Question about Fisher and Paykel Washing Machines
Rotor Position Sensor - error 131
Can anyone show me with a diagram where the Rotor position sensor is?
  • Fisher and P... Expert
  • 554 Answers
RPS removal
Rotor Position Sensor - error 131 - ac0d984b-6953-4efa-8c9e-8690e63e4abb.jpg
Posted on Dec 26, 2013
tzweeb
  • 318 Answers
SOURCE: Cabrio rotor position sensor
ok lets try... first off you need to have the f51 code. then if you do, you do have a "rps"sensor that has failed.
get under the unit and you will see the large disc with an allen set screw holding it to the tub. remove the screw and it will pull off. then there will be 4 screws holding the rotor windings to the tub with a few wires on the sensor.
remove the screws and then the rotor will pull off and you will have the windings and sensor in your hands. when you get this all of it will be very confusing as the wires and sensor are just held into place by plastic tabs. if you have a new sensor that will help you to know that you are dealing with the right part. then unhook the wires from the sensor and next remove the sensor from the rotor windings
there is an arrow mark to show you where to put the sensor back into place, but its not easy.
thats why i get paid the big bucks!!!!!
anyway you can try this but dont get upset or mad, its just not easy for the first time you do it, but if you do it for a living then it gets easier the more times you do it.
of course i know you will only do it once but thats the best i can offer here.
Posted on Jan 06, 2009
  • 713 Answers
SOURCE: function of the rotor position censor
rotor sensor is attached 2 motor windings and detects position of motor and speed of motor. please reply 4 more help
Posted on Apr 09, 2010
blueextc3221
  • 15935 Answers
SOURCE: I have a Kenmore Oasis HE top load washer;
The F1 error code on this washer indicates a Primary Control Board failure.
It is likely that the machine control board will need to be replaced to correct this problem.
The part number for the machine control board is undetermineable because you have not provided me with the exact model # of your washer.
The procedure for replacing the machine control board is provided HERE
LINK: http://media.fotki.com/1_p,wfgstgtftbtkrrdxgtqsskgwtqkq,vi/gfsfgfsgqxgfqtqtgwf/1/1303472/5961857/image55806img-or.gif
NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
There is a slight possibility that a problem with the pressure switch hose could be causing this problem.
A pinched or twisted air hose can cause this fault code.
When you open the console, check the air hose connected to the pressure switch on the machine control board.
If it is pinched or crimped, I recommend rerouting the hose to resolve this problem.
This may fix your problem without replacing the control board.
NOTE: You may want to check for this condition before ordering the control board. Most electronic control boards cannot be returned for a refund or credit.
If you find no apparent problems with the air hose on the pressure switch, then replacing the machine control board on this washer should correct your problem. There is a risk involved in replacing this part yourself.
As noted above, you could have a problem with the air pressure hose that is not apparent upon your initial inspection. A service technician would normally need to properly and thoroughly diagnose this problem before replacing the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question!!!!!!
Posted on Sep 18, 2010
BarrettDenCo
  • 1772 Answers
SOURCE: kenmore elite oasis he washer
Hello, everything you replaced has nothing to due with balance, you have balance spring/shocks that need to be replaced or adjusted
Posted on Dec 19, 2010
Macmarkus
  • 2605 Answers
SOURCE: Whirlpool washer (Model: WTW6400SW0) shakes
Hello, Welcome to FixYa. Based on what you've described, "shakes on spin cycle" sounds like a worn tub bearing unfortunately. If you've already had the unit apart you'll know how to check for sure. Remove the agitator assembly inside the tub, once it's off you'll see the hub which holds the tub in place. ( if you're not sure how let me know...it's should be a single bolt under the center cap, then it'll lift off ) Take the tub assembly and move it side to side to inspect for "play" in the bearing. This will explain the excessive ibration coming from the spin...too much vibration sensed to allow a full spin as well no doubt. Let me know what you find and I'll try to help you move forward from here. The good news is if it's a bearing, most of those whirlpool have 5-10yr. "Parts only" warranty on that. Regards, Macmarkus :)
Posted on Jan 11, 2011
Mw612 not working
It looks like Error Code 130,
130. (10000010) Phase 1 to 6 Single Rotor Position Sensor Error
The Motor Controller has found an error in the pattern received from the Rotor Position Sensor.
Likely causes of this fault are a bad connection on the harness
between the Rotor Position Sensor and the Motor Controller,
or a faulty Rotor Position Sensor.
Primary Source: Wiring.
Action:
1) Check for corrosion on the edge connector of the Rotor Position Sensor and
the Motor Controller module connector.
2) Check the contacts on the rotor positional sensor end of the hall harness to
see if any have been damaged. (Each set of contacts in the socket has two
wipers. If the distance between these wipers varies between different
contacts, replace the rotor positional sensor harness).
Secondary Source: Rotor Position Sensor.
Action:
Check the Rotor Position Sensor with an R.P.S. tester.
Replace if faulty.
Tertiary Source: Motor Controller module.
Action: Replace Motor Controller module.
Jun 12, 2013 | Fisher and Paykel GWL11 Top Load Washer
Won't fill, spin, rinse, drain
130. (10000010) Single Rotor Position Sensor Error
The Motor Control Module has found an error in the pattern received from the Rotor
Position Sensor. Likely causes of this fault are a bad connection on the harness between
the Rotor Position Sensor and the Motor Control Module, or a faulty Rotor Position Sensor.
