What is the cause of intermittent power of matrix tv model MX - TVS1414A?
3 Suggested Answers
gopakumarg43
  • 74383 Answers
SOURCE: How to unlock my TV matrix model no:MX-LCD3266 with a remote control.when I try to open it become green and suddenly it become red
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Unlock procedure and to override the password lock of many popular brand TVs and other devices are given. Search the site by type in this key phrase "How to unlock television"; in the search box at the top left of the display window, to get gathered related posts.
I don't think it might be due to a lock. Might be some other problem to its main board circuit. Contact any service technician.
Posted on Dec 29, 2016
gopakumarg43
  • 74383 Answers
Posted on Dec 30, 2016
Dec 29, 2016 | Televison & Video
Matrix mx t4 treadmill
Maybe it has a tip over sensor and you set it off while moving it? Check your manual to see if it has one and how to reset it.
Jun 08, 2014 | Exercise & Fitness
Matrix codes
028,020,021,025. Try these codes. If you wish to get more codes and other details check:
http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/
Both the sites have setup code list, and setup procedure to many popular brand remote controls. Check the site in 'Mosaic' view. It will make search easy.
Jan 08, 2014 | GE JASRM24912 Remote Control
I get a E 7 system error what is this error
test the 2 alternatives for this error 7 .God bless you
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
Oct 06, 2013 | Matrix Commercial Treadmill: Mx-t5x
My matrix MX-T5x start running and stop in seconds. With the error code E7. What is the problem ?
By E7 it means Speed sensor feedback missing. You have to check the speed sensor mounted near the motor pully. Remove the speed sensor and clean it well Then refix it then check the tread mill by powering ON. If then also the problem remains the same , You have to replace the speed sensor.
ok
Aug 02, 2011 | Matrix MXT5 Treadmill
Hello, I have an ASUS KBV-MX motherboard. Suddenly from the last few weeks i am not getting any display. When i start the system, it will go through till the windows log and then suddenly it gives an...
Replace your power supply unit with a better wattage rate. BSOD is sometimes cause by an intermittent power supply.
Thanks for using Fixya.
Jul 28, 2010 | ASUS K8V-MX Motherboard
Clock and radio
If your clock doesn't work, it is probably because there is an internal fault within the clock module, itself. This is a common problem in many of the Japanese models - the Toyota Matrix included. The clock may be intermittent or have a dead disply.
If your Matrix clock is dead or intermittent, you can remove it yourself and have it professionally refurbished by Dr. Clock. He offers a lifetime warranty and does top-notch work.
Jun 24, 2009 | 2005 Toyota Matrix
Tv not playing sound on my surround system
Check if the tv has an option in setup to turn ext speakers off.
If so turn them back on.
Hope it helps.
Nov 26, 2008 | Televison & Video
Insignia LCD TV loses power
Probably it is a faulty power board.
Oct 06, 2008 | Insignia 37" LCD Flat-Panel HDTV
Panasonic 50 inch plasma
You should call for warranty service. If the set is very new try to get it exchanged.
There are some very heavy duty power supplies and many high power matrix drivers used in Plasma sets.
The description sounds like the noises are very loud. It is normal with any of these TV sets, if you put your ear right up to the back of the set at the vent holes you will hear some noises. These would be some acoustic harmonics from the power supplies and related circuits.
I am wondering if it is possible that there is something that is becoming less stable. If the set is working very well without any failure, so-far this is a very good sign. Before it gets to be a problem, I would have this checked.
On many models of these sets, they use fans for cooling specific areas. A bad fan can cause noise.
Jerry G.
Apr 13, 2008 | Panasonic 50 in. Plasma TV
jasbo
jasbo
