error message. Luckily, the shoot i was on the master audio was being captured by a secondary device and we were able to simply use the video from my camera. Since then, I was able to play & capture both the video & audio previously recorded in HDV30P and I didnt receive an error message. Now though I cannot record any DV audio without dropouts. When I tested just moments ago, I was able to record HDV and both video & audio were clean, but during playback I still received the Head Cleaning message. Is the record head different from the playback head? Can you manually clean the heads by removing the plastic door cover with a lintfree cotton swab and rubbing alcohol (obviously disconnecting and removing all power & powering off prior to cleaning), the same way any previous machine heads were cleaned in our stations? I think I may have got a batch of bad tapes that may have gunked up one of the heads some where and its getting missed by the cleaning tape. Is is possible that the head has been scratched, and will require replacement. If yes, is there any way to look at the head and detect this?
Posted on Oct 10, 2008
welcomejee
  • 10594 Answers
SOURCE: unit in safeguard mode
Please remove and reattach battery and hope this will resolve 03 error issue in your JVC camera.
Posted on Dec 06, 2008
SOURCE: Tape ejects on a JVC GR-D275U camcorder but will not autoclose
Threw it in the trash can a bought a Kodak
Posted on Jan 29, 2009
Dear Fixya, I'm problem with my mini-tape dv rollout or spitting out while loading on Samsung camcorder SC-D453 any solution?
sir,
Please use a contact cleaner spry,
eject the mechanism, take the cassette out, look at the left below side of the eject mechanism, you can see the mode selector switch lays there. (may be not clearly visible) just point the nozzle of the contact cleaner spry to that direction spray a little, then let it dry for a while, connect the power, on it, put the cassette in and ply it.
this will cure most of the similar problems.
Jan 20, 2016 | Samsung Video Cameras
Tape jammed. Eject jammed.
Sometimes the tape is stuck on the head . Open the door and try to pry off the tape from the head with a thin instrument . Power up the unit and usually it spits out the cass. This worked for me many times.
Jan 30, 2013 | Sony Handycam CCD-TRV43 Camcorder
Vhs is stuck in machine. Won't play and won't eject.
There are any number of reasons why it won't play. The loading basket is jammed, the video tape has got tangled up in the mechanical section of the vcr or the loading gears are stripped. Unplug machine and remove top, [screws side and back] if the tape is spewed carefully remove by cutting it and clean tape particles, for any other problem have a technician check it out.
Jun 28, 2012 | Sony RDR-VX530 DVD Recorder/VCR
I tried to clean the heads with a spray cleaner and a swab.
This is the problem your camera is wet(spray)
Try to dry the camera
Nov 12, 2008 | Sony Handycam CCD-TR87 Camcorder
Sony Handycam CCD-TRV37 Error code C:32:20
1. I removed the battery. 2. With the power switch On position and holding the tape ejected I inserted the battery back on & it ejected the stuck tape.
Jul 24, 2008 | Sony Handycam CCD-TRV37 Camcorder
Canon Elura 100 won't eject tape
I have been having the similar problem. Try switching the power to off and then eject the tape in the off position. My finally ejected.
Apr 04, 2008 | Canon Elura 100 Mini DV Digital Camcorder
Loading tapes
I had a similar issue where the tape bay would not lock in and engage the motor mechanism to load the tape. I removed the battery from the unit and let it stand for approximately a minute then reinserted the battery. The tape drawer closed first without a tape then reopened with no issue. I then inserted a new tape with no issue. I guess it needed a hard reboot.
Mar 23, 2008 | Sony Handycam HDR-HC3 HDV Digital...
Tape won't load
Was having a similar problem but the tape would not even partially load. Spent several hours, over the course of several days trying to figure how to fix this and found the following solution to a similar problem on this site. I tried it as a last resort...it worked! Now I just need to figure out what to tell my wife when she asks me "how" I fixed the camera???? Here is what I did...I allowed the mechanism to close without a tape inserted (the only way it WOULD close), gave it a solid - but gentle - whack on the tape side of the camcorder with the palm of my hand...sort of like burping a baby. I said a little prayer to the saint of hopeless causes (St. Jude Thaddeus)...slid the open/eject button, opened the door, slid a tape in, gently pushed it down (where it says "push") and ...the mechanism closed!!! Not sure if the "fix" will last but we'll see and report back if the problem crops up again.
Dec 05, 2006 | Sony DCR-HC42E Mini DV Digital Camcorder
JVC GR-DVL915 Camcorder Logo
51 people viewed this question
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Mohamad Abdan
Mohamad Abdan
Roger Goldberger
Roger Goldberger
Level 1 Expert
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
