Question about Whirlpool Dishwashers
My dishwasher is a Whirlpool Model # DU930PWKQO. The dishwasher is not draining the water out after a wash cycle.
I cannot figure out how to get the filter off so I can clean it.
  • 126 Answers
SOURCE: dishwasher not draining
if its new call your dealer its a warranty call
Posted on Dec 22, 2007
SOURCE: whirlpool dishwasher drainage problem..
This sounds like a bad timer. The timer is what tells the pump to drain at specified times. If it gets a bad contact, that timed cycle won't happen.
PS: Do you know for sure that the drain is occurring in mid-cycle? If not, you may just have an obstruction in the drain and/or anti-siphon valve (where the hose connects under the dishwasher.
Posted on Jan 03, 2008
aborcass
  • 2651 Answers
try pressing the cancel/drain button.Do you hear water draining into sink freely?? if not i would disconnect drain undersink look for a clog right there first
Posted on Feb 22, 2008
  • 116 Answers
SOURCE: siemens hydrosensor dishwasher SE25A091GB/22
Paul
If you are still trying to sort out this issue try the following.
From what you say then it is most likely the aqua sensor on the side of the dishwasher. The gurgling sounds that you hear are likely the drain pump running and the un-drainable water sloshing in the sump.
Verify that there is actually water going to the dishwasher( Basic step but often overlooked)
Next the inlet valve will have to be checked. This is the part where the water line from the house connects to the dishwasher, under the toe/kick panel. Remove power from the dishwasher. Disconnect the dishwasher electrical connections (2 wires) to the inlet valve and connect it (carefully to 110 V power) using a jumper wire. With 110V power the valve should open and water will flow into the dishwasher, if not then the fault is in the inlet valve.
If this checks fine then the fault is likely in the aqua sensor...
On the outer left side (viewed from front) there is a panel, Behind this panel there is a small clear(of light blue) plastic mechanism with hoses and wires attached( There is usually a yellow disk at the top about 6cm in diameter) this is a float and sensor assembly there is tells the control the water level and works as an emergency drain if there is an issue. There will be a red stick protruding downward to the base and a Styrofoam float on which the stick rests. This is a pan overflow sensor if the stick is too high the unit will go into drain and cut off the fill valve power. The yellow disk is a diaphragm which senses water height. This unit can become stuck with wear and hard water.
Posted on Jul 28, 2008
SOURCE: GE Dishwasher is not draining water
GE Prifile dishwashers have a valve called a "Piston" and an "O" -Ring under the screen that become degraded over time. The part is around $10 and it takes about an hour to do the repair. You can do this yourself if you are handy and have some simple tools. You can go to the GE website and get a free owners manual.
Posted on Aug 01, 2008
My whirlpool dishwasher (GU980SCGB3)will not drain. Wash cycle works fine. Water will not drain when the cycle is finished.
Whirlpool Dishwasher Won't Drain - Model GU980SCGB3 ...
www.repairclinic.com/...Dishwasher/...-/Whirlpool-Dishwasher-won-t-dr...
My Orders. Login · Order History · My ... Whirlpool Dishwasher Won't Drain.GU980SCGB3 ... Dishwasher not draining, wont' start or not cleaning dishes properly? This video provides ... how to access... Show all parts for model GU980SCGB3 ...
Nov 04, 2015 | Whirlpool 24 in. GU980SCG Built-in...
I have a whirlpool model GU980SCGT2. There will
bake sure the water is not back water, in other words make sure your drain under the sink is high.if it is take it off and put into a drain in a bucket see if the water comes out freely
May 30, 2010 | Dishwashers
AFTER THE WASH AND RINSE CYCLE IT DOES NOT SEEM TO
Bad pump or a kink in the drainline between the appliance and the garbage disposal. And since we're speaking of garbage disposals check to see if scum hasn't built up at the drain orfice on the dishwasher.
Good Luck
Dave
Aug 19, 2009 | Dishwashers
Whirlpool Quiet Partner II not washing or sensing.
I have a whirlpool quiet partner II and for some reason it does not drain the water out any more and I cannot figure out why....people say that it is the filter but that is unbelievably hard to get to and I cannot find any instructions online or paper work that tells how to break it down. If anyone has any insight please let me know
Nov 16, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool Gold model GU1200 will not start wash cycle
FYI, for anyone else with the same symptoms. I took mine apart and found that the seal on the motor shaft failed and over time corroded the motor shaft bearing causing it to failed. I ordered full motor assembly from the parts store.
Oct 09, 2008 | Whirlpool Gold 24 in. Built-In Dishwasher...
Dishwasher will not drain water. Put Drain-O in did not work,ran short cycle water on floor. HELP
My Whirlpool Diswasher did not drain water. The same water has been recycling from washing thru rinsing and sitting there after done.
Model: S62NXPLP-7624
Oct 03, 2008 | Dishwashers
Whirlpool Quiet Partner 2
More likely: the solenoid which directs the water to either the drain or the spray arm is clogged/jammed. Located underneath near the drain line.
Jun 13, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
21 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
