Question about Zanussi FS1455W Front Load Washer
Zanussi FS1455W 2 beep error - replaced Drain Pump
My 2004 Zanussi started giving 2 beep codes and stopped mid cycle. It then wouldn't start at all just beeping twice with flashing start light (2 flashes) Checked this online and indicated drainage issue - checked filter/impeller and all clear - but pump not working. Checked supply to pump & getting 115volts. Checked continuity over pump contacts and open circuit.Replaced pump - machine then started but stopped at the first drain stage and now back to 2 beep and no drain. What could be the problem? Many Thanks
  • 6277 Answers
SOURCE: Our Zanussi FS1455W stops mid
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
(If these actions have not cured the problem, it could be the control board OR the main motor. Motors will show weaknesses when commanded to spin.)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jul 04, 2011
  • 1462 Answers
SOURCE: Drain pump removal on Zanussi FJR1254 Washing Machine
not easy.suggest you disconnect pump and power up independently as an easy way to check if it runs
easiest way to remove pump - and its awkward - is to undo the 3 screws holding the pump to its housing
Posted on Jun 29, 2008
SOURCE: Fault on Zanussi FS1455W
why should i tell you how i solved the problem????? you want money off of me to tell me how to solver it, so shove off
Posted on Aug 29, 2008
SOURCE: zanussi washing machine won't start E10, E40 & E50 at times
It was suggested that the pump had failed and taken out the programmer with it - expensive! Wife wouldn't wait, and bought new machine. Problem almost solved - anyone want an out of order washing machine?
Posted on Feb 04, 2009
  • 174 Answers
SOURCE: zanussi fs1455w not spinning fast under load.
May be not pumping efficently. when the spin starts the initial rush of water floods into the drum from the clothes a build up of water under the drum causes a braking action on the drum and slow spin speed.. look for partial blockage in pump chamber hoses or under sink if a spigot connection. probably not the belt as it would throw off a loose belt. Check it anyway. if non of these check carbon brushes they may on the verge of failure.
Posted on Jul 24, 2010
Whirlpool duette washer stops during cycle beeps and displays error code F
The f should be followed by a digit or two that indicate a particular fault code. A mid cycle stop with a fault code might be because of a long drain time due to a
Faulty drain pump or clogged drain filter but without the entire fault code it’s difficult to give an exact answer.
Feb 11, 2018 | Whirlpool Washing Machines
Washing machine humming but nothing else :(
if you watch carefully, the end light flashes and then stops, and then flashes again... how many times flashes?
Dec 22, 2013 | Zanussi FS1455W Front Load Washer
Zanussi tempoline not working, son twisted nob mid cycle it then stopped and wouldn't drain. Now not doing anything! Any ideas? I assume its a error code flashing up
The first step of a dishwasher is a drain / rinse drain. I would turn the dishwasher off at the socket, turn the nob to the off position only turn this in a clock wise direction IE: the direction the nob would naturally move. Turn on back at the wall and start as you would normally. The dishwasher will empty the water out in its first step then should cycle through as normal.
Feb 08, 2013 | Dishwashers
Start/Pause light flashes, won't start. No error code. Pump or hose blockage?
It is a common fault that the drain fails to work in most machines in a period of time and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged. Now remove the drain hose clamps and remove the drain pump/valve, clean the drain pump/valve, use back flushing to clear off all dirt. Now test using power to see if this works and can be simulated. When refitting, the hose must be tightened properly. If the pump/valve does not work even with power then it must be replaced. If there is intermittent power to the drain valve/pump then the program controller unit is a suspect.
Cleaning a pump:
Finally the washer must be placed with a tilt- use a spirit level- so that all water will drain to the outlet port and thereby there is no residual water remaining.
Replacing the pump on a Bosch machine, please check this link for tips:
Jun 28, 2012 | Zanussi FJS1225W Front Load Washer
Machine stops half way through program
One looses touch with all the codes available, but normally if washer stops mid cycle its due to a blocked or faulty drain pump. OR incomming water is to slow or defective inlet sensor. Switch off and start from the beginning. See if you can get machine to drain by moving the timer etc. If not, rectify pump problem. Take note where in the cycle the problem arises.
Jul 21, 2010 | Zanussi ZWD1680W Front Load Washer / Dryer
Error E20
zanussi error E20 suggests a pump/draining problem. remove pump/filter and clean it all out. its located at the end of the drain hose at the bottom of machine. power off. it might need replacement.
Nov 01, 2009 | Zanussi ZWF1430W Front Load Washer
Stopped mid cycle
"F21" (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Sep 05, 2009 | Kenmore Washing Machines
EFO, E10 error Message
Frigidaire, Zanussi, AEG, & More....
EFO = Filter Blocked (low flow) and it is accessible from the bottom front of the machine.
1. there is a blockage in the filter or drain hose.takes too long to drain out.
2. over dosing of powder or liquid. again can cause an air lock in the pump which slows the drain pump down.
Check the filter and drain hose and test again. this fault will only come up at the end of a cycle.
You do not need to reset the machine to get rid of the fault code as this is automatically deleted.
Run an empty load with no detergent in an attempt to get rid of the code.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 09, 2009 | Frigidaire GLTF2940E Front Load Washer
Zanussi turbo dry 1200
Try cleaning out the pump, and main hose to sump. If problem persists replace pump.
Slim Jim
Nov 12, 2007 | Zanussi FJS1225W Front Load Washer
Zanussi FS1455W Front Load Washer Logo
112 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
