Question about Cycling
17n80c3 transister ic mosfet for 48 volt smps battery charger
17n80c3 alternet pats
SOURCE: I nedd a schematic for a Yamaha 48 volt Golf Cart
THEY ARE SPS425
Posted on Apr 25, 2010
c1apton15
  • 3400 Answers
SOURCE: power supply prpblem .dead set.the
If you have manual, schematic is in the back pages. If not go to Behringers' site and download PDF (I believe it's under support)
Posted on Mar 03, 2011
emissionwiz
  • 75822 Answers
SOURCE: the last battery in line keeps going dead and charger shuts off after 20 mins
Have the battery tested, it may be defective.
Posted on Jun 15, 2012
  • 6702 Answers
SOURCE: philips dvd ic blast in smps section
You best buy a new, or when in warranty, bring it back to the store.
Posted on Mar 09, 2015
Testimonial: "but it is out of warranty now I make ready the board but I dont get the number of the IC if i get it that dvd will work"
gopakumarg43
  • 74136 Answers
SOURCE: aiwa TV a219 no sound?. checked Smps volt and ic tda2007a fine.
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Posted on May 13, 2015
Charger works but cant get it to charge when plugged into my cart 48 volt
This can be one of several problems. Make sure charger works on another cart first. If it does then check total voltage of your cart, has to be at least 42 volts before charger will turn on. If you plug in the charger and it does not turn on then listen for a small click from inside the charger. That would be the relay and if it operates then your voltage is ok and you have something else wrong. If you don't hear the click then check the small gray wire at charger receptacle. It sometimes breaks just inside the receptacle, Without this sense lead, charger will never turn on. If all batteries, wiring, sense lead, fuse in the sense lead are ok, then it might be the OBC (on-board computer).
May 13, 2015 | Golf Cart Parts & Accessories Energy...
How the SMPS is working in telecom? What are the functions of SMPS? How it is Converting AC to DC? What are the parts are there inside the SMPS and their function?
smps involves ac to dc and dc-dc switching at high frequency because the type of a transformer in smps is a high frequency transformer and a current gain due to the ferrite application.to do a dc to dc switching you need a mosfet,smps ic e.g uc3845,dc capacitor and some passive components.
Aug 31, 2014 | Eaton Powerware® 9120 UPS System
Smart ups 1500
Thanks for the info Dmar.
If you would like pricing on replacing the UPS (entire unit) let me know and I'll be glad to help.
If you need UPS, Surge, or Power Related help contact:
Inside Service Sales
Daniel Salazar 800.260.2259 daniel@psihq.com
Power & Systems Innovations, Inc.
customerservice@psihq.com
Power & Systems Innovations, Inc. is an Elite Certified Service
Sales Partner for APC/MGE brands manufactured by Schneider Electric
Visit us at www.psihq.com
Apr 11, 2014 | Computers & Internet
Eee pc x101 won't charge
You need a new AC charger the wires wear out very often with constant plugging in and out im on my fourth one.Buy the full charger and cable.Ebay less than a tenneerr
Aug 17, 2012 | Asus Notebooks Asus Eee PC X101CH-EU17-BK...
I've been charhing the battery for 48 hours and no charge! any answers?
Kw How old are the batteries and have they been sitting up for a long time? If this is the case the charger cannot pick up really low batteries and charging them for 48 hours won't help. Unfortunately you have to get 2 new batteries. Your chair requires 2 U1 batteries. Now if the batteries are fairly new and when you plug the charger into the joystick you should be getting a red light and a yellow light on the charger. When fully charged the yellow light turns green. If you have both lights and it never turns green bad batteries if no lights or just the power light bad charger, If you have a digital voltmeter you can set it on 200 volts dc and place the leads in the two outter charger plug holes on the joystick. It should read the battery voltage fully charged 25-27 volts HOPE THIS HELPS
Sep 06, 2010 | NRS Hoveround MPV 5 - Used Power...
Philips X50 charging problems
1st remove Battery after few min insert battery and connect charger Then power on laptop.If not on check Power Mosfet or Power ic.
Jun 27, 2009 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
Samsung 953BW monitor alwyas goes to blank screen
first u will check the signal cable then check crt base [ if lot is arcking ok] replace crt base check filament volt,g2 volt,g1 vot .....etc,then u r chek 5v reg ic in supply out on smps,eprom chip and check H OUT transistor base voltage u r problem not solved about this information pls ask again to me may i help u.......
May 16, 2008 | Computers & Internet
Battery`s dont last
Warp the batteries in few plastic bags.
Place them in the freezer for 48 hours.
After 48 hrs,it them air out for another 48 hrs,
The expand and contraction may help breaking the salt bridge.
Mar 15, 2008 | Icom IC-R10 Handheld Scanner
Cycling Logo
26 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
