Question about Nokia C5 Cell Phone
Error in nokia c5-03 continue offline mode
Continue using phone offline mode ...error in nokia c5-03
zaids
  • 456 Answers
SOURCE: Phone in offline mode
'whether you want to continue in offline mode y/n'.,
when it displays this messege
press no
and u r done
Posted on Sep 29, 2008
  • 4 Answers
SOURCE: Nokia e65 stuck in offline mode.
step 1>switch off your phone and turn it on again
step2>you should get a respond <: continue in offline mode>: select no
finally, i believe that everything should be ok.
if it doesn't there is alternative 2???/////
ALTERNATIVE TWO: this is useful for those who got INSERT SIM CARD RESPONSE.
WHY INSERT SIM CARD PROBLEM ?
my phone is 1yr and 6 months now and i discovered that as you remove and replace your Sim card numerous times, there is a big possibility that Sim card port will get expanded.
SOLUTION is very simple:.>>:1. buy a black solo tape
2. place it at the outer part of the sim card and use blade to cut exactly the same shape as the sim card.
3. finally stick the tape.
WARNING>>?do not stick the tape on where you have the Sim card service sensors.make use of your brain.
Posted on Jan 14, 2009
fossildude
  • 832 Answers
SOURCE: nokia e65 phone is stuck on offline mode.
hi thanks for using fixya!
On this kind of error, I suggest you should bring your Nokia E65 to a Nokia Care Center in your area to further check the software error.
If you need further assistance, let me know. Please rate me! thanks!
Posted on Jun 15, 2009
raingamj
  • 2148 Answers
SOURCE: my NokiaN70 is in the
Offline mode means the sim you have inserted was not detected by your phone.Firstly clean the Sim Card slot(case)and check the connector.If the problem still persist contact nearest mobile repairing center.
Good luck
Visit Again...........Fixya.com
Posted on Aug 15, 2010
SOURCE: my nokia c5 is in offline mode how am i going to
open line
Posted on Mar 10, 2011
My nokia c5 is in offline mode how am i going to openline it?
on standby mode. Press the power button once, you should see some options. Just pick a different profile and answer yes to the next question or open the phone, adjust your sim and restart your phone and it will ask to continue using phone in offline mode and you click no
Jul 09, 2013 | Nokia C5 Cell Phone
My nokia 5230 shows me am in offline mode, i need to come out of it
I think you are using the handset without sim if it is so try inserting a SIM Card and while trying to switch on phone it will opt you whether u want to continue with offline mode or not.......simply click on no and your handset will be out of offline mode
But if you have inserted the sim card and its still showing offline try going to profiles and select General mode from there....if it is changed then its superb and if not then visit your nearest service center to get the software updated for your device
Jun 19, 2011 | Nokia 5230 Cell Phone
How to remove offline mode in nokia e72 mobile
Please restart your phone. After restarting, it will ask do you want to continue in offline mode, select NO. This should solve your problem. Make sure you have SIM card inserted in your phone.
Feb 26, 2011 | Nokia E72 Smartphone
My nokia e72 still stay in offline mode .....how to change it..
offline may mean that the Sim Card was not correctly placed or a fall or shock on the phone has requested you to switch to offline mode and thus you are on that mode. This can be cured by turning off the phone and removing and putting back the Sim Card. You can also just change the settings to General if you had earlier inadvetently chosed the offline mode.
just try this one!!! first you do is to click the power switch for 1 sec. then it appears: switch off,lock key pad,general,silent,etc. you will see a offline word in the screen.... just choose general profile.... and this words will appear "phone is currently in offline mode. change profile to access network?" just choose yes.. i hope it will help your problem....
please rate :)
Dec 19, 2010 | Nokia N72 Cellular Phone
My NokiaN70 is in the offline mode and I cant get to be in the online mode. On start up it asks continue using the phone in offline mode, when I press the No button it does not respond but continues to...
Good luck
Aug 15, 2010 | Nokia N70 Cellular Phone
It says continue using phone in offline mode?
Error Message -
Continue using phone in offline mode?
Troubleshooting tried -
Tried with Samsung service centers but no gain.
Master reset, Software reinstall, also tried to reset imei number.
Most of the troubleshooting was done by certified techs, if you could help to fix
this issue, you must be called as the best Genius of Technology!! Please Help.
Dec 26, 2009 | Cell Phones
My phone nokia 6680 has been in the offline mode.i want remove it
when you insert sim in your phone after using it offline,it should ask you if you want to continue using your phone in offline mode...select NO..Otherwise your phone cannot detect the sim card..clean sim terminals..if problem persists check and reheat sim filter IC..the crystal one, near the sim terminals itself..if all fails then UPP (CPU) or software problem..
Jul 16, 2009 | Nokia 6680 Cellular Phone
press no
and u r done
Sep 15, 2008 | Nokia N70 Cellular Phone
Offline mode
take the sim card and put it bck again.restart it...there it will say "CONTINUE IN OFFLINE MODE?"....select no there...choose another profile and press ok...offline mode will b disabled....
Oct 23, 2007 | Nokia N73 Cellular Phone
My Nokia 3250 is in offline mode(Profile) and refuses to change back to a normal mode.
reinsert sim of ur fone and it will ask there continue in offline mode?select NO there and choose another profile....
Oct 09, 2007 | Nokia 3250 Cellular Phone
Nokia C5 Cell Phone Logo
48 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
