Question about HP Office Equipment & Supplies
I brought my HP Officejet 7410 over from the States. I got a new plug and transformer over here. I plugged it in and it started to warm up. Then it froze--I can only pull the power cord, no buttons work, with all lights flashing. Screen has: error 0xb9921f36 165:hw_interrupt_hwv2.c Help please. Many thanks, Leslie
  • 6 more comments
  • leslieloftis Oct 23, 2008
    It worked fine in Texas. I had it for a few years as well.
    The transformer seems fine, so before I go order another I'd like to see if anyone else has any ideas.
    I'm not under warranty any more. I'll do research. Just tell me what I'm looking for.
    I got it in the States, probably 2005. I'm using it in the UK. The power rating on the transformer is correct for the UK.
    How do I check the seating of the memory? Also, what's a TFT?
    Mitch3020
    Solution 1: still flashing lights and frozen but no error message.
    Solution 2: It took a lot of time, making a bunch of warmup noises. I thought it worked, but then same error and flashing lights.
    I keep getting emails that y'all are commenting, but I can never get to new posts in this thread without reposting.
    I'm up for opening the printer. Sorry about the TFT thing. I just posted that I can't seem to access new responses without reposting my query. Talk me throuh this. Do I need any tools?
    Guru:
  • 257 Answers
FROM MY ONE POINT OF VIEW WHAT HAPPEN IS THAT YOU HAVE ALREADY BEEN USING THIS PRINTER BEFORE WITH THE CURRENT VOLTAGE THERE AND WHEN YOU ON IT IN THE OTHER COUNTRY YOU ARE NOW IS TOO MUCH OR TOO LOW FOR THE PRINTER IT ALWAYS HAPPEN TO ANY ELECTRONIC MACHINE TOO LIKE THAT OK
SO what you are going to do is to get the printer and see if there is any where at the back where someone can adjust the current and voltage at the back if yes try it and lets know what is happening and if No then i will advise you to check the Capacitors and Transistors in it if there is any damage in it or is going to need a hardware soldering of some component back to their proper position ok.
Thanks for your Post
Pls Rate this Solution
ok
Posted on Oct 23, 2008
  • Temidayo Abraham
    Temidayo Abraham Oct 23, 2008
    sounds like a power supply issue, do you have 50 Hz or 60 Hz power?
    Are you sure the transformer has enough capacity?
    From your outlet, do you know if you have 50 Hz or 60 Hz power source?
    If Israel is 220 VAC at 50 Hz that could be part of the issue.
    You will need to look at the label on the printer and see what the
    power requirements are for the machine.
    Then look at the transformer and make sure it's output is
    adequate to the printer
    ok
    check and give me a reply
    Rate this Solution.
  • 535 Answers
Http://www.unitedtechsonline.citymax.com/page/page/4590235.htm
see this link for error code & problem for your printer
  • HP Master
  • 19,396 Answers
How much is the power rating written on the transformer?
Power network in the UK works at 240 Volt, even if this does not happen very often, the higher voltage can fry many 220 Volts power adaptors.
Ginko, UK
    Master:
  • 763 Answers
Check the power cord that your using on your printer to the transformer it must be busted. also try replacing the cord. if all the solutions here tried and still didnt work then you might send it to repair service for the issue of the power lost. hope that helps!
thank you for using fixya
CHARCOIS
    Novelist:
  • 67 Answers
Hi leslieloftis,
I have a few suggestions you can try on your printer:
1.) Try holding the # then the 6 key down while you're plugging the printer back into the outlet. See if you will get a different response.
2.) If the above doesn't work try this instead, you should Press and hold OK and Cancel while plugging in the power cord of the printer to the wall outlet. See if this works.
What were trying to do is to clear settings and reset NVRAM of printer.
Hope this helps!
Peace! :)
  • 849 Answers
The transformer is not appropriat, get a reliable transforer....
  • HP Master
  • 6,487 Answers
By the way may I ask did you test printer in States before bringing this to your country because there's a possibility that the printer is really bad when you purchased it? if you already test it and it work fine better try a different transformer to make sure that its not a problem with the transformer...
  • Mark Gil
    Mark Gil Oct 23, 2008
    So this will be the first time that you will be using this printer there in UK is that right? because as you can see there's no button working on the printer meaning there's only power on the printer but that can be a incorrect power getting to the printer.....
