Question about Refrigerators
Plunger replacements Avanti
The shaft of the plumger has broken away from the mesh section ad will not reattach
  • Carolyn Boyd Feb 09, 2012
    Coffee French press
    Master:
  • 431 Answers
Have a look on ebay, or failing that visit the manufacturers website
Posted on Feb 09, 2012
2002 saturn sl exhaust system its located under the manifold but above the cadilitic converter... It looks like a stainless steel mesh and flexible, its 2inch pipe by 8 inches long
guessing you are referring to the flex section of the exhaust pipe that allows engine movement separate to moving the exhaust system
it is a stainless steel convoluted section enclosed insulation by the mesh and are subject to failure from work hardening of the stainless steel section from improperly maintained exhaust system mounting rubbers ( broken)
can be replaced by any accredited exhaust repair shop
Apr 15, 2017 | Saturn Cars & Trucks
How do I remove the plunger for washing?
The plunger on mine cannot be removed. I just checked it to make sure. If you remove it, you have broken the unit. Just rinse with water. The plunger should not get dirty of used properly. A rinse under running water is enough.
Jan 28, 2015 | KitchenAid Salad and Fruit Spinner - White...
I have a lav sink where the stopper no longer comes up. The plunger shaft goes down. I have removed the stopper and can see that it has a female threaded "throat", but there's nothing to...
if you look under neath your vanity you will see where the plunger goes into the drain pipe. remove it and see if your activator rod is there, if so this is what screws into the plug end. if it is not there remove your U section and see if it is in there and reattach it. if it is broken you will have to get a repair kit at your local hardware store.
Aug 09, 2011 | Kohler 7129-A-CP Lavatory Grid Drain with...
Just today had brake booster replaced. Arriving home after dark, brake lights would not turn off! Tried removing fuses-etc. - nothing works. Help! Battery will drain overnight. Thank you!
Your brake light switch is stuck. It's mounted just under dash above your brake pedal. Sounds like it wasn't adjusted properly. You can disconnect your battery for the night and reattach in AM to get back to repair shop for proper fix. Remember when reattaching cables, NEGATIVE CABLE GOES ON LAST
Jan 18, 2011 | Plymouth Voyager Cars & Trucks
We have a stainless steel french press coffee barista from Starbucks, which we purchased in 2003. We need to replace the mesh plunger. Look for options in replacing that part
I have a 2003 press that I love. The mesh plunger works fine, but the little "handle" to push down has broken off. Could you use my plunger to fix yours? I think I'm going to have to buy a whole new one so I don't mind selling you the part.
If so, contact me at emailjunky (at) mac dot com
Jan 05, 2011 | Starbucks Barista Quattro Coffee Maker
I need to find out how to take off and put on a starter on a 2004 chevy tracker
TESTING WARNING
During the following test, the starter motor must not be energized for longer than 5 seconds, otherwise you run the risk of burning out the starter motor coil.
  1. Remove the starter motor from the vehicle.
  2. Detach the field coil lead from terminal M on the starter motor.
  3. Using jumper wires, connect a 12 volt battery to the starter motor so that the negative battery terminal is attached to the starter motor housing and to solenoid terminal M, and that the positive battery terminal is connected to starter motor solenoid terminal S. The starter motor plunger should move outward; if it does not, replace the solenoid with a new one. Fig. 1: To test the solenoid plunger, first detach the field coil lead from alternator terminal M, then attach a 12 volt battery to the starter motor as shown . . . 90882g50.gif
    Fig. 2: . . . then detach the negative jumper wire from terminal M. The plunger should remain extended 90882g51.gif
    Fig. 3: Detach the other negative lead from the starter motor housing. The solenoid plunger should now retract to its normal resting position 90882g52.gif
    Fig. 4: Use an ammeter to measure the amount of current draw the starter motor uses 90882g53.gif
  4. Detach the negative battery jumper wire from terminal M on the starter motor solenoid, and check the plunger for movement. The plunger should remain extended; if the plunger returns to its resting position, replace the solenoid with a new one.
  5. While observing the solenoid plunger, detach the negative battery lead from the starter motor housing. The plunger should return to its normal resting position; if it does not, replace the solenoid with a new one.
  6. Reattach the 12 volt battery and install an ammeter to the starter motor as shown in the accompanying illustration. The starter motor should rotate smoothly and steadily with the pinion gear moving out, and the ammeter should display less than 60 amps at 11.5 volts (Samurai models), or 90 amps at 11 volts (Sidekick, Tracker, X-90 and Sidekick Sport models). If the ammeter does not display the specified values, or if the starter motor does not operate smoothly and steadily, replace the starter motor with a new one.
REMOVAL & INSTALLATION
  1. Disconnect the negative battery cable.
  2. If necessary for added under-vehicle clearance, apply the parking brake, block the rear wheels, then raise and safely support the front of the vehicle on jackstands.
  3. From beneath the vehicle, label and detach all wiring from the starter motor solenoid terminals.
  4. Remove one of the two starter motor mounting bolts and loosen the other bolt until it can be turned by hand, then support the starter motor with one hand while removing the last starter motor mounting bolt.
  5. Lower the starter motor down and away from the engine and transmission. To install:
  6. Hold the starter motor in position and install the two mounting bolts. Tighten the two bolts securely.
  7. Reattach all applicable wiring to the starter motor solenoid. Ensure that the wiring terminals and connectors are clean and free of corrosion.
  8. If necessary, lower the vehicle.
  9. Connect the negative battery cable.
Oct 23, 2010 | Chevrolet Tracker Cars & Trucks
Avanti portable dryer - drum does not rotate
The belt is broken . Call Avanti to get it fixed or take it back and get it replaced .
Oct 11, 2009 | Avanti Dryers
Avanti 12 bottle wine cooler...switch is bad. Electricity going to the switch but not turning on. Where do we get one? Avanti is NO HELP!
There is a circuit board in this that you'll have to replace,and good luck finding the part.Most of these coolers were built as throw aways,meaning when it stops working you, throw it away.
May 29, 2008 | Avanti Refrigerators
Batteries out
You can reset it with holding [SF] + [M1] ( the big button with denso on it) +[0]+[PW] simultaniously
WARNING it will clear all existing programs running on it.
After you reset it you should be able to upload new software on it
May 10, 2007 | Denso Nippondenso BHT3000 (bht3041)...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
