Question about HP LaserJet 1018 Printer
My HP laserjet printer is showing Out of paper repeatedly. How to fix it?
The printer shows the OUT OF PAPER message despite of a fully loaded paper tray.
  • HP Master
  • 1,684 Answers
The out of paper erro can also be caused by worn pickup rollers. These rollers are used to pickup paper from the paper tray and feed it into the printer. When they get worn down they can't grip the paper to pick it up so the printer thinks the paper tray is empty. The pickup roller runs $3.99 and can be installed by the end user, no service center is needed. The part number is RL1-0266 and looks like this:
My HP laserjet printer is showing Out of paper rep - 2_9_2012_9_43_58_pm.jpg
We carry them in stock if you would like to order one here:
http://www.ccl-la.com/catalog/product_info.php?products_id=202
I hope this helps, if so please rate my solution.
BuddyMc
Posted on Feb 09, 2012
  • 35 Answers
SOURCE: HP Laserjet 3050 No paper pickup
NOTE:
If the printer DOES NOT PICKUP paper .
That is a jam also so the places to look are smoth rollers or smoth spots on the rollers.
trays not adjusted properly and if they have it some trays have a coustom/standarsd switch (should be in standard for letter/legal paper
Posted on Jun 13, 2008
  • 138 Answers
SOURCE: hp 5550 laserjet paper jam
Thhis error is usually due to a dirty photcell (sensor) in the tray 2 paper feed assembly or a broken sensor flag in the same assembly. Start be removing all cartridges and the transfer belt. Look in the bottom of the printer below the lowest cartridge slot for a removeable cover. That's the area your problem is probably in. I have incuded a link to a free PDF of complete service manual below. Good luck.
http://www.feedroller.com/Store/Service%20Manual/Color%20LaserJet%205500-5550.pdf
Posted on Aug 03, 2008
dnewcombe1
  • 1564 Answers
SOURCE: My HP LaserJet 3050 will not grab and feed paper
Open the top as if you were going to change ink cartridges. Find all rollers yuou can and wipe them with a t-shirt type material dry. Do not use any liquids unless you can get some rubbing alcohol. Turn the wheels and claen them as best as is posible. Open the paper jam door and do the same to all rollers in site. Any way you can get to the rollers, use it. This should solve your problem. Also try fanning your paper before loading it. Thanks, Dana
Posted on Sep 04, 2009
  • 240 Answers
SOURCE: default paper tray selection for HP LaserJet 4200tn
1) When the printer receives a print job, it selects the tray by trying to match the requested paper type and size with what has been loaded in the trays. Using an “autoselect” process, it searches all available trays for the paper that satisfies the request, starting with the bottom tray and ending with the top tray (tray 1). The printer begins printing the job as soon as it finds the proper type/size.
2) If paper is loaded in tray 1 and tray 1 is set "TRAY 1 TYPE=ANY" and "TRAY 1 SIZE=ANY" on the
Paper Handling menu, the printer will always pull paper from tray 1 first.
Posted on Dec 10, 2009
shawn38
  • 200 Answers
SOURCE: HP laserjet p4014n
Check the media settings for your paper trays. Make sure they are set properly, also check the diver media settings. Is the problem happening with a specific print job? If it is check the page setup for that document.
Posted on Mar 06, 2010
Hp laserjet 1536 dnf MFP. How can I repair document feeder?
how to fix and repair the adf doc feeder Q5997A hp laserjet ...
? 1:36
https://www.youtube.com/watch?v=lpTj4jiLaY8
Dec 12, 2011 - Uploaded by BrokenPrinter1
Parts Available @ BrokenPrinter.com how to fix and replace the rollers on a hp laserjet 4345 mfp and color ...
Fixing Paper Pick-Up Issues - HP LaserJet Pro M1212nf ...
? 5:40
https://www.youtube.com/watch?v=ZXtAhSDYqyU
Jan 23, 2013 - Uploaded by HP Printer Support
Learn what to do if your HP printer does not pick up or feed paper from the ADF when you do have paper loaded, and a Doc feedermispick error message display... ... FIX YOUR PRINTER: ERROR: Printer Does not Grab Paper fromTray ... Kit m3027 mfp- Kit Hp m3027 mfp - Kit Mantenimiento m3027 mfp ...
'Document feeder mispick' Message Displays on the Control ...
Dec 13, 2015 | HP Office Equipment & Supplies
HP LaserJet 1020 paper jam alert
Here's a video Harshit kumar suggested as a solution to your problem from YouTube:
Fixing a Paper Jam - HP LaserJet 1020 Printer
Apr 17, 2013 | HP LaserJet 1020 Printer
Printer shows "PC LOAD LETTER" when asked to
Have you made sure the tray slide that buts up against the paper is snug? I had this issue yesterday and that was the only issue. You may have to go into your settings and adjust the paper settings.
Aug 31, 2011 | HP LaserJet 4 plus Printer
I have a HP Laserjet 2420 and show error code 41.03.00
Un expected paper too lengh, check papers are loading one by one or more then one at a time loading in side?..If multi papers are loading, replave separation padClean all paper path sensors..
Aug 19, 2011 | HP LaserJet 2420 Printer
My HP Laserject 5100 Printer has the Paper Jam Problem. After that, I check printer. But i haven't seen any paper jam. When i print out, nothing show on paper and show the paper jam.. How to fix?
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Jul 04, 2011 | HP LaserJet 5100 Printer
Unable to print on network it is showing offline or load letter. How to resolve?
I can help you with your HP Laserjet 4 printer problem.
Ensure the paper is loading correctly from the paper tray by reloading paper and printing locally.
If the printer prints locally, then paper loading is not the problem. Select your printer from the Control Panel > Printers list, right click and choose Sharing to re-setup printer sharing.
I hope that helps.
Aug 30, 2010 | HP LaserJet 4 plus Printer
Printer is loaded with paper but get message
Although you really haven't given me enough information, I will posit and response for you.
A "Load Paper Error can be caused by the application telling you to change the "TYPE or SIZE" of paper that is in your paper tray.
For example, The application thinks you want the page printed on "Letterhead" paper, but it know that you have plain bond paper installed.
So you are sent a change paper type message.
The fix is to hit go and skip around that error.
The actual fix is to make sure that your printer driver, application and the printer are all set to the same size paper and type paper.
Don
Nov 05, 2009 | HP Hewlett Packard LaserJet P1005 Printer
My HP Photosmart C6150 shows an "Out of Paper" message. I have repeatedly removed paper and added it back, message still shows & it won't print
Dear sir your printer problem is paper sensor when you stay paper then paper switch is open but this printer paper switch lever is broken or displace please chack it then solve your problem
Jul 20, 2009 | HP Photosmart C6180 All-In-One InkJet...
79 people viewed this question
Seeker5211
Seeker5211
