Bios cant save any information - Computers & Internet
    Novelist:
  • 182 Answers
If the BIOS loses its settings every time the computer is shut off or especially unplugged, it could be the battery that is on the motherboard has gone dead.Most PC motherboards have a lithium disk battery (CR-2032 or similar) inserted into a battery holder that is mounted on the board itself. The purpose of this battery is to hold the BIOS settings in what would otherwise be volatile memory (as opposed to flash memory, which can keep its data even when no power is applied).If this battery goes dead, the computer may complain of invalid BIOS settings every time you turn it on.Some computers (especially laptops) have a different shaped battery attached somewhere else to the motherboard, but the principal is the same. These batteries are relatively cheap, as computer parts go. Replace the battery, and you may fix your issue.
Posted on Feb 09, 2012
Cerna obrazovka nemam disketu bios
Hi, you can download the bios here:
http://www.asus.com/Motherboards/AMD_Socket_A/A7V600X/#download
Download the asus update utility from here:
http://www.softpedia.com/get/Tweak/System-Tweak/ASUS-Update-Utility.shtml
The asus Update is an utility that allows you to save, manage and update the motherboard BIOS in Windows environment.
The Asus Update utility allows you to:
· Save the current BIOS file
· Download the latest BIOS file from the Internet
· Update the BIOS from an updated BIOS file
· Update the BIOS directly from the Internet, and
· View the BIOS version information.
Aug 25, 2011 | ASUS A7V600-X (90M7A820G0EAYZ) Motherboard
Cmos bios bad asus p5ld2-x/1333 i945gc. how i fix?
http://majorgeeks.com/ASUS_Update_Utility__d4435.html
ASUS Update Utility - an utility that allows you to save, manage and update the motherboard BIOS
The ASUS Update is an utility that allows you to save, manage and update the motherboard BIOS in Windows® environment.
The ASUS Update utility allows you to:
You need an Asus motherboard in your system.
Rules for Safe BIOS update:
1. For safety reasons, always use the most updated BIOS utility!
2. Do not overclock the system/CPU during BIOS update!
3. Load "Setup Default" in BIOS menu before BIOS Update.
4. Make sure you have "Administator" privilege on your Windows system (WinNT4/2000/XP).
5. Close all application programs under Windows.
6. Disable any existing Anti-Virus applications in the system.
7. Reboot the PC after the BIOS update is complete.
8. Switch on the PC and load "Setup Default" in BIOS again.
Hope this helps
May 23, 2011 | ASUS P5LD2-X/1333 - motherboard - ATX -...
I forgot the BIOS password someone told me to remove battery and put it back but i cant find the battery
The BIOS Battery, to be precise CMOS battery looks like:
When your PC is turned off, your computer saves information about time, bios options and others with the help of CMOS battery. Try to remove it, wait a few minutes and set it back again. This action might cause to reset your BIOS password.
May 10, 2011 | Acer Aspire L100 PC Desktop
Cant detected bios
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS
after you make any changes in BIOS press Esc then press the F10 button save to cmos to restart
cmos is located in BIOS
hope this helps
Feb 20, 2011 | Western Digital Caviar WD1600 (1600YD) 160...
We cannot save the bios and can't restart
If you can't save the BIOS settings, then either your BIOS is corrupted or the battery supplying power to your BIOS is dead. The battery looks like a large watch battery on your motherboard. Try replacing that and see if it works then. If not you can either take it to a computer shop to have the BIOS flashed or replace the motherboard.
May 29, 2010 | Foxconn G31MX-K socket LGA775 motherboard
Under (setup utility) save settings are all disabled. need to able (restore settings) (load default settings) (save set- tings). in settings utility. my name is joe. can u help?
The bios shouldnt block you from saving unless it cant do it.
If this computer is more than 5 years old you may want to replace the bios battery on the motherboard and try saving your settings again.
Also, check with IBM on how to erase bios password if it has one.
Good luck and be careful.
Mar 17, 2010 | IBM NetVista PC Desktop
Invalid configuration information- please run setup program & do not enter setup
STEPS
1)"F2" on Dell Logo to go to bios screen
load Bios defaults in bios
Save and exit from bios
2)Install BIOS Update from support.dell.com
Nov 22, 2009 | Dell Inspiron 6400 Notebook
Cant load xp on compaqv3000
Hi Syed rambo,
you need to go in bios then look for boot up system then disable your hard drive to none and all other one to none just keep your cd drive as able then save then exit bios reboot system with your vista should stat to boot up then when it load up the system will reboot again before it starts up loading winxp get back into bios agian then able your hard drive and all to able them exit save and reboot that should load up your winxp.
Jan 15, 2008 | Computers & Internet
CPU Upgrade on Biostar P4VTG
1. Try change PSU - 350-400Wt is recommended as minimum.
2. Try update BIOS to last version.
Nov 30, 2007 | Biostar P4VTG-A07 Motherboard
Bios reset
As another option you could try resetting the jumper. Some boards save the password regardless unless the reset the BIOS by using the resetting jumper. Refer to the motherboard's manual for further information on how to do this.
Oct 10, 2006 | Acer (ACERMOTHERBOARD)
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
