Grundig HD GUFSAT01HD Manual
I have two other satellite dish which already feed this television, But I want to be able to put in a free sat Satellite top box as well is this possible.
  • 346 Answers
SOURCE: no audio on magnavox television
check the audio amplifier ic
Posted on Dec 23, 2007
  • 749 Answers
SOURCE: Emerson tv remote code
I have ask some help from our friends and they also have problems regarding this type of TV... But try this one
Quotes from friends:
1. "The universal remote that came with my Motorola HD cable box worked fine"
2. chat sessions
3. Chat session find jcut92
My quote:
Ask the vendor for a code, if they don't give you return the TV , it lacks technical support... Believe me or else face more problems in the days to come.
I'm sorry, there's lo luck... Fixya me instead...
Posted on Feb 06, 2008
SOURCE: Input Signal between TV and satellite dish lost
had that happen with my 42F430 and my PS3
every other input works except the HDMI
toke me the entire day to verify that its not my PS3 thats casuing the trouble
what i end up doing is "UNPLUG" the power cord of the TV and disconnect the HDMI cable from the PS3 then let the tv sit for 2 minute, then plug the power cord back in the TV then press and hold the power button for about 10 second.. to turn it on, after the TV boots up then i go to menu and do a factory reset
and after that it start picking up the signal from my PS3 again
Posted on Jul 04, 2008
xCAUSALITYx
  • 210 Answers
SOURCE: Satellite dish icon unavailable so cant retune
Switch over to analogue and press menu, the Sat dish icon should be there, if its not there then the tuner board/video board may have gone faulty.
Sat icon is not available in DTV mode anyway...!
Thanks
Posted on Oct 01, 2009
Testimonial: "Cheers, TV now tuned in, all sorted, can stop pulling my hair out!"
  • 4 Answers
SOURCE: My television don't receive any signal from my satellite cable
Frist u have to make sure there is no break in the anternna cable, then see to it that there is no dry joint in the tuner p
Posted on Sep 11, 2010
My Free sat has stopped working. Keep getting no signal. What could it be?
Have you checked that your satellite dish hasn't been moved by something, if all of the satellite wires in the back of your box are still plugged in, then this may be the cause.
Nov 03, 2013 | Televison & Video
How do i connect my samsung dvd recorder sh853m to my free sat box? Also is it possible to record a channel from free sat onto my samsung recorder while also watching a different free sat channel.
If it's a Standard-Definition (SD) FreeSat box then a SCART cable would be the normal method of connection to your DVD recorder. This would connect to the SCART/EXT OUT socket on the back of the FreeSat box and the SCART/EXT IN on the DVD recorder. However, this depends on whether your FreeSat box has multiple SCART outputs and whether you are using a SCART cable to connect to the TV.
If there is no spare SCART output socket on the FreeSat box, then you need to use an alternative connection which is common to both devices, i.e. co-axial, and make sure you are connecting from an OUT socket on the FreeSat box to an IN socket on the DVD recorder.
If you have a FreeSat HD box, then you need to connect it to the DVD recorder using an HDMI cable or another cable type that will carry an HD signal.
You will only be able to record from a different Satellite channel if you have a Dual LNB with 2 feeds to the FreeSat box. The LNB is the receiver that attaches to the arm on the satellite dish. You can determine whether you have a Dual LNB as you will have 2 cables from the Dish to the FreeSat box. They may be joined as one cable, but there will be 2 F-plugs (threaded co-axial plug) on each end.
If you don't have 2 cables then you will only be able to record the same channel as you are watching. To record another channel, you need a FreeSat box that supports this feature and each channel needs also a separate feed from the dish.
Hope this helps. If you need any further assistance please post back with the brand model number of your FreeSat box and details of the connections you are using between the FreeSat box, the TV and the DVD recorder.
Regards,
BElectric
Dec 29, 2010 | Samsung Televison & Video
Vip 622 rebooting. receiver works when just plugged in,once satellite cables attached, will work for a while then reboots. Can get it going again if take satellite cables off then put them back on. But if...
this problem occurs when the ground on the Dish is not properly connected. What is happening is the cables from the dish are backfeeding voltage and grounding out your rec. Now there could be a possiblity that it could be the rec. however if it stays powered on with the sat in cables discon. then it defintley sounds like a grounding issue.
Oct 20, 2009 | DISH Network ViP622 DVR DTV Receiver /...
Does the dish network 322 receiver require two lines from the satellite to the receiver?
It does require 2 lines form dish unless you have a switch installed such as a dp34 or you have Dish Pro plus LNB"S on your dish and you can use 1 feed to the reciver and use a separator to separate the signal into sat 1 and sat 2 (note: a standard splitter is NOT a separator) a separator is dish brand equipment.
Oct 15, 2009 | DISH Network 322 DTV Receiver
Thanks
Oct 01, 2009 | Televison & Video
NOT CORRECTLY IDENTIFY SAT
The HD feed comes in on 61.5 for a majority of stations most often locals come off 119 or 110. The USA hd comes off of 61.5 transponder 19.If you press menu 611 on your dish remote and manuever the highlight to the satellite and go to 61.5 and then change the transponder to 19 you will probably have a poor signal from 0 -39. Typically this can be resolved by having the dish re-peaked but sometimes foilage may be the cause. Thanks for using Fix Ya.
Aug 02, 2009 | DISH Network 301 DTV Receiver
HD not fitting on screen not sure of settings
Both the TV and Satellite box will have various size settings. The box remote probably has a button devoted to it.. could named several different things, (aspect, size,picture,etc..) on tv menu you will find a section devoted to picture size or you may even have a button on your tv remote just like the sat box does, most do.
Apr 30, 2009 | Televison & Video
I have a Sharp Aquos LC-30HV4U which is supposedly HD ready. I am a Dish Network satellite subscriber. I do not know what to do to make this HD ready set receive HD signals.
Your reciver is already set for the hd. Alls satellite programing and cable already come in hd format. You can also get any info here.
http://www.dtv.gov/
Good luck and please rate FixYa!
Apr 07, 2009 | Televison & Video
Looking for manual
HI,
DOWNLOAD PDF FILE FOR 800 SATELITT
GO TO GOOGLE ENTER SAT 800 GRUNDIG PDF
YOU WILL GET A MANUAL FREE OF CHARGE....
Nov 13, 2008 | Grundig Satellit 800 AM/FM/SW Radio
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
Electro Med Services...