    Sergeant:
  • 154 Answers
Actually this is a service error.
try leave the unit with out power for one hour and then again plug in the unit.
see if that works
else get back to us
    Master:
  • 538 Answers
Hmmm..well..that is odd...where are you located right now? maybe a power input issue..
  • 4 more comments
  • A Womans Computer Man
    A Womans Computer Man Oct 23, 2008
    ok..nothing about the input power to get worried about..
    so, those errors are more a driver issue. you may need to go to www.hp.com to get new drivers..
    there is also the possibility that the memory may have been jiggled on the shipment over the water..since this is a turn on issue, it is likely that either the memory or the drivers are at fault..you up to doing a little detailed investigation. this under warranty, by chance.
    hmm..did you consider checking the seating of the memory, which can be a cause of this error. The external transformer is capable of from 90 to 264 vac, so that is not an issue..but since you already decided to award a TFT, not sure if you are actively seeking my assistance here..
    TFT is a thanks for trying rating, which apparently, is automatically assessed, when an asker, like you, decides to repost a questions..you did not give anyone that rating, did you?
    the memory is inside the machine..are you up to trying this..??
    leslie..methinks it is time for a dialogue...you may wish to send a note, so we can focus on this..
    pn4pm@yahoo.com
    seems that it may also be the internal hard drive..i recommend you reach a local UK based hp person..
I deleted my HP Officejet 7410 in error. How do I
If it is a USB device then unplug it from the PC boot up the pc and then plug it in, Windows should try to install it ffor you ,make sure you have the CD with the drivers available
Either that or go to Add/Remove Programs and uninstall the software
Re-install and refit the printer following the CD's instructions
Jan 02, 2010 | HP OfficeJet 7410 All-In-One InkJet...
HP OfficeJet 7410 All-In-One InkJet Printer won't POST
Unplug the power cord from the back of the printer and while its unpluged, press and hold # 6 on the printer together for 30 secs and after 30 secs plug the power cable back into the printer while holding it and then after pluging it release the buttons after 6 secs
Nov 10, 2009 | HP OfficeJet 7410 All-In-One InkJet...
HP Officejet 7410 All-in-One Blue screen error message 00000020
I did everything you said, even the angry part lol and still nothing. Sigh...well, I've been wanting an air printer anyway :D
Oct 05, 2009 | HP OfficeJet 7410 All-In-One InkJet...
My hp officejet 7410 all in one display only hp invent and not respond
Perform a power reset
  1. Press the On button to turn off the HP All-in-One.
  2. Unplug the power cord from the back of the HP All-in-One.
  3. Unplug the power adapter from the wall outlet and wait for 30 seconds.
  4. Plug the power adapter back into the wall outlet.
  5. Plug the power cord to the back of the HP All-in-One.
  6. Press the On button to turn on the HP All-in-One.
Sep 25, 2009 | HP OfficeJet 7410 All-In-One InkJet...
My HP Officejet 7410 xi is showing an error message that states "Remove and check color cartridge". I have tried replacing the old cartridge with two separate new ones and I still get the error message.
Apparently, there is a known problem with this printer series (7310 / 7410). When you replace the cartridge, there is a metal wire that keeps the cartridge in place. This wire comes away from the wall as you slide the cartridge in and makes a hole in the ribbon cable.
Unfortunately, there is not much that you can do, other than to contact HP. Hopefully, your printer is still under warranty.
Jun 15, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Hp officejet 7410 all-in-one scanner don't work half the time.
Perform a hard reset on printer and also uninstall completely all software and then reinstall. Try scanner again.
If you have "upgraded" to another OS there is a possibility that the driver being used is not good for the new environment. If applicable, check that out.
If printer is out of warranty HP will do nada but refer you to a forum or suggest you get a new printer - an HP naturally!!!!!!!
Aug 27, 2017 | HP OfficeJet 7410 All-In-One InkJet...
HP 7410 Scanner Failure
Sorry, you have a bad scanner assembly which will cost more than a new printer.
Jan 11, 2009 | HP OfficeJet 7410 All-In-One InkJet...
HP OfficeJet 7410
Modem is part of the main board. Main board will have to be replaced. We have a few spares laying around.
Inkworks
866-381-054 1
Apr 18, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Unable to send a fax
Is your fax correctly plug in the outlet line of the wall and the same in the back of your fax....????
Mar 25, 2008 | HP OfficeJet 7410 All-In-One InkJet...
77 people viewed this question
Seeker5211
Seeker5211
