My asko W6661 Quattro 1600rpm says inlet water fault and it won't let me open the door to get washing out what do I do please
  • 1294 Answers
SOURCE: Asko washing machine door not closing
Changing the door lock is one of the easiest things to do in a washing machine. Just note which wires go where & get a new door switch.
Posted on Jun 11, 2007
  • 351 Answers
SOURCE: Asko W660 Quattro Front Load
check the inlet valve solenoid there are three of them one might be o/c,also using to much soap can cause this or a coin stuck in the sump hose near the pump.the filter is in the valve but normally isnt the problem
Posted on Aug 28, 2008
SOURCE: I own the ASKO W6661
It is not an easy shut. They do this on purpose. Try using force at the point of contact. Do not slam.
Posted on Jan 12, 2009
jumptrout51
  • 3361 Answers
SOURCE: Asko w640 has a water inlet fault
Check the drain line to make sure the water does not siphon out as it enters the machine.
Posted on Mar 10, 2009
  • 15 Answers
SOURCE: Asko Quattro 6661 water inlet fault
I had the same problem with my unit. The manual tells you to disconnect the water intake at the machine and clean the screen. This wasn't my problem because as you said the problem doesn't occur until the Rinse cycle which means there is water supply to start the Wash cycle.
From the back of the unit, remove the three screws and take of the lid. You'll notice that there are three separate motors do pump water inside the machine at the water intake. When standing in front of the machine, the motor on the right controls the rinse cycle. I connected an AC volt meter to that pump and started the rinse cycle. 240v showed up at the pump, but the water flow was poor. I simply squished up and down the rubber hose connecting this motor to the detergent unit and was unable to free the clog and water began to flow.
Posted on Mar 14, 2009
Water outlet fault
Check and eventually clean filter. Located behind the small square "door" on the left side:)
Oct 13, 2013 | Asko W6661 Front Load Washer
Inlet water valve error when the door is opened and closed during a washing cycle
If water is siphoning out, either drain hose is too far down pipe or there is an airtight seal where drain hose goes into pipe.
Aug 31, 2017 | Washing Machines
My Asko W6661 washing machine water inlet fault would come on so I check the water inlet line and filter and everything was ok, but the water still would not come into the machine. I than check the...
As the solenoid should should remain power free and closed until the programmer tells the circuit board to switch on the power, it could conceivably be either or both of those things, though I feel the chances are greater the circuit board is at fault.
Apr 05, 2017 | Asko W6661 Front Load Washer
Jan 07, 2009 | Asko W6661 Front Load Washer
Asko W660 Quattro Front Load Washer - WATER INLET FAULT. Checked the troubleshooting guide, which recommends disconnecting the hose and cleaning the strainer in the water inlet of the machine. WHERE IS THE...
Aug 28, 2008 | Asko Washing Machines
Over Flow Fault detection
Press "end of cycle" button; and wait for 2 minutes before trying the door. Do not force the door.
Rate me if helped please.
Jan 12, 2008 | Asko W6661 Front Load Washer
The water temperature fault indicator is on
I think te problem may be the Termistor(temperature sensor) that is faulty. You need a technician from Asko to replace it.
Dec 13, 2007 | Asko W6661 Front Load Washer
Water outlet default
Outlet filter is located behind the little square door at the bottom of the machine. The inlet filter is in the end of the inlet hose. It is also a filter in the valve on the machine.
Dec 09, 2007 | Asko W6661 Front Load Washer
Washing Machines Logo
43 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
