Question about Shimano Cycling
How to install cable for shimano st-ef28 8 spd shifter v brake combo
  • 1137 Answers
SOURCE: How to dismantle and re-assemble the lever
Here's the diagram:http://fish.shimano-eu.com/media/techdocs/content/cycle/EV/bikecomponents/ST/EV-ST-T400-S-1970_v1_m56577569830613258.pdf The lube in them tends to dry out and harden over time and needs to be flushed out with whatever is safe for the parts (cleaner/degreaser) and then relubed with some high quality lubricant. The spray stuff doesn't stay around long enough. Ask your local bike tech what he uses.I used saxophone key oil.
Posted on Aug 11, 2009
  • 15 Answers
SOURCE: How do I replace rear shifter cable in shifter
ok this is a little hard to explain in words but the important thing is to make sure the chain is on the biggest cog, pull the cable through the deralier tight and fasten. don't pull it too tight however. you may need to fine tune using the h/l screws but if it was in tune before then it shouldn't need too much adjustment.
Posted on Oct 30, 2009
dunnbiker
  • 8546 Answers
SOURCE: replaced broken shifter cable on
Adjust it correctly...
http://www.parktool.com/blog/repair-help/shift-levers-shifters
Posted on May 17, 2011
dunnbiker
  • 8546 Answers
SOURCE: is there a brake down
http://techdocs.shimano.com/techdocs/index.jsp
Shimano only posts consumer-level documents.
http://techdocs.shimano.com/media/techdocs/content/cycle/EV/bikecomponents/ST/EV-ST-M510-1899_v1_m56577569830609281.pdf
Elves build these things.
Posted on May 18, 2011
dunnbiker
  • 8546 Answers
SOURCE: Shimano STX (combo brake and
You can't have end-to-end intact cable movement and NOT move the derailleur unless it is NOT tight to begin with. Look closer.
You need to figure out at which end the problem lies.
You can elevate the rear wheel (or hang the bike by the tip of the seat on a low branch) and pedaling it forward with your hand you can grab the bare exposed cable somewhere in its routing (usually along the down tube) and pull sideways on it (away from the bike) to see if the derailleur moves as expected when the cable REALLY moves. Then you can decide if the shifter is or is not controlling the cable.
Everything is replaceable as required.
Adjustments: http://www.parktool.com/blog/repair-help/categories/derailleur-systems
or use a search engine "how to...." for videos.
Posted on Jul 10, 2011
Exploded view of parts diagram for shimano tourney st-ef40 shifters for re-assembly?
If you can't find with a search for st-ef40 diagram or on the Shimano site then it does not exist. Although not identical carefully disassembling the other shifter may give you enough insight.
Apr 08, 2015 | Shimano Tourney ST-EF40 3x7 Speed Brake...
Hi! is there any replacement for shimano ST-3300, 8 speed, right hand STI lever?? many thanks
There's a used pair on an eBay auction right now ending 6d 09h (Sep 21, 201101:52:54 PDT) that you might be able to snag for cheaper than a separate right lever. Wait til the last 10 seconds and bid ONCE. Leave time to confrm the bid.
http://www.ebay.com/itm/SHIMANO-SORA-8-SPEED-STI-3300-BRAKE-LEVERS-DUAL-SHIFTERS-8x2-8sp-/200651614761?pt=UK_sportsleisure_cycling_bikeparts_SR&hash=item2eb7c4aa29
There are other models, too.
My $.02: I'd take the opportunity to switch to Campi Ergo (also available on eBay). The brake lever is ONLY a brake lever so you don't have to tip toe around it when shifting and ALL CABLES are hidden.
Sep 14, 2011 | Shimano Sora ST-3304
How do i feed shifter cable through shimano v brake shifters
Maybe find the exact (or similar model) at http://techdocs.shimano.com/techdocs/index.jsp
or use a Search Engine "shifter cable through shimano v brake shifters" for videos and other advice
or
http://www.parktool.com/blog/repair-help/linear-pull-brake-service-v-brake-type
Jul 24, 2011 | Shimano Cycling
Ive a new rear deore unit cable and housing etc. where does the cable secure in the shifter unit? I can see a small metal arch but cant figure where the end of the cable actually fixes
Not a great picture but if you follow the arched groove back from the cable-housing guide it leads to a little hole. THAT is where you stick the cut end of the cable.
Accounting for physical differences, this should get you going.
Jun 21, 2011 | Shimano Deore Xt Thumb Shifters 7...
Shifters don't catch and move the cable
These are among the simplest design for shifter on the market. If the cable is taut it WILL pull. Perhaps the cable is broken, grossly loose or rusted inside the housing.
If the model is incorrect look for yous at http://techdocs.shimano.com/techdocs/index.jsp
Procedures... http://www.parktool.com/blog/repair-help/categories/derailleur-systems
Apr 19, 2011 | Shimano Deore Xt Thumb Shifters 7...
My Shimano Deore DX mountain bike up / down shifter is malfunctioning. Any help will be appreciated.
Maybe start here and if you can't figure it out, take it to a Bike Shop. Ther's only so much useful mechanical advice one can remotely lend with no details.
Jul 03, 2010 | Shimano Deore Xt Thumb Shifters 7...
New shifters for deore xt x7 delrailer
Shimano make an "EZ fire" which is an integrated shifter/brake lever combination and cheaper than buying seperate shifters and levers.
e.g.
http://www.tredz.co.uk/.Shimano-Acera-8-Speed-EZ-Fire-ShiftersBrake-Lever_24339.htm
Feb 07, 2010 | Shimano Deore Xt Thumb Shifters 7...
How do I replace rear shifter cable in shifter lever? Older Shimano Deore XT
Oct 03, 2009 | Shimano Deore Xt Thumb Shifters 7...
Shimano st 7900 shifter,left lever apart and how to reassemble
You can download an exploded diagram of the 7900 series STI shifters here:
http://techdocs.shimano.com/media/techdocs/content/cycle/EV/bikecomponents/ST/EV-ST-7900-2874E_v1_m56577569830670749.pdf
You can reassemble them according to this diagram.
May 11, 2009 | Shimano 2008 Dura-Ace BR7800 Rear Road...
Cycling Logo
380 people viewed this question
Top Shimano Cycling Experts
John Egan
John Egan
Eric Hidle
Level 1 Expert
Mike
Are you a Shimano Cycling Expert? Answer questions, earn points and help others
