Question about Proview PL866B 18 in. Flat Panel LCD Monitor
Waves Sometimes when I use the computer I get somthing like waves going accross the whole screen. They appear and dissapear after a while. Any suggestions on how to fix this?
0 characters
1 Points
How do I resolve image on screen shaking?
Hope you are talking about a computer. Do you have any electrical objects near your PC? Stuff like radios, phones etc cause waves on your screen because of the waves that they produce to communicate...magnets can also cause this...just things to look out for...also try the connects on the back...screen waves could be due to this!
If the solution was helpful, pls rate and leave a comment
Jul 26, 2012 | HP w2558hc 25.5" Widescreen LCD Monitor
Monitor screen scrambles
is your monitor is crt type or lcd or led if crt type then some hrizontal section problem like some capacitor weak
May 13, 2012 | Computer Monitors
My Monitor has impulse waves.
It may be the DC filter caps in the power supply going bad, that will be the first place to look. See failed ACER and other monitors here:
Jun 24, 2010 | Acer AL1916W 19" LCD Monitor
Vertical lines accross the screen
Vertical lines running down the screen is indicative of a data failure to the screen itself, which means either the screen is starting to fail or the data being transmitted through the data cable is being interferred with. Put a hand on either side of the monitor and give the monitor a light twist....does the line disappear? or do more lines either case, there is a problem where the data cable attaches to the lcd panel itself. You can try to change out cables, if that doesn't correct it, then the panel may have to be replaced. If you have the option of trying the computer on another monitor that would be the first step in seeing where the problem lies.
May 24, 2010 | Dell 1703FPs 17" TFT LCD Flat Panel...
I hold an LG 22inch LCD monitor. I can see waves on my monitor not sure what is causing the waves.. I have moved my speakers to down rack of my comp table.. but still i am getting.. Please help me on how...
may be a problem with your motherboard connector. Try connecting the monitor using another comp and check for the waves. But before this, try to reinstall your display driver.
Feb 24, 2010 | LG Flatron L1710S 17" LCD Monitor
Small waves going through screen
This is usually some sort of interference from another electronic component PC A/C or fan can cause this. Also dont rule out interference from outside by radio antennas or high voltage and welders
Aug 14, 2009 | Dell E173FPf 17" TFT LCD Flat Panel...
I am facing blurry waves on my new samsung lcd monitor sometimes these waves are strong and somes times get weak also very visible on same color background like blue and black background, these waves...
anything nearby causing electromagnetic interference...anything with a motor, speakers near monitor..
Don't forget to rate the advice!
Jul 28, 2009 | Computer Monitors
Hi hoovs, Waves streaming normally comes from the 60 cycles hum of the AC mains. Sometimes this is caused by poor or loose grounding in the video cable or at times a weak or defective capacitor in the power supply of the monitor or at times low voltage supply to the monitor. If after checking your cables (both power and video) are not loose and are snugly fitted to their connection points and you still get the waves, then you are probably better off returning the unit for replacement. Another thing you can check is if the monitor is getting enough power. If the monitor's power supply is rated 100~240 VAC, then it should work out ok. If it's got a 240 rating and you are using it in 110, then the monitor is not getting enough juice which may cause the waves. On rare occasion, waves may be eliminated by simply plugging in the AC plug of your monitor the other way around. Hope this be of some help to you. Pls post again how things turn up. Kind regards.
Jul 18, 2007 | Samsung 906BW LCD Monitor
"Waves" generating from the right of the screen.
It's power distortion. If you move the monitor away from the pc, the waves will stop. It's magnetic distortion causing this interference. Your monitor is fine.
Jul 05, 2007 | Dell E173FP 17" LCD Flat Panel Monitor
Faulty screen
You might need to replace the surface mount capacitors. measure the ESR on them, the higher it is, the more likely you are to get ripples. If this doesn't say much to you, take it to a lab. Use the warranty if you have it offcourse. Good luck
May 05, 2006 | HP D5060A (White) 14 in. Flat Panel LCD...
Proview PL866B 18 in. Flat Panel LCD Monitor Logo
26 people viewed this question
Top Proview Computer Monitors Experts
 Mike M
Mike M
Diego Zenizo
Diego Zenizo
Level 1 Expert
Are you a Proview Computer Monitor Expert? Answer questions, earn points and help others
