My t.v. will not power up or turn on
Once I turned off my t.v. it won't turn back on. I've checked one fuse and it didn't seem blown. is there any other fuses? It worked great until this. I usually leave the t.v. on all night when i'm at work. i've been doing this for about 2 or 3 months and then one morning i turned it off and that was it,nothing more.
  • 525 Answers
What it the brand and model of your tv? try to be specific
Posted on Oct 24, 2008
My compact refrigerator won't turn on after a defrost
change the regulator... your regulator is faulty
Oct 09, 2012 | Traulsen Refrigerators
Tv won't turn on. It turned off after a few minutes and won't turn back on. We opened it up and replaced the fuse.Didn't change anything. A friend said that it just seems to not be getting any...
does the power light flash three times slowly then stay off? If so chances are its just the CP150, cp120 and CP114 capacitors. There is the RCA repair kit by that same name available from www.tvrepairworld.com which has the capacitors and the CD with repair instructions
Oct 25, 2011 | RCA HD52W56 52" Rear Projection HDTV
Olevia 537-b11, blue light won't come, even when power cord is replaced. Please help!!!!
Since you've already replaced the power cord and still the led light won't came on, this is an indication that the power supply board of your unit is dead. If it is not under warranty period(if so, avail it because the manufacturer will fix it for free) open the back cover and check the continuity of the fuse using the multimeter, if you found it open replaced it with the same current(ampere) ratings and then try to turn on the TV. If the replacement fuse blew again, this is an indication of more serious problem on that board. If the replacement fuse didn't resolve the issue, other parts on that board gone to malfunction as well. If this is the case, I would advice you to replaced the entire board for your convenient. The cost will almost the same rather than troubleshoot it. Check the actual part no of your board and check this LINK.
Hope I helped you.
Have a nice day!
Thanks for using fixya.
Sep 09, 2011 | Olevia LT37HVS 37 in. LCD HDTV
Daughter unplugged tv without turning it off first. Now, it won't turn back on from the remote or the monitor panel on the front of the tv. It's a Samsung 1080 LCD. Only 6 months old. I've...
hi if you have at least a basic knowledge in repairing in any electronics as my recommendations, since the problem is won't power on.first you need to open the back cover with the use of philip screw driver then start to check the power supply look for the blown fuse replaced with the same amper rated at the part. then check for any burnt or bulged capacitors. also considered the inverter ballast board if their is no burnt connectors or parts. good luck hope it will help you.
Jul 14, 2011 | Televison & Video
Have older rca tv...shut off with sleep mode...will not turn back on...tried unplugging...didn't work...now cannot get it to turn on
Try to open the back cover of your TV.Then check the fuse of your TV near the out let cord of your tv.check if the fuse is blowned or open.Replace new fuse with the same ampere.Then power on again the tv.
Jul 01, 2011 | Televison & Video
The battery tested good but i have no power to anything inside the car
You most likely have a bad battery cable or cable connection. Depending on what kind of car you have (you didn't say) you could also have burned fusible links and/or blown fuses. I would check the battery cables FIRST. All connections need to be CLEAN and TIGHT.
Also please review these articles:
My Car Won't Turn Over
What Else Could Be Wrong?
Where's The Fuse?
Jun 11, 2011 | Honda Civic Cars & Trucks
My Bernina Activa 240 won't turn on. I checked the outlets and they are fine. I even plugged it into different outlets hoping for something to work and it didn't. Can I take it apart and fix it...
Likely the problem is a blown fuse in the S-Print (power supply). You must have a grounding wrist strap when working with a Bernina Activa. They are extremely sensitive and can easily destroy the main circuit board if you don't use a wrist strap. You can get one at Radio Shack for less than $5. The power supply is the square 1/3 of the machine on the back on the handwheel side. You can remove the power supply by removing the long torx screw on the rear of the machine and tilting out enough to unplug the connector. Then dismantle the power supply until you can get to the fuse. Test the fuse with a continuity tester. If the fuse is blown, buy an exact fuse. Don not deviate. If the fuse is not blown, you may need a new power supply.
Jun 02, 2011 | Bernina Activa 140
My sharp LC-20AV4U tv did not turn on when i plugged it in
The fuse is blowning because most likely when you plugged it it, it took a power surge. And the power surge blow a proection diode. As long as you opened it up... in the power section you will see a bunch of diodes. Get a multi meter and check these diodes out. Besides the diodes... you will see a transformer.... if you are looking at the unit with the fuse to the left... then look to the right of the transformer... you will see a transistor on a metal heat sink... that could have blown also.. if that did... then you should also check the diodes just on the other side of the heatsink too.
Good luck
Dec 16, 2008 | Sharp LC-20AV4U Television
Televison & Video Logo
80 people viewed this question
Top Televison & Video Experts
Electro Med Services...
