Question about Nikon D200 Body Only Digital Camera
Blur images with nikon d200 camera
The images taken on normal & custom mode r blur even if image sharpening is set at +2
    Problem Solver:
  • 12 Answers
This could be a number of things:
1) Are you shooting at a fast enough speed, this then leads to what lens and how are you using it (handheld, tripod etc?)
2) The Lens you are using may need calibrating it may be rear or front focusing - it will focus slightly in front or behind your main subject
3) In camera sharpening isn't that great - all sharpening and if your shooting Raw files then about 70% of Raw files need sharpening should really be done in the post process
4) I used to have a lot of problems with soft focus and it ended up being down to technique, sometimes i focus in front then bring the subject back into focus from that point.
Otherwise if the problem just seems that the image is blurred it sounds like you may not be using a fast enough shutter speed.
Hope this is of help.
Drew
Posted on Nov 17, 2008
    Problem Solver:
  • 26 Answers
Try cleaning your sensor manualy.
Posted on Nov 12, 2008
The camera is set on Auto. The pictures are a blur, not in focus. Is there a way to set up good focus?
Revie manual here:
User Guide.pdf
This your camera:
Nikon Coolpix 775
1.check your lens camera is clean and clear.
You have to choices, auto and scene.
What happen when you choose scene mode?
2. test change your image quality to normal. you can go to menu even in shooting mode.
3.change image to normal and back to shooting mode and try again
It is same ?blur?
4.if still blur, try go to menu mode again, at left side you can find BSS.
5 IF BSS is off.. change it on. if it is on, change it off.
6.go to shooting mode again.
that all. good luck and rate me..tq
May 12, 2011 | Nikon Coolpix 775 Digital Camera
Hello! When I attach the flash on my Nikon D200, it fires even while I'm focusing or just when I touch the trigger button. Any ideas? The flash is not firing like that while not on the camera.
The flash on the camera is being used to throw light for the lens to focus, unless the flash has a setting / the camera has a setting to fix this.... I would assume this as a normal behaviour.
Just to be sure that i'm thinking the same lines as you - your flashes that happen while focusing will be short bursts and when you take the final image you still have a significantly higher powered flash.
Dec 25, 2010 | Nikon D200 Body Only Digital Camera
Blured images when flash not used.
It could be 1 of 2 issues:-
1) Make sure all your settings are on Auto and try again. It may be currently set to a specific scene setting which is distorting your photos.
2) It may require a firmware upgrade. That will involve going to the Nikon website, following links to support/downloads and checking to see if there's an update for your camera.
Apr 10, 2010 | Nikon COOLPIX L20 Digital Camera
I shoot RAW/basic jpg. I review them there is a contrast differen
This is normal. Bear in mind that the JPEG file has all the image processing done, while the RAW is just the raw data. Depending on your image settings (contrast, saturation, sharpening, etc) you may see some differences.
Nov 24, 2009 | Nikon D200 Digital Camera with Nikkor AF-S...
Nikon D200 images not sharp
Your camera settings may be off. The D200 is very flexible when it comes to personalizing your settings, but they can be hard to navigate.
Try resetting using the built in reset feature. This will not affect your personal settings but may clear any unwanted changes. To do this, find the "QUAL and +/- " buttons on the top of the camera. Hold them both down for a few seconds. The top LCD blinks then the camera is reset.
This resets things like resolution, White balance and ISO settings.
Next, try setting your metering matrix to the middle position. Not the top and certainly not the bottom postion. This switch is located on the right side of the view finder.
If your lens has a "M/A - M", use the M/A setting.
There are three settings for focus. C, S, and M, located on the front of the camera next to the lens. Set your camera focus to "S". This will set it up for still subjects and prevent the sensors from tracking things that move. Also set on the AF area mode switch on the back of the D200.
Try these settings. If your images are still out of focus, you may have other issues that may require servicing by an authorized Nikon facility.
Apr 13, 2009 | Nikon D200 Digital Camera
Very soft focus on D200
Hi Amanda, welcome to FixYa.
Try this to fix your focusing issue. It's a custom AF setting.
Press the Menu and select the pencil icon. Then you'll see Custom Setting Menu on the LCD display. Click down to Autofocus and then click to the right.
There are 3 choices here: FPS Rate, FPS Rate + AF, and Focus.
Set it to Focus.
FPS Rate is the default setting, the camera will take 5 frames per second whether it's in focus or not.
FPS Rate+ AF forces it to slow down hoping to get more frames in focus.
Focus sets the camera to fire only when in perfect focus. It slows you down some, but it will save you from deleting all the blurry ones.
Try this and let me know if it works for you with a comment.
Ken Rockwell has alot of tips and tricks (including the one I just gave you) in a pdf telling all about your camera. You can read it here. http://www.kenrockwell.com/nikon/d200/users-guide/d200-users-guide.pdf
Enjoy your camera and feel free to rate my solution.
Rob
Mar 02, 2009 | Nikon D200 Digital Camera with 18-200mm...
Problem with importing images to laptop(macbook) from nikond200 trough data cable
Camera must be in point-to-point USB mode for remote tethering to work.
In menu with wrench icon, make sure USB is set to "P" point-to-point.
Apr 12, 2008 | Nikon D200 Body Only Digital Camera
Fujifine pix A330 produce blurred image on all picture taken
continuous blurred images? or only occasionally (say in low light)?
Mar 30, 2008 | Fuji FinePix A330 Digital Camera
NikonD200
The symptom you describe sounds like an incorrect white-balance setting when you take the images. Digital cameras are sensitive to the quality of lighting seen when your taking pictures. First thing to try is to manually select a white balance setting and try the photos again. Try google or your manual to find instructions on how to do that. The camera can auto-adjust to some lighting situations, but fails to properly compensate in other situations resulting in the muddy or yellowed images you have seen. There is a product called "expodisc" that corrects for this white balance problem as well. Look it up. David Millier Advance Camera Repair
Feb 21, 2007 | Nikon D200 Digital Camera with 18-200mm...
In camera mode, screen shows a blend of image and digital spectrum analyzer bars blurring the image
the ony way is to get the CCD replaced with a new one. Contact NIKON for free replacement as this comes under manufacturing defect.
Aug 16, 2006 | Nikon Coolpix 5700 Digital Camera
Nikon D200 Body Only Digital Camera Logo
187 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
