Question about Juicers
How do i clean cookworks signature juicer
Nned to remove grater on juicer but have no manual
  • 4 Answers
SOURCE: how to clean juicer
You can donwnload a manual (pdf) from http://www.powerjuicer.com/pdf/classic.pdf
Or you can view a video - Power Juicer Assembly, by following this link http://www.powerjuicer.com/customer-manuals-video1.html
Eddy
PS - the video is shown for the Deluxe model but same procedures apply to the Classic
Posted on Jun 17, 2008
  • 24 Answers
SOURCE: COOKWORKS JUICER 350W
CHANGE THE FILLTER
Posted on Jul 29, 2008
SOURCE: breville je2 (anthony worrell juicer) lost the blade!! slicer!!! thing
why don"t you two put your heads together and call the company or get on your computer and look it up, to order the parts,good luck
Posted on Aug 07, 2008
  • 7 Answers
SOURCE: How to clean the Jack LaLane Juicer?
the blade can be removed possibly with your hands, if you can manage to turn it, if not then find something that will fit into those little holes of the blade to turn it, and then take it apart, but remember in what order. to put it together: the grey thing with the spout attached goes on first, then the orange basket, then the blade, but don't turn it too tight, just look for the indicator marks and line them up with the arrows, then the black lid, and then the pulp basket.make sure that the black lid in the back, goes INTO the pulp collector, it is not very far, but if it is not done like this, then your machine will not work. then you raise and lock the bar into place and put the pusher into the feeding tube. hope that helps.
Posted on Jun 30, 2009
SOURCE: how to remove strainer/grater from vitamin bar juicer
I am assuming your juicer is the same as mine. The JC-6 White with "Vitamin Bar" and a carrot on the front.
There is most likely a tool that you insert in the back slot, but since I don't know of one, I had to get creative.
First unplug the juicer and undo the side locks, remove the clear cap. Look in the back, there is a 2-inch wide slot where you can see the motor and locking mechanism.
Take a butter knife and hold the mechanism in place. Use your other hand or have a partner spin the mesh/bladed bowl counter-clockwise.
With just some effort and a small "pop" noise, the piece should be free.
I searched forever for a solution, I hope someone with a similar plight finds this helpful.
Posted on Aug 07, 2011
Need to buy grater and filter unit
Will any grater and filter unit serve, or do you have something more specific in mind?
Jul 20, 2013 | Juicers
How do I remove the grater/filter from juice collector to clean it? Also the juice collector from the drive shaft? Thanks
You have to lift off the juice collector (the black part around the grater)-you have to use a little force-then you'll be able to take out the grater.
Jan 10, 2011 | Maximatic EJX9700 Juicer
How do you take the grater off the juiceman2 the part that the fruits and vegetables get grated. Thank you
how do you take the grater off the juiceman2 the part that the fruits and vegetables get grated.
Dec 12, 2009 | Salton JM411 Juiceman II Elite Juicer
The plastic screw, which the grater is screwed onto (looks like part of the motor) is broken.
I had the juicer for exactly two weeks and the same piece broke. The little plastic part in which the blade screws onto. Called the company and they were actually no help at all. Please don't waste your money!
Nov 14, 2009 | Jack Lalanne Power Juicer 250 Watts
Jun 21, 2009 | Jack Lalanne Power Juicer 250 Watts
Breville je2 (anthony worrell juicer) lost the blade!! slicer!!! thing
Am currently looking for a spare part for mine. If I fail to find it, u can have my grater bit!!
May 02, 2008 | Breville JE3 Juicer
Cleaning my juicer
Generally you will have good luck with this item - however after using it for a while here is the problem people are stating in other reviews. You cannot get the basket our for cleaning. Unfortunately there are no instructions or troubleshooting or anything on the manufacturer's website for fixing this..
Here's the problem...There are 3 little captured balls on the basket that engage into holes into the juicer to hold it into place when you load it. The problem is that over time - the balls get juice in them. Then you store the thing with the basket locked into the juicer. Then from sitting in your cupboard - the juice dries and the balls are stuck. When they get very sticky they do not float in their cavity they are stuck. Then after you juice the next time - you cannot get basket off. basket is stuck and you will destroy the juicer if you try to pry it out with excessive force.
If you have this problem and you are lucky enough to be reading this - I have figured out the fix on my own...
You need to fill up a large tupperware, rubbermaid, whatever - bowl about 3 inches deep with hot water. Then take the juicer with the clear cover off and flip it upside down and into the hot water. Make sure the water is covering the entire basket area, but not so deep it goes into the motor area. I let it soak for about 3 hours, but I don't think you will need to do it for that long. When I took it out of the water I was able to pry the basket out with very little force. This is when I discovered this flawed design with the balls. Now I rinse the little ball bearings really good after using and dont store it connected. Then before connecting the basket to the juicer rinse the little bearings and push them in to make sure they are freed up before each use.
I used it probably for a year or so about 40 or 50 times without this issue, but let it sit for about 4 months - which is why I believe it caused these balls with juice in them to get so frozen I couldn't remove it.
Good luck. It worked for me.. this should work for you!
Tom
Mar 23, 2008 | Juicers
How do u wash this?
if you have a jack lalanne it comes with an orange handle that fits into the sharp cutter and you twist it to tighten/loosen the blade. hope this helps
Dec 04, 2007 | Juicers
Juicers Logo
136 people viewed this question
Top Juicers Experts
eyecam
David Payne
David Payne
Tom Chichester
Are you a Juicer Expert? Answer questions, earn points and help others
