Ethernet driver is not working,have tried to put another in and also not working
  • Anonymous Mar 10, 2009
    I have no network driver installed
  • A Womans Computer Man
    A Womans Computer Man May 11, 2010
    hmm..and what sort of computer are we working with here?
    Guru:
  • 257 Answers
Hello hear me well did you mean your Ethernet card or driver?
If its your Driver then try to find a original and not a trial version the one right from their site or from their company ok then install that but if its your card then change the card to another slot or dust the slot very well and replace it ok it will be fine.
Rate this Solution.
Posted on Oct 23, 2008
Ethernet device not working
Is the driver installed? Check to make sure the driver is install in the device manager under the Control Panel. Click Start/Control Panel then look for System or System and Performance. Open it and look for the device manager. Check under Network for the ethernet or Local network connection and make sure it is working.
Look at where the ethernet cable goes into the computer and you should see it light up. If there is no light, then either the port on the computer is bad or the cable is bad.
To download the ethernet driver try the steps below.
Get onlineand got to www.google.com In the google search box type: "AcerSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Download and install the Network drivers.
May 04, 2012 | Computers & Internet
Ethernet light does not come on cant connect to internet
Try replacing the ethernet cable, if that doens't work then try to reinstall the driver, if that doens't work then that means the ethernet port could be defective.
Feb 28, 2011 | Computers & Internet
My erthernet card doesn connect when i put a cable ,it says cable unpluged..how do i fix it
plz try by reinstalling the ethernet driver, if the problem is not solved then check with a working lan cable.if your ethernet card is working with another lan cable then your ethernet card is faulty other wise your cable is faulty.
Aug 25, 2010 | Compaq Computers & Internet
I cant install my router. The internet, power, WLAN, and DMZ lights are all on, but none of the Ethernet port lights are on, but when I try to complete the install I get the following error message: Unable...
If the ethernet light is not coming that means your router is not detecting your computer. Try to plug the computer on any other port.
To check if your ethernet ports are fine you can perform a loop back test. You can take a cable which is not connected to anything. Than put one end of the cable to one ethernet port and put other end of that same cable to any other ethernet port. If the light on the ethernet ports led up means your ports are fine and u need to reinsatll the drivers of the ethernet card on your computer. Else your routers ethernet port are not functioning. If that is the case you can try to reset the router.
Let me know your finding.
**If this works please rate else let me know in case of further help.**
Jul 03, 2010 | Linksys Wireless-G WRT54G Router
Lan terminal not working
first check for all the drivers in the device manager.... if every thing is perfect in driver side, then check if the ethernet/ lan is enabled....
then check is the light in the ethernet adapter is lit, when you plug any ethenet cable in it... still if it is not working, then finally try to update the latest driver for the ethernet controller.... if nothing works, then buy an pci ethernet card and use it..... you can also buy external cards like usb to ethernet converter... even belkin manufactures usb to ethernet controller....
May 09, 2010 | ASUS P4P800 SE (890552603657) Motherboard
Unable to get on the internet. It says ethernet is unplugged. a friend told me that i should download the driver to my other computer. Then put the harddrive on the other computer that im having problems...
If its saying "Ethernet is unplugged" means its not getting signal from the router to the machine through your LAN cable. Try changing the LAN cable and check your Ethernet settings.
Jan 05, 2010 | EliteGroup P4S5A/DX Motherboard
Replacing ethernet PCI card 10/100 by gibabit 1000
When you replace and install LAN card you need to install also the driver. Be sure that your onboard ethernet PCI card are disabled in BIOS. So that the new install LAN card are working.
Regards
PCmania
Sep 26, 2009 | Dell Ethernet Card Network Adapter
Connecting to internet
yeah i feel so you can check if they are installed by going to my computer properties and driver signing.good luck
May 25, 2008 | Acer TravelMate 212TXV Notebook
Computers & Internet Logo
376 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
