Question about GE WBVH6240F Front Load Washer
How do you read tech codes on ge wwvh6800j1ww
How do do read codes
What is the color code for a 3 coil GE burner
color code? as in the wiring colors? the tech sheet should have a diagram on it...
May 20, 2016 | GE Kitchen Ranges
What is ge error code 0225
I have the same issue and was told by GE that it will take a technician to fix it because it is not a known error code. Most error codes start with "f", F0, F1, etc. This the second time a tech had to come out for this cooktop. Probably the last GE I buy. Definitely won't buy anything electronic. I want regular knobs on the next one.
May 05, 2014 | General Electric Ge Profile Pp975bmbb 36...
Keeps reading error f7
Usually this means a stuck key on the keypad. A tech can disconnect the keypad, then power up the oven. If no error code: problem with keypad, if still get error code: problem with electronic control.
best regards,
bruce
www.fixyourboard.com
Jun 18, 2010 | GE JKS05 Electric Single Oven
GE WBVH6240 Front load washer. Pump running while empty
you would need to go into the fault codes and read them. the tech sheet should be under the lid or in the kick panel
Feb 07, 2010 | GE WBVH6240F Front Load Washer
GE Wall Oven JKP70 Locks and reads F9
From all the information I could gather on this issue, including speaking with a GE tech I decided to call in a repair person.
Dec 29, 2008 | GE JTP20 Electric Single Oven
We use the cooktop for about 5 mins. then it starts beeping
You have a failure that needs to be read by a technician. Call GE Consumer Service 1-800-432-2737 as these guys know the product unlike any other and can translate the fault code (there's more behind that "F" that you won't see until the unit is put into "tech mode")
Dec 12, 2008 | GE Cooktops
GE side by side GSL25KGREBS
Same problem here. Called local service tech and he said it was a common manufacturer defect with some GE refrigerators. I called GE and they don't have a recall or any formal documentation available to Cust. support people but found this on another site. A Replacement Program my GE, letter to GE service techs regarding problem. My model was listed and i am ready when the GE tech comes tomorrow that he knows about it.
here is link:
http://applianceguru.com/view_topic.php?id=13243&forum_id=1&jump_to=76889
Mar 17, 2008 | GE GSL25JFPBS Side by Side Refrigerator
What does the codes mean.. when you hit the co mbination buttons?
IN SIDE THE MACHINE IS A TECH SHEET THAT WILL TELL YOU WHAT THE CODES MEAN LOOK FOR IT IT HIDDEN USUALLY IN THE TIMER HEADER OR BEHIND FRONT PANEL
Nov 22, 2007 | GE Profile Harmony DPGT750EC Electric...
F3 Error
This is due to a Defective control board..You have to get it replaced..
Oct 15, 2007 | GE Profile Advantium SCB2001KSS Stainless...
One unit show fault code F153
Hi - I've been having the same problem. GE tech service in St. Louis, MO has been a joke. 1st tech call cancelled 30 minutes before appointment. 2nd tech call to diagnose the F153 code I had already provided when I scheduled service on-line cost $74.95 and the tech didn't have the part on his truck. 3rd tech call a new tech shows up, has no knowledge of previous call diagnosis, opens the box sent to my home by GE and announces that the previous guy ordered the wrong part! We're on the 4th call. My cook top right front burner has not worked for a month. I've contacted GE corporate. The part you need (at least I need) for the right front burner which is a large burner is: WB30T10062. If I knew how to, I'd repair this myself. I don't have the extended warranty. The part is covered because my cooktop is only two years old (parts warrantied for five years) but labor is estimated to cost almost $200....plus the $74.95 "diagnostic" visit. A total rip-off. My advice, if you've got this cooktop, it's still under warranty and you aren't using all of the burners on a regular basis: start using them! The tech guy said most people use that front right burner alot and it eventually malfunctions (code F153). His suggestion was to start using the other burners on a regular basis, too, so that when they go out, at least the part will fall under the five-year warranty! When this cook top is done, I'm going to get a gas stove with "old fashioned burners" and it won't be GE!
Sep 24, 2007 | GE 30 in. Profile JP938 Electric Cooktop
GE WBVH6240F Front Load Washer Logo
15 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