Action: Check for corrosion on the RAST connector of the Rotor Position
Sensor and the Motor Control Module connector.
Action: Check the Rotor Position Sensor with an R.P.S. tester. Replace if
faulty.
Tertiary Source: Motor Control Module.
Action: Replace Motor Control Module.
Quaternary Source: Rotor
Action: Ensure the correct rotor for this phase of machine has been fitted
May 24, 2013 | Fisher and Paykel GWL11 Top Load Washer
What is error 240 on a Fisher & Paykel IntuitiveEco IWL16 Top Load Washer
240. (11110000) Phase 6 - Hall Out of Order. RPS Fault
Same as previous Hall Error faults, just an extra fault code for Phase
6. See fault codes 130 and 131 for directions.
130. (10000010) Phase 1 to 6 - Single Rotor Position
Sensor Error
from the Rotor Position Sensor. Likely causes of this fault are a bad
connection on the harness between the Rotor Position Sensor and the
Action: 1. Check for corrosion on the edge connector of
2. Check the contacts on the rotor positional
sensor end of the hall harness to see if any
the socket has two wipers. If the distance
different contacts, replace the rotor positional
sensor harness.)
tester. Replace if faulty.
131. (10000011) Phase 1 to 6 - Repetitive Rotor Position
Sensor Error
This fault is similar to fault number 130 above but differs slightly in that
it is a continuous condition.
Oct 02, 2012 | Fisher and Paykel IWL12 Top Load Washer
I have a fault code on off off off off off on on
That is fault code 131
Sensor Error
it is a continuous condition. See fault 130 for service procedure.
Sensor Error
sensor harness.)
Sep 17, 2012 | Fisher and Paykel Washing Machines
Error code 130
faulty.
Aug 11, 2012 | Fisher and Paykel IWL12 Top Load Washer
Fisher and Paykel Smartdrive washing machine won't fill up
Your fault code is 131,RPS faulty.
between the Rotor Position Sensor and the Motor Controller, or a faulty Rotor
Position Sensor.
Action:
Action:
Check the Rotor Position Sensor with an R.P.S. tester. Replace if faulty.
Action:
131. (10000011) Phase 1 to 6 - Repetitive Rotor Position Sensor Error
This fault is similar to fault number 130 above but differs slightly in that it is a
continuous condition. See fault code 130 for service procedure
Mar 20, 2012 | Fisher and Paykel Washing Machines
The 1st and 7th light are on and beeping, does anyone know what this means?
(10000010) Phase 1 to 6 Single Rotor Position Sensor ErrorThe Motor Controller has found an error in the pattern received from the RotorPosition Sensor. Likely causes of this fault are a bad connection on the harnessbetween the Rotor Position Sensor and the Motor Controller, or a faulty RotorPosition Sensor.Primary Source: Wiring.Action:1) Check for corrosion on the edge connector of the Rotor Position Sensor andthe Motor Controller module connector.2) Check the contacts on the rotor positional sensor end of the hall harness tosee if any have been damaged. (Each set of contacts in the socket has twowipers. If the distance between these wipers varies between differentcontacts, replace the rotor positional sensor harness).Secondary Source: Rotor Position Sensor.Action:Check the Rotor Position Sensor with an R.P.S. tester. Replace if faulty.Tertiary Source: Motor Controller module.Action:Replace Motor Controller module.
Oct 18, 2011 | Fisher and Paykel GWL11 Top Load Washer
Water filling in squirts then fault codes 10000011
Hi just read your posting.The error number you have is 131.This error is called REPETITIVE ROTOR POSITION SENSOR ERROR.This means the wiring to the rotor sensor or the rotor sensor or the control module is faulty.Unfortunately to test the rotor sensor you need an RPS tester.I can help you test the wiring but without an RPS tester you can not test the rotor sensor easily. The rotor sensor is underneath the machine attached to your motor.Please reply on how you would like to proceed and I will help you as much as I can.Looking forward to your reply.
Oct 05, 2010 | Fisher and Paykel GWL11 Top Load Washer
Code error 131.
Hi just read your posting.Error Code 131 is called REPETITIVE ROTOR POSITION SENSOR ERROR..The 3 reasons this fault is appearing is 1--the wiring to the rotor sensor is faulty.--2--the rotor sensor is faulty.--3-- the motor controller is faulty.If you have or can borrow an electrical test meter I can help you test the wiring but to test the rotor sensor you need a tester called RPS tester.Please reply on how you would like to proceed an I will help you as much as I can.
Aug 08, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Code 131 appears on the screen. How do I fix it?
The code 131 indicates Rotor Position Sensor Error. The Motor Controller has found an error in the pattern received from the Rotor Position Sensor. This code appears due to bad connection on the harness between the Rotor Position Sensor and the Motor Controller Module, or a faulty Rotor Position Sensor.
1) Check for corrosion on the edge connector of the Rotor Position Sensor and the Motor Controller Module connector.
2) Check the contacts on the Rotor Positional Sensor end of the Hall Harness to see if any have been damaged. (Each set of contacts in the socket has two wipers. If the distance between these wipers varies between different contacts, replace the Rotor Positional Sensor Harness).
3)Check the Rotor Position Sensor with an R.P.S. tester. Replace if it is found to be faulty.
Thank you !!
Jun 29, 2010 | Fisher and Paykel IWL12 Top Load Washer
Washing Machines Logo
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
