Question about Canon PowerShot SD400 / IXUS 50 Digital Camera
White screen when taking pictures in daylight
Pretty much as the subject describes. i had my camera fixed for a broken jammed lens by canon. camera worked perfectly than i noticed that when in the daylight even in overcast with pretty much no light at all the screen will be a bright white with maybe faint shadow of things. but i can take pictures in bright light indoors with flash and theyre perfect. it makes no sense to me, someone help!!!
    Problem Solver:
  • 9 Answers
Go to the menu screen for LCD contrast and adjust, it sounds like it is to high. Kinda like a back light for a plasma screen.
Posted on Nov 26, 2008
Picturess are too green
there are advanced color correction modes,
Blue or dark pictures/videos
Keep your shooting distance inside of 2ft to 3ft, depending on
visibility and ambient light.
If you are using only one light, considering adding another light
(dual lights) or/and external flash accessory. The ideal
set-up is a combination of a light plus flash.
Consider purchasing the SeaLife Wide Angle Lens (SL975). The
fisheye lens allows you to get closer to the subject and fit more
into to picture frame.
For SeaLife camera with external light accessory (No external flash):
1) Set the camera's scene mode to Sea mode or Snorkel mode
2) Change camera's PHOTO and VIDEO White Balance
settings to DAYLIGHT.
For SeaLife camera with external light and flash accessories:
1) Set the scene mode to Ext. Flash mode
2) Change the VIDEO White Balance setting to DAYLIGHT.
For other underwater camera brands:
1) Set the Scene mode to "Auto" or "Underwater" scene
mode, as recommended by the camera manufacturer.
2) You may also need to change the White Balance setting to
DAYLIGHT depending on the camera's underwater color
correction or if pictures/video turns out red.
Mar 05, 2014 | SeaLife DC1200 Digital Camera
When taking pictures outside or from inside through a window, the picture comes out white with faint red outlines of some images. Inside the house and darker areas it takes pretty good pic's. What can be...
First the camera has a flash to allow for darker areas to be illuminated to capture pictures. The type of camera may bot allow to capture outdoor pictures with the camera flash on. Power off the flash when outdoors to capture daylight pictures.
Jan 30, 2011 | Canon PowerShot SD700 IS Digital ELPH /...
Canon powershot A470 problem when i click photo then white image come? but when i use it night it is normal. but during daylight or with sunlight.. white image appear....and every time i take a picture...
The shutter flex cable inside the lens is broken. Happens to all cameras from Canon A4xx series. At day the images will be overexposed with horizontal lines on it, but it could look better at dark / night. The FLEX has to be replaced. Canon doesn't supply new flex cables for these, but there are some cheap copies on ebay. But as these brake very often, I wouldn't suggest you investing money in this camera, because it will brake again sooner or later.
Jan 26, 2011 | Canon PowerShot A470 Digital Camera
White screen for all outdoor pictures
Sorry to say this sounds like a stuck open shutter mechanism. Put the camera in any mode other than auto and make certain that you turn the flash OFF (you don't want to blind yourself in the following step). Next look down the center of the lens barrel and take a picture. You should see a tiny flicker (wonder where that website got that name?) in the center of the lens as the shutter opens and closes. If no movement is seen then it's likely stuck.
Some people have had success in unsticking Canon S2 IS shutters with the following procedures. It may or may not work for you:
May 09, 2009 | Canon PowerShot SD30 Digital Camera
Camera takes white pictures in daylight
Sounds like over exposure due to the shutter not closing all the way. test video out. should work fine. shutter mechanism will need cleaning
Apr 25, 2009 | Canon PowerShot A630 Digital Camera
Canon G9 digital camera
There are two stages to the shutter release. The first stage is the focus stage pressed half way down and the second stage is the actual shutter release. Always press the shutter half way to get the camera focused first then press all the way down when the camera is ready to take the shot. Check to see how the settings are with regard to how it focuses (9-point, face recognition, etc). When the camera focuses you should get a green box or multiple green boxes depending on your settings. That tells you the camera is ready to take the picture. Pressing the shutter all the way down at once from the beginning will cause the pause you describe since the camera has to first focus then shoot the picture. Depending on the subject or subjects the camera may take a second or two longer to focus. With good lighting my G9 focuses pretty fast. Hope this helped.
Aug 31, 2008 | Canon PowerShot G9 Digital Camera
Camera lens might be broken
My friend droped my camera and the lens is sideways. i can look at my pictures, but when i want to take a picture it is black and says lens error. what should i do?
May 21, 2008 | Casio EXILIM EX-Z70 Digital Camera
Broken lens
but you would have to take it to get fixed and its pretty pricey
your better off just buying a new camera
May 18, 2008 | Kodak EasyShare One Digital Camera
Camera jam
All the R series Ricohs have a pretty complicated lens system employing 2 swing-out lenses which can get stuck pretty easily, or worse, broken. If you are very good at taking things to bits you might have a go at fixing it (I've done several that were not TOO bad) since picking up one on Ebay with a good lens unit is almost impossible.
Jan 13, 2008 | Ricoh Caplio R5 Digital Camera
My camera display screen is only showing weird colors but works when I take pictures
A loose connection perhaps
A gentle taspe may restore it - or it may not.
Canon support will advise on your next move
Sep 14, 2007 | Canon PowerShot SD550 / IXUS 750 Digital...
Canon PowerShot SD400 / IXUS 50 Digital Camera Logo
206 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
