Question about RCA L42WD22 42 in. LCD Television
Where is the fuse on na rca 42 inch lcd tv - RCA L42WD22 42 in. LCD Television
dsacco86
  • 1077 Answers
SOURCE: sound ok but no picture on a 42 inch. lcd tv
The most likely the tv has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Posted on Jun 28, 2009
1fastbob
  • 301 Answers
SOURCE: 42 inch lcd tv.its a rca. the screen is damaged.
There is NO picture tube on an LCD set. If the screen is damaged it will make more sense to buy a new set rather than attempt a repair.
Posted on Nov 13, 2009
  • 7 Answers
SOURCE: RCA LCD TV INVERTER BOARD
I have a new power/inverter board for a L32HD32D RCA 32" flat screen LCD TV. Make offer, 1-907-225-2337 I'll ship it USPS in the box it came in.
LS2HD32 CEG379B CAJAID, CAJA4465 1114363 are some numbers on the package it came in. You might try LPS#1 on the ribbon cables & their video board connection for the LCD by opening the back 4x5" pannel in the middle & clean reinstall them ? That's what fixed my TV, maybe. So I don't need the board now. It's only about a 5 minute job to clean the 2 ribbon cables.
Sincerely Bitdog
Posted on Feb 16, 2010
SOURCE: i have a 42 inch rca tv model WB22YX5 componet inputs dont work
Sometimes, these inputs get damaged by ESD, or stray voltages, and become damaged. You may just need to give the set a reset, unplug an leave for 5 mins or so, and try again, if still no go, see if there is anything, in the troubleshooting procedures, that can help. It may just be a board replacement, If you decide, to get it repaired, please first contact RCA head office, and ask for a referral, to an authorised service center.
http://www.scribd.com/doc/7581822/RCA-Chssis-CTC-175176177186187-TV-Training-Manual
Posted on May 05, 2010
mpaint
  • 36 Answers
SOURCE: 42 inch rca lcd tv says unusable signal
This is a very common problem with these models.
The problem is very likely a fuse that has blown, if the following is true:
No Video on any input BUT HDMI and
No Audio at all.
Purchase a fuse, these are freaking tiny from digitalkey.com or mouser.com F1455ct-nd
Pull the back off of your unit
Pull the cover off of the PCB housing. It is the box that contains the hook ups including the cable tuner.
The silver box that you screw the cable to is where you begin to look for this fuse.
About two inches behind this silver box is some numbers printed on the board 7c32 and partially obscured will be 1c33
Using a big magnifier look next to the numbers listed above, you should see a tiny rectangle fuse with an F on it.
This F fuse is a 500ma fuse that is too small for the load
The fuse listed above will have a G on it. It is a 750ma fuse.
Call the repair shops in your area, tell them that you know the problem, have the part and you want to know how much the bench time and labor will be to repair your unit.
Posted on Jul 23, 2010
My RCA 42 inch TV turns on but I see nothing but different color lines on the screen and no sound.
Lines on the screen usually is a problem with LVDS board, panel or the ribbon cable to the panel. Set should have audio though. the main board processes both audio and video but will not produce colored lines.
Feb 03, 2015 | RCA L42WD250 42 in. LCD HDTV
Cannot program 42 inch tv with rca remote?
They wont do that. If you don't have the original remote then you must do by way of the manual controls on the set.
Nov 27, 2010 | Westinghouse W4207 42 in. HD-Ready LCD TV
I am attempting to attach a Samsung Sound Bar to my 42 inch LCD 1080P Polaroid Television. I can not seem to get sound from the Television connected to the Sound Bar. Thoughts?
Connect the audio out RCA jacks (white and red) on the TV to the white and red RCA input jacks on the sound bar for analog stereo sound or connect the black digital audio output jack (typically optical) on the TV rear panel to the sound bar's optical digital audio input jack for surround sound. Use an optical cable. There may be some user settings on the TV for audio.
Aug 12, 2010 | Polaroid FLM-4201 42 in. LCD Television
No Audio at all.
Jul 20, 2010 | RCA L46WD22 Television
42 inch lcd with blinking red light
I just fixed mine, I am not exactly sure what did it, but I held the power button down while pushing and holding each button for a few seconds after going through each button I unplugged power cable and then plugged it back in and it powered it up and it worked
May 21, 2010 | RCA L42WD22 42 in. LCD Television
42 inch lcd tv.its a rca. the screen is damaged. picture tube is out. how much will it cost?
The cost of a new screen is proportional too the retail value of the tv. When the screen is cracked its overwhelmingly expensive to purchase, then an additional cost to install it. You may want to look into selling that tv for parts. Other than that, you may as well buy a new tv compared to the cost of a new LCD screen.......
Nov 13, 2009 | RCA L42FHD37 42 in. LCD HDTV
My 42 inch lcd phillips tv turns on and of by its self and freeze
If it is still under warranty address this. The problem is the signal board. The one with rca jacks and RF connectors.
Aug 19, 2009 | Philips Televison & Video
Philips 42'' flat screen
Bring your TV to eletronics technician. The main power of your TV has a broken semiconductor parts that need to be replace. ( Maybe power mosfet, fuse, transistor, capacitor, etcc ).
Jul 23, 2009 | Philips 42PFL5603D 42 in. LCD HDTV
Remote control code for 32 inch lcd EMERSON TV
I succeeded is using the DirectTV remote control for the Emerson 42" plasma TV, by using a Samsung code. On my TV, was 10060. If this one does not work, there are a bunch of others that might work. Good luck
Feb 18, 2009 | Emerson Televison & Video
RCA L42WD22 42 in. LCD Television Logo
85 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
