Question about Samsung Speedplus SH-S223 22x DVD?±RW DL SATA Drive w/LightScribe & Software Burner
Samsung SH-S223 door jammed open
Door jammed open
The SH-S223 has the door problem ( when there is no DVD inside).... specially after using it for couple of months, cuz i had an internet cafe and i had the same problem over 8 DVDs from 10 .... so its a factory problem.... any way here how to solve the problem of your DVD door that does not open even when it has NO DVD inside.. ... to solve the problem... take off your DVD out from the case of your PC. take off the upper label on the top of the DVD u will find a rounded circle (cover) , open it just by making it move in a circular way. under it you will find a circled plastic that has a METAL in the middle remove the metalic thing . and through it away from your window. and put the rounded plastic back (Remember not to put it up side down), then close it as it was.. DONE, for more info mazenaburas@yahoo.com plz if u find this info helpfull let me know by sending an email.... thx
Posted on Feb 15, 2012
5 Suggested Answers
shafykp750
  • 1070 Answers
SOURCE: DVD Writer Model SH-S223 hangs
Welcome to FixYa
Dear User
You have to Use a Lense Cleaner CD to Clean your Lense.Still same Problem Exist ti seems to Some Codec Problem.Try in Different Player.
Again Same Problem Send it for Repair/Replace....
Hope this Helped ...thanks for Connecting FixYa..
Posted on Oct 16, 2010
  • 302 Answers
SOURCE: Hello I have Samsung SH-S223
Do you have itunes installed?
If so Itunes put upper and lower filters in the registry key taking control of the dvd.
Goto Start type in cmd if it is vista, if it is XP click on run, then type in cmd, then regedit goto these keys in registry.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{6D807884-7D21-11CF-801C-08002BE10318}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{CE5939AE-EBDE-11D0-B181-0000F8753EC4}
Goto each key listed above and delete upper and lower filters then close out of registry editor goto device manager go down to dvd/cd rom drives right click on the dvd drive and delete it and if asked to delete drivers for this device check box to delete drivers then close out of device manager and restart the computer.
These upper and lower filters will say something like Gear Aspi.
Posted on Nov 14, 2010
bronk50
  • 27725 Answers
SOURCE: I need driver of my
If your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll to cd/dvd drives you could see a yellow question or exclamtion mark ! ? or a red x right click to update driver
hope this helps
Posted on May 02, 2011
  • 289 Answers
SOURCE: please give me the SH-S223
you can use the nero9 light scribe burner
Posted on Sep 01, 2011
My laserjet pro 400 color mpf m475dn printer is indicating " paper jam...open back door to clear jam," please describe how i will go about this process.
There is an access door in the back of the printer. Open the door and you should see jammed paper. If not then you have a faulty sensor or switch.
Mar 20, 2014 | HP LASERJET PRO 400 COLOR MFP M475DN
Driver door jammed on vw golf 99
Hold the door( when it's open) and try to lift it. After moving the door up and down, monitor the hinges, this will let you know if the hinges are getting worn.
drivers door gets used the most, maybe it's starting to sag causing binding.
Jan 17, 2014 | Cars & Trucks
On a clx-6200 message says "paper jam 0-c=open/close door. what door is this?
It is telling you that there is a paper jam. Open the door, pull the jammed paper out, close the door, it should clear the message.
Apr 21, 2012 | Samsung CLX 3160fn All-In-One Printer
Carriage jam
Hi
The carriage door is the cartridges access door.Access the cartridges and make sure they're properly installed.To open:
  • Turn the machine on.
  • Open the cartridges door by lifting from the front center of the device until the door locks into place on its own.
Feb 27, 2012 | HP C6250 InkJet Printer
1998 Plymouth Voyager drivers side sliding rear door will not open. I have removed the inner panel, checked the linkage and everything appears fine. I deduce that the rear latch mechanism is...
is the door latch mechanism moving and moving far enough to release the latch to open the door,you can`t remove the the striker plate from inside a panel as the bolts that hold the plate go in from the open side of the door jam,these do have a problem with the doors coming off the rails which mean that if this is the problem then the weight of the door will hinder the door from opening you may have to hit the door hard at the latch end of the door or even pry the door open at the same end to get the latch to pop open.the latch may even be seized or just jammed closed. good luck
Mar 02, 2011 | 1994 Plymouth Voyager
I get a message carriage jam and told to clear jam. However there is no paper jam. It tells me door open and it is not open. It seem the door does not go all the way up. I keep getting the message that...
It seems you mistook Carriage Jam as Paper Jam, but they are different issues. Carriage jam means the carriage that carries the cartridges is jammed which needs to be moved or be cleared manually after opening the door.
Please follow the instructions mentioned here (Click Here) [source HP Support].
Good Luck.
Let me know if you need further help.
Thanks for using FixYa.
Jan 14, 2011 | HP OfficeJet 6210 All-In-One InkJet...
I am having repeated paper jams in the rear door of y HP 4200. It occurs right when the paper hits the rollers to go into the outbin, and the paper stops and jams in the rear door area. I have to open...
It's been a while since I worked on a 4200. Will it print if you keep the back door open?
If yes, does it jam?
If yes, and it doesn't jam, replace the paper delivery assembly(RM1-0026-040CN)
Dec 23, 2010 | HP LaserJet 4200 Printer
Kodak i640 communication Error
I Have had the same problem. I changed the power supply an the error was never detected
Feb 08, 2007 | Kodak i640 Path-Through Scanner
Samsung Speedplus SH-S223 22x DVD?±RW DL SATA Drive w/LightScribe & Software  Burner Logo
202 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
