DVDR520H 1/ Trying to play DVD shows unlocked lock symbol - what does this mean ? 2/ Unit not accepting blank discs for use in recording from HDD or external source
  • bigal13 Oct 23, 2008
    Screen shows an unlocked opadlock symbol referring to the DVD I am trying to play - what does this symbol mean ? Also why does the unit not accept blank DVD's for use in recording situations
    Novelist:
  • 67 Answers
Hi bigal13,
Based from the screen you're seeing it looks like that you're trying to play a DVD that is on a different region and is not supported by your player. Try your other DVD movies on the player and see if they work. You can unlock your DVD player so it can play other region DVDs by trying this particular procedure:
Go into the main menu
1.) Highlight "exit"
2.) Enter 2, 9, 6, 0
Now about the unit not accepting blank discs for use in recording, it's possible that you might be using the wrong type of disc for recording, try other brands of DVD-R or DVD+R or DVD+RW disc on it. See if it works.
Hope this helps!
Peace! :)
Posted on Oct 23, 2008
  • mitch_3020
    mitch_3020 Oct 23, 2008
    I did some further checking and for this philips model the unlock symbol can mean that the disc that you inserted is actually still open or you can still record on the disc if it still has space left. So most likely the disc you're inserting is a custom DVD that you made. If you don't close the disc out most players won't recognize the disc that you burned using this philips. You need to goto "Disk Tools" to display the Disk Tool Menu, then choose there "Finalize" icon. And it will finalize the disc.
    Also your player only supports DVD+R and DVD+RW discs. Not DVD-R, DVD-RW, or DVD-RAM. So buy only those blank discs that have DVD+R or DVD+RW for it to work.
    For more information you can check out your manual or visit this link to view it:
    http://www.p4c.philips.com/files/d/dvdr5...
    Hope this helps you further.
    Peace! :)
    Master:
  • 763 Answers
It is a default feature of your dvd player and it must have a settings for that to unlock your device. take a look on your device manual and see if it has a configuration for this.
CHARCOIS
  • 6,487 Answers
That message show because there's a possiblity that you're trying to play a DVD from a different region like region 0 and regioan !, in order for your player to play those DVd from different region its should be unlock first to be a multi region dvd player.......
  • Mark Gil
    Mark Gil Oct 23, 2008
    Sergeant:
  • 154 Answers
Is it showing you to unlock the unit or what?
what is being shown in screen exactly? can you tell me that correctly?
thank you
  • santha ram
    santha ram Oct 23, 2008
    this is a region code issue
    what all regions does your player support?
  • santha ram
    this will get solved if you make your player region free.
    Master:
  • 538 Answers
Are you referring to the symbol on the led screen? this is vital..and there will be more information so please hold your rating until we have more information
  • A Womans Computer Man
    A Womans Computer Man Oct 23, 2008
    seems that the unlock is part of the installation procedure..do you have the installation disk that comes with that unit?
Philips DVDR520H DVD Player will not recognise disc
Disc must be the right type (+R) . Not faulty, and have nothing on it if it is a use once disc . If it does not work then after a reboot , the drive may be faulty .
Aug 18, 2012 | Philips DVDR520H DVD Player/HDD
Trying to record to disc from VHS After recirding 8 copies, it now reads "Unknown disc, Please check disc" This is a Go-Video VR3845 Unit.
I answered this question previously and the solution remains the same;
how long have you been using the player and has it ever accept blank DVD-R discs in the past.
The problem might be as a result of weak laser (lens) or the blank discs inserted might not be compatible with player.
When the laser(lens) of a player becomes weak, it will not be able to read blank discs. It only takes a very strong laser to read/accept blank discs. If it happens that the laser (lens) is the cause of the problem, then it means you will need to replace the laser (lens) to a brand new one to be able to read blank disc. Though the player might be playing DVD and CD, note that blank disc is stronger when it comes to reading from the laser (lens), it requires sharper laser. I hope you understand this.
So, insert a CD into the player and observe if it will play.If it plays, then its obvious that your laser is very weak.
Concerning the incompatibility issue, I hope you are aware that there are various kinds of empty DVD discs such as DVD +, DVD -, DVD RW. Try any of this empty DVD discs as one of them as to be compatible with this DVD recorder.
Amongst the two topics discussed above, one has to be the cause of the problem. So its up to you to figure out which is the cause of the problem.
I hope you understand the above....
I wish you good luck.
Apr 08, 2011 | GoVideo Go Video VR3840 DVD Recorder/VCR
Trying to copy VHS to Disc-Says"Unknown disc"
Hi I am trying to copy a video to dvd on this recorder What dvd disc do i use as after recording says this disc cannot play- would appreciate the exact direction how to do this Tks
The DVD-burner inside the DVDR520H is a very cheap LiteOn-burner (model: DDW451S). It would be better to replace the burner, but it would be difficult to find a product which will fit in the limited space. I'm having troubles with burning DVD's since I had bought this peace of ****. The machine have been repaired three times, but it is still not functioning properly. Shame on Philips for assembling such a weak product and their very bad support!
Sep 19, 2010 | Philips DVDR520H DVD Player/HDD
RECORD
I think you must set the RECORD MODE to SP or SLP as above that level you cannot record from a disc. ie not in LSPor SLSP
Oct 14, 2008 | Philips DVDR520H DVD Player/HDD
Live in region 2 want to play region 1
To unlock all regions:
1.Press Setup on remote
2.Scroll down to Lock icon
3.Press 0000000
4.Regionfree!!!
Jay
Aug 26, 2008 | LG RH1999H DVD Recorder/HDD Recorder
Need to play region 1 DVD in region 2
I just got a RH387H in Hong Kong, region 3, but the above method doesn't work, this model has slightly different icon, no "lock" icon, I tried in other similar location but no effect, hopefully someone will provide a method.
ipw
Jun 28, 2008 | LG RH1999H DVD Recorder/HDD Recorder
Invlaid region code
Sounds like you are trying to play a DVD of a different region to that of the player.
Worldwide region codes, sumarised:
1 - US / Canada
2 - Europe
3 - Asia
4 - Australia
5 - Africa
6 - China
You can change the region code of the DVDR520H to any region or use region 0, which makes the unit multi-region to play DVDs from any region.
  1. Go into the main menu
  2. Highlight the exit button
  3. Type 2960
    This should give you access to a hidden menu form where you can change the region code.
Feb 20, 2008 | Philips DVDR520H DVD Player/HDD
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Televison & Video Logo
94 people viewed this question
Top Televison & Video Experts
Electro Med Services...
