Question about Yahoo Messenger
Yahoo Messenger NULL error.
I am using Windows XP home edition on my computer. I downloaded a firewall and had to restore my system in order to be able to connect to the internet. When I called my service provider she had me install Internet Explorer 7. When I tried to log on to Yahoo Messenger I received the following error message in the top of the blue box it says Inside the blue box it says
I can log into Yahoo but I can't do anything because of this error message. I have to close it out or it will send a report. I downloaded the newest version of yahoo messenger to see if it would correct the problem but it hasn't corrected it. If you can help me with this problem I would greatly appreciate it.
  • brneyz Oct 23, 2008
    This worked perfectly as you directed. My Yahoo Messenger is working again properly. I am thrilled!! Thank you for your knowledge and time! I
  • 6,487 Answers
Try first to run a complete scan on your computer using agood anti virus like Avast and also a anti malware like Malwarebytes they are free if you like you can download them, just to make sure that this is not cuase by any malware that came when you downlaoded the latest internet explorer.. if possible also install the older version of yahoo messenger because the new one most specially the Beta of yahoo messenger has alot of problem....
Posted on Oct 23, 2008
  • 154 Answers
Please download a older version of yahoo messenger and try it.
this may sometime clear the problem
  • santha ram
    santha ram Oct 23, 2008
    you said "I downloaded a firewall and had to restore my system in order to be able to connect to the internet."" actually what did the firewall do? what was the problem it created? and can you name that software?
Firewall stops me using yahoo messenger
Uninstall or disable any security software running on your computer. Try restarting your computer in safe mode with networking and then installing. If all of the above doesn't works and still you were getting message for firewall then either disable your Router's firewall by opening Router's page or Bypass router for a while and connect directly to Modem and then Install.
May 23, 2010 | Yahoo Messenger
Error login yahoo/windows messenger
Try to restore your window to back date if you using window xp go to start then all programs then select accessories go to system tools and select system restore a new window appear select restore my computer to earlier time, press next then select which date you want to restore your computer, press next again, this will restore your computer to a earlier date do not worry about your data this application restore only your window settings
This will help. Thanks please keep updated. please do rate the solution positively .Thank you for using Fixya
Jan 04, 2010 | Yahoo Messenger
M having windows vista yahoo messenger 8.1 is not intalling
Right Click in Yahoo Messenger ,exe And go to Trobulshuting Complier
Plz Install
Aug 17, 2009 | Microsoft Windows Vista Home Premium...
use system restore to roll back to a date before you installed it
Windows XP
Start --> All programs --> Accessories --> System Tools --> System Restore
Restore my computer to an earlier time
Click on the date you installed the **** blocker over to the left
on the right click on the point at which you installed and then click next, it will restore you pc to the point before it was installed
then continue
Make sure you are patient and do not force the pc to turn off with the power button, it will not change any of your files just the windows os
If it\'s vista the just type system in the search box and "system restore" will display above
Jan 31, 2009 | Yahoo YHT-630 System
Error code81003004
Messenger 9 for Vista users and XP users with 9, The updated Windows Firewall will not let Messenger download correctly.And is causing 9 and 8.1 users to have problems now.. The only option that might help is turning off the firewall to download and install then turning it back on.Go to control panel, click on windows fire wall, Exceptions tab. make sure messenger is checked,if not listed then add it to the list.then click save.
.If the fire wall still causes problems,then revert back to 8.0 or 7.5 these and all versions of messenger can be found here;
You need to remove version 9 1st to get another version to work. To remove Messenger version Use Unwise located middle of page of Messenger Folder.. Your contacts are stored online But if you want to save your old messages archives,they are saved on your PC in the messenger file you are about to delete.Go here and copy them to a new folder
Start>my computer>c:drive>program files>yahoo>messenger>profiles>(your ID)>archive>messages
Jan 25, 2009 | Microsoft Windows XP Home Edition
I m getting error 81003004 when i m trying to login in yahoo messenger
uninstall yahoo messenger, then go to and install the current version, the error code is due to a bug in the beta version, or the version you are using
Jan 20, 2009 | Microsoft Windows XP Home Edition
Cant sign in to yahoo messenger
I believe this problem is caused by a proxy error.  Does Internet Explorer connect to the Internet OK? Do you or your network provider use a proxy? Or a local proxy program such as Privoxy? If no, make sure that Yahoo is set to connect "Firewall with no proxies".  If yes, set Yahoo Messenger to use HTTP proxies.
Nov 12, 2008 | Microsoft Windows XP Home Edition
MSN Messenger NULL message problem
Try first reinstalling MSN , and see if this fix the problem.
Oct 23, 2008 | Microsoft Windows XP Home Edition
Cannot sign into my messenger account. Receive message: Failure to connect Foxfire can't establish a connection to the server at
Do you have a firewall? Because if so it sounds like it is disabling the connection from your computer to the Yahoo! Server.
Oct 22, 2008 | Microsoft Windows XP Home Edition
Can't get yahoo messenger to download on my pc,tried everything,firewalls down ,pop ups off what else help?
Restart your computer and being again , go to www. and redown load again if u have windows 95 you will not get yahoo messenger.Need a up date computer.
Nov 26, 2007 | Microsoft Windows XP Home Edition
Yahoo Messenger Logo
112 people viewed this question
Top Yahoo Computers & Internet Experts
micky dee
Level 1 Expert
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
