Question about Stoves 720EF Electric Double Oven
Wiring diagram for grill element for samet stove
  • 250 Answers
SOURCE: schematic wiring diagram
I have a copy of a STOVES 720EF Manual (including wiring info) posted on BT Digital Vault. Supply an email address and I will give you access to take a copy.
parsonm
Posted on Jan 20, 2009
  • 250 Answers
SOURCE: I need a wiring diagram for Stoves 720 EF
Post your email address and I will give you access to my BT Digital Vault where you can have a complete copy of the handbook which includes schematic and actual wiring diagrams.
Posted on Mar 25, 2009
  • 250 Answers
SOURCE: No Grill operation for stoves 720ef
Supply an email address for you and I will grant you access to my BT Digital Vault where a copy of the complete handbook is lodged. It includes circuit diagrams.
With your fault, can you here the switch operating, if not it just may be stuck?
Posted on Dec 16, 2009
bayyagg
  • 1672 Answers
SOURCE: mixed wires up going into grill element can you
Pls go to this site............
He is the one that handles ur probs... and his the only one got the diagram!
http://www.fixya.com/users/parsonm
Hope
Posted on Dec 04, 2010
  • 250 Answers
SOURCE: wire diagram for top grill element
The diagram is in the handbook. If you don't have one and need a copy, I can give you a pdf copy. All I need is an email address and I will send it to you.
(By the way, the grill only operates with the door down. There is a microswitch in the right hand side of the oven that stops the grill operating when the door is up).
Posted on Jan 08, 2011
Samet model 611 stove wiring diagram
Request the diagram directly from Samet.
Aug 08, 2016 | Stoves Ovens
Wire diagram for top grill element
Dec 04, 2010 | Stoves 720EF Electric Double Oven
Grill trips my electrics on Stoves 720EF
I had problems with tripping and it was a faulty RCB on the consumer unit. But it wasn't just one appliance causing the problem.
Have you isolated it to the top or bottom oven. If it is the main oven, then it could be anything associated with the operation of that component, i.e. the oven control knob,the oven thermostat, the element, the element fan, the overheat thermostat all could have insulation that is breaking down that could cause this problem.
Before you go and buy anything and if you have the time and patience and confident enough and know what you are doing, I would remove the oven from the cupboard, take off the top and back covers, note the wiring for the element, take the leads off the element and run the oven with the element disconnected and see what happens. That should prove whether it is the element or anything else.
BE CAREFUL.
Jun 06, 2010 | Stoves 720EF Electric Double Oven
Fitted new mainoven thermostat to Stoves Newhome built-in oven & grill Model No. 444445062 Serial No.41209452 other data on plate EFa900h need a wiring diagram,couple wires can adrift. Every thing...
I can only speak for the 720. If you want a circuit/wiring diagram for this one, then I need an email address. I will then register this on my BT Digital Vault and you can the download the whole manual.
Looking at the diagrams, the neon for the main oven has white and black wires.
The white wire from the main oven neon goes onto the same connector on the thermostat block as the white wire to the oven element. The black wire from the neon goes to a common terminal on the top oven neon, which then goes onto P6 of the top oven switch (still black wire).
If you need any more info, then let me know.
Apr 01, 2010 | Stoves 720EF Electric Double Oven
Dec 12, 2009 | Stoves 720EF Electric Double Oven
I have a Samet built-in oven (linea italiana #DG941ET) and I want to know what its temperature gauges mean. They range from 1 to 7. Thank you.
Samet Double oven - Small oven on top. Glass door just shattered whle cooking. Can i Buy a new door or have the glass replaced in South Africa.
Jun 16, 2009 | Ovens
Mar 17, 2009 | Stoves 720EF Electric Double Oven
Dual grill does not work
It sounds like you have no power to the the grill. Check the grill circuit with a tester until you identify where you have power to and then check for loose connections or broken wires from there on.
Nov 29, 2008 | Stoves Premier 720EMa Electric Double Oven
Schematic wiring diagram
parsonm
Oct 30, 2008 | Stoves 720EF Electric Double Oven
Stoves 720EF Electric Double Oven Logo
Top Stoves Ovens Experts
ashburton
Dan Webster
Dan Webster
Are you a Stoves Oven Expert? Answer questions, earn points and help others
