SOURCE: unable to log into router to open ports
To log in to the router in order for you to do a port forwarding you can follow the steps from this link, but if the default username and password didn't work reset the router so it will be back to its default settings http://portforward.com/english/routers/port_forwarding/ZyXEL/P-660HW-T1v2/Age_of_Empires_III.htm
SOURCE: Can't connect my Ipod touch to my router?
i had the same problem too with my'n. My issue was on of my setting's was set to block that wi-fi connection. Try switching your setting for finding internet connection from automatic to manual. that should do the trick!
SOURCE: Zyxel P 660HW T1 how to apply DMZ mode for a CCTV
Network - NAT - Port Forwarding - Default Server, Put the IP of your CCTV Hardware/PC
This IP will accept connection on all ports.
I never did this yet so any success please reply.
SOURCE: Can't connect my router to my Ipod touch?
ok do this if it is already showing your router up on your portable device but it has that security lock and you are unable to join or need a password which u dont know lol go to that network and on the top push forget this network. than go back and click on for other location. than for the name put in your router name usually 5 characters long make sure u use capitalization cuz its case sensitive. than select what kind of key u have it should say right on the side of your wireless router. than type the key in usually a wep key and u should be set to join it if it doesnt auto matically do soo
