Question about RCA D52W19 52" Rear Projection Television
Screen looks messed up
Colors and pic messed up
  • jack43 Oct 23, 2008
    thanks for your help!
  • 905 Answers
This is probably a conversion IC that controls the vertical horizontal and color alignment
you will need them replaced as well as a few resistors
if you can't do this yourself then call an electronic repair shop , they will fix it for about $400
thanks
electech
Posted on Oct 23, 2008
My blue and green coloring is messed up on my Mitsubishi Medallion. I can't get it to have both colors normally, it has to almost be one or the other. Is this just a contrast issue, or something
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. The power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
What you will need to do is convergence. You can get a repair kit from TvRepairKits.com . It includes replacement parts,step by step instructions, support, etc.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from TvRepairKits.com . It includes replacement coolant,step by step instructions, support, etc.
Oct 06, 2012 | Mitsubishi WS-55613 55" Rear Projection...
My Canon powershot 210 IS has LCD screen. And the pictures' color appeared on the screen looks really amazing. However they look not as nice on laptop screen and the color is very poor and not as warm as...
Your computer screen may need some color adjustments. Have you tried printing some of the pics to see if the color is as amazing as on the camera? Or have you tried viewing the pics on another computer for comparison?
Mar 08, 2011 | Canon PowerShot A540 Digital Camera
The screen is all messed up! It has green and
This is a common problem. Its called a convergence failure.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 31, 2010 | Sony KP-51WS510 51" Rear Projection...
My tv needs readjusted (color,focus,etc.)Is there an easy way to do so myself? i got a 1986 45'' RCA projection tv.it started of with just a blury spot across the top but after i messed with it the whole...
First pull back Look for screen and focus block you will have 3 controls ontop for focus and 3 controls below for adjusting screen drive to each Tube R/G/B
turn color off on Menu NOW try to Adjust the red,greenand blue screen drives as close asyou can to a Black and White picture then turn Color back on in Menu also adjust Focus for each Tube Be sure to Clean Top of Tube Lenses of dust&dirt Just in case Post me your Model and Chassis Number it will be on back of TV some RCA Focus&screen drive Block maybe in front of TV if so remove front bottom panel their you will see control box.
Nov 10, 2009 | Televison & Video
Pictures messed up between camera and computer
It sounds like jpeg file corruption. What do the pictures look like on the camera's screen?
If they look OK, try using a card reader to transfer the pictures and not the camera. do they transfer OK now? If not then the card may have a problem OR there is a problem with the USB on the computer that is causing it.
If they look wrong on the camera then it's possibly the card at fault.
What I would do is download what pictures you can and then give up on the others and reformat the card in the camera. That will clear the card as if it as brand new. Take some more pictures and see if you can transfer them successfully.
I've had a card fail (so far only 1) and it's really annoying, reformatting didn't help either, it was still faulty!
There is always the possibility that the camera is at fault! I hope not.
Try shooting some pictures in RAW format instead of jpeg and see what happens then.
Aug 07, 2009 | Nikon D80 Digital Camera with 18-135mm...
My screen is showing like multicolors & it still takes pics
Hi There, If your screen still lights up, sounds like the LCD Panel is cracked.
Dec 11, 2008 | Panasonic Lumix DMC-FX01 Digital Camera
MITSUBISHI 65"
You need to replace both convergence ICs Number STK392-570 If your model number is a WS-65809 you can get new replacement ICs at the following link and they provide instalation instruction with pics as well as free on line tech support so you can do the repair yourself.
http://servicemanuals.vstore.ca/
Apr 30, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Goldstar 27
In picture number 2, I saw some blue also. So I'd guess that the red gun is not firing. This could be a transistor on the board on the back of the picture tube, or it could be a bad picture tube. I would replace all three transistors on the PC board, if the problem remains, it's probably the tube.
Hope that helps...
Geno
Apr 02, 2008 | Televison & Video
RCA D52W19 52" Rear Projection Television Logo
35 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
