Toshiba vhs dvd recorder dvr19 manual - Televison & Video
SOURCE: dubbing vhs to dvd
Most commercial tapes have anti-copying feature imbedded in the signal. Often this is a kind of "burp" in the horizontal synch signal. I don't know if they are still available but a few years ago my boss obtained a "horizontal stabilization" box that did the trick for most tapes. We actually used it for legitimate image stabilization when using tapes with older video projectors. It cost (about 7 years ago) around $40.00 and was purchased at a little electronics parts store.
Posted on Mar 30, 2008
SOURCE: recording from vhs to dvd
Direct copy VCR to DVD:
- Insert VHS tape you want to copy
- Insert a recordable DVD disc
- Press DVD copy button on front panel or remote control (to DVD).
- To stop recording press the stop button.
IMPORTANT: If attempting to copy copyrighted material the Samsung DVD-VR320 will detect the encoding and will not allow the copy to be made.
Posted on Apr 05, 2008
Tech5508
  • 40 Answers
SOURCE: how do i hook up dvd recorder/vcr to my tv?
Hello.
If its a combined dvd/vcr unit you should be able to record on the dvd input from the vcr with a 3 split cord connected as described below..
VCR -
Video output - yellow.
Audio output - left and right - red & white.
DVD
Video input - yellow.
Audio input - left and right - red & white.
Or you might have to use a standared RF cable from the
antenna out on the video to the antenna in on the DVD.
Additional information....
Just as you can't copy commercially made video tapes to another VCR due to Macrovision anti-copy encoding, the same applies to making copies to DVD. DVD recorders cannot bypass the anti-copy signal on commercial VHS tapes or DVDs. If a DVD recorder detects the anti-copy encoding on a commercial DVD it will not start the recording and display some sort of message either on screen or on its LED front panel display that it detects the anti-copy code or that it is detecting an unusable signal.
A DVD recorder can be used to copy any homemade videos, such as camcorder videos and videos made from TV shows, and can also copy Laserdiscs, and other non-copyprotected video material. Also, remember that a DVD recorder also has a built-tuner for recording TV programming directly. The tuner can be programmed to record a series of programs on different days and times, much like a VCR. However, if you are recording a non-copy protected DVD to a DVD recorder you can record any of the video content, provided you click on the menu and start the video segments running and you have enough time space on the disc. DVD recorders function like VCRs in that they can record incoming video signals -- however, they do not automatically copy all the contents of the DVD - for instance, you cannot copy the interactive menu functions of a non-copy protected commercial DVD. A DVD recorder creates its own menu functions, it will not duplicate the function menu from a another DVD.
Hope this will help you.
/Tech5508
Posted on Feb 13, 2009
simon_law55
SOURCE: toshiba d-r160 dvd recorder manual
found it on the net
Posted on Oct 07, 2009
SOURCE: LG RC389H. Can't record vhs to dvd
Put both your vhs and blank dvd into the player.
Go into VHS mode and press "Home" menu button.
Scroll across to "Easy Menu" and select "Dubbing".
Make sure you are at the place on your VHS where you want to record from and select the "Dubbing" button.
Press the Stop button to finish transfering.
When it has done recording file information, press eject once and select to finalize the disc.
And that's it!
Posted on Jan 23, 2010
Is it possible to transfer from vhs video cassette to double layer DVD ie. DVD+RDL on Toshiba DVR20KB
There is a whole raft of solutions. Read this article for assistance/understanding
http://www.pcbuyerbeware.co.uk/ComputerProblems/CD-DVD-Blu-ray-Drive-Problems/how-to-convert-vhs-video-to-dvd-and-blu-ray-disc-formats.htm
Nov 28, 2014 | Toshiba DVR20KB DVD Recorder
Need manual for toshiba D-vr 610 recorder
For VHS -> DVD dubbing, make sure that you put in a compatible writable DVD with enough space for the video. For dubbing a DVD to VHS, make sure that you have a VHS tape with the erase protection tab on the tape. Insert the blank media in the correct side and the media that you want to record in the other. Press Setup on the remote, then select the General Settings menu. Then select Recording and finally Dubbing. (Use the up/down arrows to navigate the menus and press Enter to select an option.) Select the type of dubbing that you want to do. Press Setup to exit. Then press the DVD or VCR button (with the item to record) and press play and pause when you reach the point that you want to start the recording. Then press the other device button and press the Dubbing button (on the remote or the unit). Press Stop when done recording the selection.
Note: copy-protected videos can't be dubbed.
Crutchfield and Toshiba both have the manual for the DVR-610 . Crutchfield has the manual here: http://a248.e.akamai.net/pix.crutchfield.com/Manuals/052/052DVR610.PDF . See page 49 for a set of screen captures of the steps for duplicating a video.
I hope this helps.
Jan 20, 2012 | Televison & Video
I have a Toshiba DVD Video Recorder. How do I record from a VHS to a DVD?
For a toshiba DVD player there should be a s-video input. For a vhs you must have a vhs player that has a component/s-video output. Hook up the vhs player to the dvd recorder using an s-video cable and press play on the vhs player. Then press record on the dvd recorder.
Feb 28, 2011 | Toshiba Televison & Video
I have DVR19 DT, DVD?s I have burned will not play
The disc needs to be finalised. Unfortunately, my player didnt come with a manual. Can someone post how to finalise a disc, step by step.
Thanks
May 02, 2010 | Toshiba DVR3 DVD Recorder/VCR
Hi. I have Toshiba sdv395 & was told I could dub VHS to DVD. There is no info in the manual. Can it be done & how. Roy
This is a DVD player. It will not write to DVD but will play discs you have recorded elsewhere. You could (with non-copy protected discs) dub the DVD to VHS. To go the other way, you would need to connect the player to a computer with appropriate software or other DVD recording device.
I hope this helps.
Mar 14, 2010 | Toshiba SDV395 DVD Player/VCR
Have a toshiba tp 61H95 proj TV- want to connect panasonic dvd recorder and toshiba vhs recorder so I can copy family videos to dvd- can't get hook ups set up for both to work.
Select AV-1 or some thing in TV and plug DVD recorder Video-Audio output in AV-1 input of TV, playback any DVD and confirm its picture and sound in TV. Press Stop button of DVD recorder to stop playback.
Now plug Video-Audio output of VCR in DVD recorder input and select AV Input in DVD recorder, insert VHS tape in VCR and playback it and confirm you get VHS picture and sound in TV via DVD recorder.
Hookup between TV, DVD recorder and VCR is completed.
Playback VHS tape in VCR, Insert blank DVD disc in DVD recorder and press Record while you see VHS tape picture in TV.
Hope this info will help you.
Feb 03, 2010 | Toshiba TP61H95 61" Rear Projection...
Dubbing vhs to dvd
I have a toshiba dvd/vcr vr610 And I don't know how to dubb.I don't have the manual
Dec 30, 2009 | Toshiba D-VR4 DVD Recorder/VCR
Toshiba d-vr660ku to transfer vhs to dvr
there is an error in manual. omit step 7 and also unit should be on L1 input
Jun 11, 2009 | Toshiba D-VR4 DVD Recorder/VCR
Televison & Video Logo
51 people viewed this question
Top Televison & Video Experts
Electro Med Services...
