Question about Maytag MGR6772 Gemini Gas Kitchen Range
Igniter stays on on all four burners all the time. Had to turn off breaker to stop. Started sparking all by itself with burner in the off position.
  • Anonymous Mar 27, 2014
    when the buttons are in the off position the burners are still clicking
    Problem Solver:
  • 12 Answers
Usually this happens when water or some type of liquid gets on one or more of the igniter switches. Let it dry for 48 hours, turn the power back on and see if it keeps on clicking. If it does, one of the switches needs to be replaced. Not a very difficult job. Hope this helps, APP tech http://www.AppliancePartsPros.com
Posted on Aug 08, 2006
Our Thermador Pro-Harmony gas range just started to make clicking noises and it will not stop. Nobody turned the stove on. It started clicking on its own. How do we shut it off?
Usually a clicking sound from a gas range is the gas ignitor/igniter sparking to light one of the gas burners
...Check to make sure all functions are turned off. If all are off
could be a defective switch..check to see if you see a spark at any of the gas burners
Sep 09, 2017 | Thermador Kitchen Ranges
Jenn-Air JDG8430 Ignitor won't stop sparking after burner ignites
Test the ignitor first, if the ignitor does not spark should be the ignitor itself.
Oct 12, 2008 | Jenn-Air 30 in. JGD8430A Gas Cooktop
The electric igniters for the stove burners stopped working. All four stopped at the same time.
If all 4 stopped working at the same time, the problem is with the spark modulator.
If the igniter is working on several of the burners but not on another, (or any variation), the problem is with the igniter wiring harness.
By design, the igniter for each burner is daisy chained in the wiring harness such that if one goes, the others will still work.
Mar 24, 2015 | Magic Chef 31000 Gas Kitchen Range
I have just replaced all the ignitors and the spark control module on the cook top burners. Prior to this the back burners would cause ignition spark continually when lit. the front 2 burners could be...
first check to make sure all the burner tops are setting correctly on the burner base, if not it will make the flame uneven. the way the igniter works is once they feel the flames on them they will stop sparking. make sure the flames are not too low and they are touching the igniter. check them one at a time. if you have any questions message me back thanks
Apr 08, 2011 | Viking Kitchen Ranges
Spark igniters on the burners fire continuously
When cleaning, if the control switches get damp, they will react as you describe.
Unplug the appliance, use a hair dryer and attempt to dry the switches.
Leave it unplugged overnight and try them again tomorrow.
They will eventually dry and be OK.
Feb 24, 2009 | KitchenAid 31 in. KGCC505 Gas Cooktop
Dacor gas range igniter clicking
I did have the same problem after the house keeping people done with cleaning. They used window/surface cleaner. First I asked them not to clean the ignitor with any cleaner. Here is what I did to solve the problem
I took scotch scour pad (one that you use for washing dishes), In dry state I polished ignitor switch. It is abrading the residuals and deposits on the top and polishing it. Don't use any thing more abrasive than that. MAGIC - I don't have any more problem.
Aug 14, 2007 | Dacor Preference SGM365SS Gas Cooktop
Cooktop's electronic igniter started clicking all by itself
Check to make sure your burner caps are aligned. I had this problem, and it turned out one of my burner caps was slightly askew. Putting it level fixed the problem.
Jul 25, 2007 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
Stove burner igniter does not work.
Your problem is not the igniter itself, but the burner switch that controls the igniter. All the igniters get their power from one spark module that is mounted somewhere in back of the oven. That's why you are able to get all the igniters to spark with only one burner control turned on. This is normal. That is also why you are able to light the burner in question buy turning on another burner. The spark is being provided by a switch that is working. To answer your question: the igniter is removable, but I don't think it's necessary. Cleaning them generally doesn't make them work better. I would check the wiring from the spark module to the burner switch and/or replace the switch. I hope this helps.
Jul 18, 2007 | GE Profile JGSP48 Gas Kitchen Range
Had The same problem. I removed the top of the control panel to find out that one of the ignitor switches had turned when I replaced the four large plasic nuts on the control panel. Make sure the switches (block) are aligned, and kept aligned, when re-installing the top of the control panel. Startwreck.
Jul 15, 2007 | KitchenAid KGST307 Gas Kitchen Range
Open Questions:
Maytag MGR6772 Gemini Gas Kitchen Range Logo
168 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
